Question about RCA HD56W66 56" HDTV
RCA hd56w66 56in. hdtv
Our tv was working fine no problems at all. turned it on and there was no picture just audio. checked all outlets and cant seem to figure out the problem.
I JUST LOOKED UNDER RCA.COM AND FOUND THIS .. IM TO AM HAVING THIS PROBLEM.. ITS THE LAMP. IT SAYS IT ONLY NEEDS A FLAH HEAD SCREW DRIVER TO GET TO IT BUT YOU NEED THE HEX WRENCHES TO OPEN THE BACK UP.. THE LAMPS ARE RATHER EXPENSIVE. BUT I WILL TRY THIS BEFORE I PAY 216.00 FOR A SERVICE CALL THAT DOES NOT APPLY TO THE WORK DID ON THE TELEVISION..SO I NEED TO ORDER THIS LAMP...HOW BOUT YOU..
Posted on Aug 06, 2008
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No audio on rca hdtv
The audio in your set is probably mostly contained in a single larger IC, possibly attached to a heat sink. These often have 80% of the audio circuitry and are not immune to failure. To locate and test this area, one should have some electronic skills and at least a multimeter. If you feel you have done what is necessary to turn on the audio, you may need an expert.
Dec 13, 2008 | RCA D52W23 52" HDTV CRT TV
Frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Dec 09, 2008 | LG 37LC7D 37 in. LCD HDTV
NO SOUND at all!
The audio is controlled by the small signal board, which is very costly and hard to get, however I will post a link where you can get one for about half price. Its called the ITC small signal board and its actually a sale item at this site. Heres the link.
http://servicemanuals.vstore.ca/
Sep 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help rca 46inch
I have the same problem using HDMI cable, I was able to get it working using composite or RCA
cables. I still cant get it working on none of the 3 hdmi inputs
May 31, 2008 | RCA L42WD250 42 in. LCD HDTV
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
Volume not working
if you are connecting the tv through RCA cables, then you are not plug in right the red and white cables that are standard for audio... like the yellow cable that its a standard for video signal..
check if that seems to be the problem..
Jan 08, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
LG 47" LCD TV - 47LC7DF Clicking Noise
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Dec 13, 2007 | LG 47LC7DF 47 in. LCD HDTV
RCA HD56W66 56" HDTV Logo
83 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
