Back to:
Tags:
Minicom RackManager 17
Minicom on RH 7.3 and connection to Solaris
By Riddle - usenet poster
Dear experts,
we have installed a 8-port serial interface on an Intel PC
where we are using minicom 2.00 to have 8 Sun Solaris consoles
on our RH 7.3 desktop.
Everything is working fine except the case when our RH 7.3 system
is powered/shut down:
All connected Suns crashes i.e. falling back to the ok boot prompt.
Here is our used minirc.ttyS* file:
pr port     /dev/ttyS*
pu baudrate 9600
pr bits     8
pr parity   N
pr stopbits 1
pr rtscts   NO
pr xonxoff  YES
Is there any way to "save" our Suns?
Many thanks for your help!
Rainer Blaes
Astrium GmbH, Bremen (Germany)
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 07, 2005
Not Rated (0)
Horner
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Presumably those servers are accessible over the network.  If so just
use ssh in 8 separate x-terms (or rxvt, my own choice) to connect with
them.
[acl]# ssh tar
Last login: Sun Sep 15 21:54:38 2002 from host.domain.tld
Sun Microsystems Inc.   SunOS 5.8       Generic February 2000
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Minicom on RH 7.3 and connection to Solaris:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Powe33
Rating: 0%, 0 votes
I guess the Sun experts generally hang out on a Sun newsgroup.
On the Sun boxes, switch the kbd BREAK sequence to use the
alternate break sequence (varies from Sun to Sun box... but
nowadays the alternate sequence is <CR>-tilde-ControlB)
On the Sun boxes...
# kbd -a alternate
Personally I use the Cyclades terminal consoles... because the
also allow the portraying of serial connects across the network
and they HANDLE the accidental BREAK problem when dealing with
Sun boxen.
Thank You!
Can you Help with these KVM Switches problems?
KVM Switches
I have checked and found that there is no power to the...
KVM Switches
I just purchased a new KVM switch but when linked up it is...
KVM Switches
my 6 gang anti-surge filter block bleeps intermittently,...
KVM Switches
2 Computers (an iMac and a Windows machine) to 1 HP 7410xi...
KVM Switches
I have a MasterConsole 2 16 ports and I'm not getting any...
Loading problems.
Repair Service
Find KVM Switch Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
