Question about JVC AV-27D502 27" TV
Sleep timer has been activated and i cant turn it off
  • guezz Jul 09, 2008
    this did not help but thanks anyway
  • tmvjdm Aug 28, 2008
    timer light flashing red. not sure why. tv will not turn on
    Sergeant:
    Champion:
  • 248 Answers
Your T.V.s Sleep Timer feature is a programmable automatic timer that will turn your TV off after a certain amount of time. Just reprogam it to the amount of time you want. You probably find that in the menu of your T.V.
Thanks!
Posted on Jun 20, 2008
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Sharp 21ne61
Probable Causes:
(1) Sleep Timer has started (You should get a on-screen Notification in this case, before Auto Turn Off). Turn Off Sleep Timer to get rid of it.
(2) Something is wrong with your TV (Get it checked at Authorized Service Center if Warranty is active, if not, contact any Television Engineer or Electronics Engineer).
Mar 29, 2014 | Sharp Televison & Video
I cant activate the sleep timer
Possibly the remote button for the timer is stuck or the remote is broken.You could try to take the remote apart and clean whatever is blocking the contacts inside it so you can activate the timer again.Some remotes have srews holding them together and clips so it basically snaps together.You need a thin flat head to pry open the remote if possible.Open up a small crack and slid the driver along the opening till it pops open.If that is too hard or your afraid to break the remote just look into buying another one.
http://reviews.cnet.com/4566-13548_7-0.html?filter=500816_109732_500820_5312423_
Dec 07, 2011 | Philips 25PT4458 25 inch TV
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
I am trying to turn off a sleep timer that is built into a rca universal remote
When you press a sleep timer, it sometimes is all you can do to activate it,
but when you press the button again shortly after, the time on the sleep delay
will change, eventually to being off/cancelled. ?
PLEASE RATE THIS ANSWER
Aug 13, 2011 | Televison & Video
How do I use the sleep timer? when I push the sleep timer button it gives me on time and off time to set. I dont know how to use this. Cant I just set sleep timer for 30 minutes to turn off? Thank you.
Hello
Before going to set the timer, you have to set the current time. Set it according to the manual with you. If the timer function work properly, there must be an uninerrupted power supply also. If the power goes off, the set time will also get resetted, and improper function will occur.
After setting the present time, set the "on" time and "Off" time. The TV will switch on at that time you set, and will switch off automatically after the end time. OK.
Dec 23, 2010 | RCA 20F420T 20" TV
It keeps turning itself off! How do I keep it going 24/7?
Well that seems like a waste of energy.
Anyway that is your problem.
The Power/Sleep button has a dual function: Power ON/OFF and Sleep.
A short press will turn the timer on and you will see numbers like 90, 75, 60,...10, 01. pPressing again will cycle to the next sleep duration. If your radio has a short duration timer it will seem that it is turning itself off.
To activate a normal Power up, your first press should last longer (I cannot tell you how long, you will have to try it on your own.) You should not see the timer durations, just the frequency of the station its was last tuned to. In addition, no loudspeaker should be displayed at the lower right corner.
Sep 03, 2010 | Grundig S350 AM/FM/SW Radio
No action shutoff was activated. How do I turn
Go in ur tv menu go to SETUP.Check for Sleep timer might be on.This timer have setting like 30 60 120 mins.Turn off the sleep timer tv well not auto shut off.Check ur remote control might have a button said sleep.
May 28, 2010 | Panasonic TH-46PZ800U Plasma TV
My remote does not have the sleep timer button.
Open cover on the bottom part of the remote SLEEP button is there.
Sep 09, 2009 | Sharp AQUOS LC-32D43U 32 in. LCD...
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
JVC AV-27D502 27" TV Logo
183 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
