Question about Vacuums
Vacum I need to check the brushes in the motor smells have removed four screws but the cover is not coming off. I dont want to damage this by forcing it but cannot find any other screws Thanks fairweather
  • gangy1 Jun 25, 2008
    REPLY
    Hi Richie
    Thanks for replying the problem was greater than I first thought
    First it was not just as simple as undoing four screws after careful examination I found I had to remove the base also cir-clips holding this together, checked on the brushes these were ok. After reassembling the motor was staling, the problem was the end fitting to the roller brush had worn out especial at the belt end this was jamming. Telephoned to get new parts (none available obsolete so I have manufactured these from using (Need It)
    As yet I have not reassembled it but should be ok.
    Thanks again for your response
    Genius:
  • 1,036 Answers
Hi there!
It would certainly help if you said which model it was.
I can only give generic help now, and do the best I can for you.
Most plastic products rely heavily on moulded catches that click into grooves upon assembly. The screws are fewer in number, and tend to be centred in the assembly, or spaced at intervals around the periphery. This is the "belt & braces" method which works quite well.
With the screws out, press around the seam line to see if it will pop open at one of the clips, then chase the gap around to all of the clips. You may have to insert a spacer as you go so they don't snap shut again.
There may be hidden fasteners under labels, star lock springs, or solvent welding to make more money for the manufacturer who insists you buy a new unit instead, but with a little care, and seeing which parts are not moving - and finding out why, then you should do it.
Worse case scenario, you crack the casing and have to glue it, saving the expense of a new motor. - Usually worth it.
If this helps you, Please rate as Fixya!.. Much apreciated thanks.
Posted on Jun 20, 2008
Motor smells Oreck Xl2
If it smells electrical, than you may need a new motor. If it smells more like burnt rubber, than you may have a brush or motor problem. To check you brush, take out the 5 screws that hold your bottom plate on the vacuum and remove the plate. Disengage the belt and see if the bearings at each end of the brush turn freely. If they do not, replace your brush. Also spin the motor shaft by hand and see if it turns freely. Hope this helps!
Mar 02, 2015 | Oreck XL21 Bagged Upright Vacuum
Sebo felix belt is broken,taken screws from bottom of vacum but will not come apart
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment..
Oct 13, 2012 | Sebo Felix Ice Blue Bagged Upright Vacuum
Where is the belt housed on the Hoover vacum cleaner model U5461-900? The belt number is 38528-033 but I can't find where the broken belt is to replace it.
Simply lay the machine down with the brush assembly facing upwards, and remove the four screws holding the bottom plate in place, and remove it. Put the new belt around the motor shaft, then around the brush assembly and push the brush back into place. Turn the brush with your fingers before replacing the bottom plate, to be sure the belt isn't caught between the brush and housing.
Jul 27, 2011 | Vacuums
How do I get to the belt on my electtrolux discovery 2 vacum cleaner. took the bottom screws out but still cant get top off?
There are clips holding it together. On the bottom of the power head are two square "holes". Insert a standard screwdriver to release the latches. Once they've released and the cover is loose, turn the power head over and lift the back. Don't force it off.
You will then need to remove the screw at each end of the brush.
When reassembling it, be sure the front of the cover is inserted into the groove in the base. Then press gently down until it clicks into place.
Apr 30, 2011 | Electrolux Vacuums
How do I change the belt on a Bissell Powerforce model 3522-1?
this is how you do it Lower handle and place vacuum on floor so you can see bottom of power head. Examine the power head to remember what it should look like when finished. Unscrew the four screws (Phillips screwdriver). Lift off cover. Lift out brush. Remove belt from brush and motor shaft. Place new belt around motor shaft, then around brush just prior to reinserting brush. Make sure the belt is placed correctly. Reinsert brush in slots. Rotate manually toward motor a few time to center the belt. Replace cover and screws. Tighten securely. Check cover to make sure it's properly secured.
Feb 16, 2011 | Bissell 3522 PowerForce Bagged Upright...
How to replace band
Make sure vacuum is unplugged. Lower handle and place vacuum on floor so you can see bottom of power head. Examine the power head to remember what it should look like when finished. Unscrew the four screws (Phillips screwdriver). Lift off cover. Lift out brush. Remove belt from brush and motor shaft. Place new belt around motor shaft, then around brush just prior to reinserting brush. Make sure the belt is placed correctly. Reinsert brush in slots. Rotate manually toward motor a few time to center the belt. Replace cover and screws. Tighten securely. Check cover to make sure it's properly secured.
Oct 03, 2010 | Bissell 3522 PowerForce Bagged Upright...
Motor noise and burning smell
your belt is of the guide arm try replacing the belt usually located @ the head of the vacum there should be 4-6 screws holding the head on remove it in well ventilated area try putting on mask cause you will release all the dust from the head when you take it apart you will see the belt around the brush remove the brush and bearings togther then replace belt if you know your model # of your vacum u can usually find replacement parts online or @ most sears and walmart outlets.
Jan 26, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Change belt on bissell vacum cleaner model # 6850
On your Bissell 6850 you need to turn your vacuum over and on the front there is a brush with a cover. Remove the six screws, take the cover off and simply pull up on the brush, the belt is attached to the brush and will come off easily. Put back together in opposite order.
Jun 29, 2009 | Black & Decker Vacuums
I need to replace the motor on a Sebo Automatic X!
OK, here goes...  NOTE - any use of the words LEFT and RIGHT assume that you are looking from the REAR of the machine.
STEP 1. Separate the base from the bag compartment: press the button at bottom front centre of bag compartment and lift bag compartment upwards away from base. Sometimes this is quite stiff and four hands would be useful, you can lever it from behind with something relatively soft (the plastic handle of a dishwash brush works well) but take care to lift vertically upwards, not sideways or you risk bending a metal lever that's hard to get back into shape again. Rest assured that once you've pressed that button there is nothing holding the two parts together other than friction!
STEP 2. Turn the base upside-down and undo the FOUR DEEPLY-RECESSED SCREWS.  All the surface-mounted screws are irrelevant to this job.
STEP 3. Turn the complete base right-way up, release the foot pedal and move the vacuum tubes out of vertical.  The top cover will then lift off.  You will see there are two belts - the pulley device between the motor and the brush roller is the sensor that measures the drag on the brushes and operates the automatic height adjuster to maintain constant drag. To the right of that double pulley is the electronic circuit board - note that it has a sensor that locates within the pulley device, be careful not to damage it.
STEP 4. At the left end of the motor cover, the drive cog is concealed by a small cover. Lift this cover out vertically, noting how it locates in the frame for when you come to put it back.  Next, although not essential, it helps to remove the metal lever because if it falls out when you're not looking you may later be uncertain about how to locate the small coil spring. So slide that lever out towards the motor, noting how the spring locates.
STEP 5. Undo the two screws holding the circuit board (take care the washers don't slip away). You need to do that because the front of the motor cover is tucked underneath it, but you don't need to move the circuit board more than a few millimeters.  Then undo the four screws holding the motor cover and lift the cover away.  The motor will then just lift out.
Re-assembly is simply the reverse of the above process.
If you need more help, just ask.  Please remember to rate this response.
Apr 15, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Removing obstruction from vacuum motor
Most Eureka's, there are 2 or 3 screws on the top to remove, then the top cover will come off. If no screws on top. then they are on the bottom. After the top is off, the belt and brush are right there in the open. To get to the motor, that off the 2 screws on the clamp on wach side of the motor, screws that are around the motor housing and then the motor cover should pull off. If the smell is electrical, if could be a bad motor, which sells for around $75 to $90. If the smell is more like rubber, then look at the belt and brush roll. If you need more info, get the model # off of the tag.
Feb 12, 2008 | Kenmore Progressive Bagless Upright with...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
