SOURCE: Front door gasket whirlpool duet washer
before replacing run a empty load with alot of bleach in it and then clean boot with a mold cleaner like kitchen cleaner w/bleach replacing the boot isnt something you want to do unless you have to do it (not easy) and the cost of the boot if you need any more help let me know and i will guide you thru the process of the boot
bill
SOURCE: replace door gasket lg wm2277hw
Hiya,
you can find spares for this machine on espares i think the gasket will be a universal one but here is a link for you to check
http://www.espares.co.uk/parts/lg/p/0/81?k=wm2277hw+door+gasket
Please note i have not used this site before but i have noticed that they will deliver to most countrys & im sure they will be able to help with a fitting tool issue if you contact them.
Hope this helps
SOURCE: Can the rubber gasket between
it can be but don't reccomend it unless you have done it before such as a repairman. i have found that cleaning it with bleach usually does the job. you may want to also run about 1 cup of white vinegar through a hot water load by itself and that should alleviate any odors for the most part. you can also by a product called washer magic at most stores. made specifically for cleaning front loaders.
SOURCE: the rubber gasket has gotten
Use a solution of bicarbinate of soda in water to remove the mould. If that does not work you can purchase a mould remover for bathroom tiles that will do a better job.
It is recommended to leave the door open when the machine is not in use so that any residual moisture will evaporate and you will not have this problem in the future.
SOURCE: where can i get the rubber fitting that is behind
just type in your make and door gasket, that is the part you need,, keep this in mind, they are very tricky to change, you have to take the whole front off to install it correctly, it takes me anywhere from 20-30 minutes to change one and i do it at least twice a week
