Question about Dryers
Simpson Maxidry 362. Tips on putting back together....? Roller tensioner spring attached to...?
    Sergeant:
  • 275 Answers
Here are the steps to get the belt and tension pulley and spring attached properly.
1. Remove the drum from the dryer housing
2. Fit the belt around the drum, secure the belt to the drum (grooved side towards the drum, flat side away from the drum) with small strips of masking tape. Leave a loop of about 10-15 cm's free to fit around the motor. (This was Hurdle #1, it was next to impossible to hold the belt on with one hand and attempt to work out the tension pulley thing at the same time)
3. Place the drum back in to the dryer housing and rotate it so that your belt loop is facing the motor.
4. (Hurdle #2) Attach the tension pulley to the motor assembly bracket. (There should be slots in the bracket for the pulley bracket to insert into. The pulley faces away from the motor, about a 45 degree angle.
5. (Hurdle #3) Feed the belt through (under) the pulley and then over the motor's drive wheel or nub, whatever it's called.
6. (Finaly Hurdle) Attach the spring to the pulley assembly. In the centre of the dryer housing floor, there should be a seam, in the centre of this seam there is a small hole where the other end of the spring attaches too. Stretch and insert the other end of the spring into this hole.
7. Remove the masking tape that's holding the belt down.
8. Re-assemble dryer and your done.
Posted on Jun 20, 2008
  • 4,889 Answers
Here you go. Its not exactly the same model but it will give you some idea..
http://www.ilfordphoto.com/Webfiles/200731916307816.pdf
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Http://www.trademe.co.nz/Home-living/Laundry/Dryers/auction-160412418.htm
its a problem that you cant solve here
better to contact
  • Dryers Master
  • 13,433 Answers
A service(repair) manual would be great for you.
you should be able to get one from simpson
This site is for australia
http://www.simpson.com.au/locator/search/service/
might not be a good idea to call australia if your not over there.
check the manual / service card for contact information, ask for a repair manual that should solve all your problems in putting it back together.
  • 426 Answers
Should be mounted to the motor or the side paneljust under or to the side of the drum
I have a Simpson Maxidry 362 3.5kgs. The timer has stopped working. If I put it on 30 minutes it remains stuck on 30. Can I repair?
Hi, I owned a dryer a few years ago and the timer switch became faulty on that so i pulled it out and took the switch to a repair store where i bought a new timer switch.....CHEERS..
Mar 25, 2016 | Dryers
Can you please tell me where I can get a Simpson Maxidry 1000 user manual or any other kind of manual for this dryer?
Try this link:
http://fasterbetterdownloads.com/simpson-maxidry-1000p-user-manual/
Jun 20, 2015 | Dryers
Simpson maxidry 362 dryer not heating, everything else seems ok
Two things to check. First, check for any lint in the screen or lint build up in the exhaust. this will restrict airflow. Secondly, check to see if the heating element is bad.
May 15, 2011 | Dryers
2000 ford Taurus belt replacement
The belt is held in tension by a speing loaded roller thet is a part of a spring tensioner,
The tensioner needs to be retracted to remove the fension so the belt can be removed.
To remove the tension, you put the proper size socket onto the bolt head that is on the center of the tensioner roller. Attach a breaker bar to the socket and lever the tensioner back to losen the tension on the belt (be careful there is a lot of spring force to deal with )
Oct 12, 2010 | Ford Taurus Cars & Trucks
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
MY SIMPSON MAXIDRY 362 3.5KG HEAVY DUTY DRYER KEEPS OVERHEATING AND CUTTING OUT. WHEN IT STOPS AND I PRESS THE SAFETY SWITCH IT TURNS ON AGAIN BUT ONLY FOR 10 MINUTES. CAN YOU ADVICE ME ON WHAT I CAN DO...
I would check the exhaust pipe outside and make sure it is not blocked and has good strong air flow while the dryer is running. If there is not good airflow, then clean out the exhaust hose and pipe. There could be other problems, but I would start with this.
May 01, 2010 | Dryers
Broken door on simpson maxidry 362
when it comes to whitegoods old is good. your dryer will outlast most new ones. buy the new parts it will b lot cheaper than a new dryer. not much goes wrong with the old simpsons. please reply if u need more help
Apr 11, 2010 | Dryers
Replacing the belt on a simpson 362 maxidry
Check out applianceaid.com good easy site to follow
Apr 19, 2009 | Electrolux Dryers
How to fix a Simpson Maxidry 1000p?
Idler pulley and spring have come off while cleaning dust from inside cabinet a diagram whould be a great help as Im 500kms from nearest service place simpson maxidry 1000p Ray bushed
Jul 26, 2008 | Dryers
Dryers Logo
1,317 people viewed this question
Top Dryers Experts
