Question about HP LaserJet 4200 Printer
50.2 Fuser error
I have printed two pages and then the word 50.2 Fuser error appear on the printer. I press ? and directed to turn Off printer but I didnt succes.
  • dissanayake May 01, 2009
    blink 'Attention' bulub. Can't take any print out.
    display on printer screen as 50.2 FUSER ERROR
  • 138 Answers
You need to replace the fuser. Part number RM1-0013. Priced well on exchange at Seattle Platen. Contact is Dale 800-221-2388.
Posted on Aug 05, 2008
Hp t1100 error 50.2
nstructions
  1. Remove the printer from any UPS supplies, additional power supplies, or power strips.
  2. Plug the printer into a wall outlet to check whether this resolves the problem.
  3. If the printer is already plugged in, try another power source in the building independent of the one being used.
  4. The line voltage and current source at the printer location might need to be inspected to make sure that it meets the printer's electrical specifications.
  5. Turn the printer off then on.WARNING: Be careful when removing or reseating the fuser. Temperatures can reach 400+ degrees Fahrenheit.
  6. If the message persists, turn the printer off for 30 minutes to allow it to cool, then reseat the fuser after checking the internal wiring connections on the right and left side, ensuring that these connections are properly seated.
  7. If the 50.1 or 50.2 error recurs after power-cycling the printer or when trying to print, try installing a known good fuser from another HP LaserJet 4100 series printer, if available.
  8. If the fuser is near or at the end of its estimated life expectancy (approximately 200,000 pages), then replace the fuser. After replacing the fuser, print a Configuration page, a Menu map (shows fuser settings), an Event log, a Supplies status page, and a Usage page, to reference the status of the new fuser and to ensure that the previous fuser settings are in place with the replacement fuser. To print an Information page on the HP LaserJet 4100, perform the following steps
    1. Press the MENU rocker key until INFORMATION MENU appears on the printer display.
    2. Press the ITEM rocker key until PRINT CONFIGURATION (or until PRINT MENU MAP, etc, appears in the printer display.
    3. Press the SELECT button to print the selected information page.
    To print an information page on the HP LaserJet 4100MFP, perform the following steps
    1. Press the MENU button.
    2. Press the DOWN Navigation button until INFORMATION is highlighted.
    3. Press the RIGHT Navigation button.
    4. Press the DOWN Navigation button to highlight PRINT CONFIGURATION (or PRINT MENU MAP, etc, appears in the printer display.
    5. Press the SELECT button, the button with the checkmark on it to print the selected Information page.
  9. If 50.x errors persist after properly installing a known good fuser, or if the errors follow the questionable fuser (provided it is not near the end of its estimated life expectancy), contact HP for further assistance.
Removing and replacing the fuser
Mar 23, 2013 | HP Designjet T1100 Photo Printer
I have an hp 4300 with a 13.12.00 error when the duplexer is installed
Here is a copy of the 13.12 error troubleshooting steps from the service manual.
1. Press the HELP ( ) button for
detailed information about
clearing the jam.
2. Press the UP ARROW( )
button and the
DOWN ARROW ( ) button to
step through the instructions.
3. Check the paper width and
fuser delivery sensors
(PS106, PS108) and verify
that the sensor arms move
freely. (See "Location of
printer switches and sensors"
on page 336.)
4. Check the inside of the
duplexer for scraps of media
that might have torn off when
a jam was cleared.
5. Replace the media-size
sensor (PS106) and fuser.
See "Location of printer
switches and sensors" on
page 336 and "Fuser" on
page 162.
6. Turn the power off. Remove
the duplexer and turn the
power on. If the error
message persists, replace
the DC controller PCA. See
"DC controller PCA" on
page 181.
7. Replace the fuser (PS108).
See "Fuser" on page 162.
8. If the error message appears
frequently, see "Paper-path
troubleshooting" on
page 295.
Feb 07, 2013 | HP LaserJet 2420 Printer
55.0 printer error
Error 55.A is an internal communication error. It typically indicates a communication error between the formatter and the DC controller. The most common cause of this error is normally related to the fuser.
Some steps to try:
1. Turn off and turn on the printer to clear the error message. If the error returns after doing this, then, check external printer connections.
a) Remove the formatter.
b) Reseat any memory DIMMs and EIO cards.
c) Reseat the formatter.
2. If the printer has a duplexer installed, remove it. Turn off and turn on the printer, and see if the error clears. If the error clears, then, the duplexer PCA may be defective. Replace the duplexer.
NOTE: With a worn fuser, the 55.A error usually manifests itself while duplexing, however in extreme cases, the error could appear without a duplexer.
3. Verify that there is no issue with the site power. If the printer is on a surge protector or a UPS, remove it, and plug the printer directly into a wall outlet. If the printer is plugged directly into a wall outlet, try it on another outlet, preferably one that is on a different circuit.
4. Print a PCL configuration page to verify the number of pages since last maintenance. If the printer is close to the 350,000-page service interval, then install a maintenance kit.
If the service interval is not near the 350,000-page interval, then, replace the fuser.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 09, 2012 | Office Equipment & Supplies
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
I had a problem in the printer saying that 50.2 fuser error that i can neither print, nor xerox & nor scan also. what can i do now?
When a 50.x fuser appear its because the fuser its worn, its probably overheating. I can suggest to take it out (in the back you will see 2 blue locks) for about half hour (turn the unit off before you are doing that) and put it back in. If the error persist you need a new fuser. Good luck
Sep 06, 2010 | HP LaserJet 2840 All-In-One Printer
What does 50.2 fuser error mean
The 50.2 error means your fuser is not heating up. You will need to order either just the fuser HP Part # RG5-7060 or the maintenance kit HP part # Q1860-69002. Check your local computer store or we can ship the parts to you. If you need additional information contact me at our web site below.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 17, 2009 | HP LaserJet 5100tn Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Fuser error on the hp 3700dn printer
You need to replace the fuser since it is most likely caused by a bad fuser. The 50.1 error indicates a low fuser temperature which can be caused by a fuser failure or a DC controller failure. The HP part number for the fuser is Q3655-69001 for a 120V printer. You can also get the fuser as a replacement supply from your toner supplier the item number is Q3655A. Depending on how long you have owned your printer, the fuser needs to be replaced at 50 months or 75,000 pages which ever comes first.
Apr 13, 2009 | Office Equipment & Supplies
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 4200 Printer Logo
1,297 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
