Whirlpool GS6NBEXR side by side
SOURCE: leak water on floor once a month
This likely a defrost cycle issue. Your drain tube is likely clogged. Get under there and clean it, clean your condenser while you're at it. Cut down door openings, open liquid in the fridge.
SOURCE: WHIRLPOOL CONTROL PANEL
Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
SOURCE: WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
Please see potential solutions at diychatroom.com. Do a search on "whirlpool fridge flickering". I had the same problem, and the solutions worked - can save you the price of a board.
SOURCE: WHIRLPOOL AMERICAN SIDE BY SIDE FRIDGE /FREEZER
I had probably the same problem. After a little discussion with the factory they sent a technician as a "Good Will Gesture." The technician told me it was the control board down by the compressor. I overheard a conversation between he and his central repair office that it was a common problem. The factory would not admit it. I have a feeling the electronic control board he replace (which would have cost several hundred bucks) was probably made in China. Now I'm having more problems with my Ohio made Whirlpool side-by-side. The freezer is working fine, the fridge is not very cold. By the way, the internal lights was one of the keys to the problems.
SOURCE: HIgh temp.
the day after it resumes working . thank you , do you have the premium service in Morocco?
continous beeping sound near the circuit board
