Cars & Trucks Logo
Anonymous Posted on Nov 18, 2010
My 2008 Ford Edge cannot seem to hold the Sirius signal. It works intermittently. For no known reason I lose the signal. (No Signal) I have called Sirius and they have sent an activation signal and it works for a short period of time. Many times there is no signal even on the freeway. Sirius told me to take it to the dealer. The dealer is frustrated and cannot seem to locate the problem. Help.
  • Anonymous Mar 12, 2014
    Had the fmv rear mirror onstalled so I would have on star the ford dealer says that the mirror might be receiving a signal which makes my radio fade out the radio works for about an hour and I donot usr the on star unless necessary
Anonymous
Level 2:
New Friend:
  • Expert 60 Answers
  • Posted on Nov 18, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
60
Questions
Helped
29052
Points
167
I had a similar problem. Tune your sirius to 184, leaving the radio and the key on with the drivers door open. Let set for 15 minutes. Before you do this procedure, call sirius to tell them to send a boost to your radio. This should take care of your problem. Good luck :)
Testimonial: "After following the recommended procedure, the radio worked perfectly until I shut off the car. Upon restarting, NO SIGNAL. Frustrating!"
All done lights flash on and off and the turn
The wire for a door switch is laying on the flasher terminals where the e is crimped to the socket for the flasher. Move the wire and the flasher will flash correctly and the dome lite will work correctly too.
I have an intermittant blinker (turn signal)
Replace right rear tail light bulb holder. Bad ground.
2answers
My 2008 ford focus sirius radio stopped working. sirius tried to reprogram, but it didn't work
Did Sirius resend a signal? If it is displaying their number it is likely that your subscription needs to be updated. The fact that it displays their info means it is likely receiving a signal. If it said "no tuner" or nothing at all, it would likely be the tuner. You can resend a signal online here:
http://www.siriusxm.com/activationhelp
If that does not work, replacement kits are available here:
http://www.tss-radio.com/products/isimple-factory-ipod-and-sirius-integration-for-ford-lincoln-mercury-vehicles-1
Rear right turn signal quits when something gets wet
ok thats simple for for a long time has been known for bad grounds also check where main wire plugs into fire wall see if it is loose but most likly its a bad ground in signal
Seems the Carrier Bearing is out on my 2008 Ford Edge with a little under 55,000 miles is this common & isn't it still under Ford Warranty?
that depends upon what coverages were offered at the time of purchase, and if you purchased extended coverage. well worth a call to the dealership. they can tell you about any ford warranty that is still in effect. sometimes dealers can work with customers that have a premature problem. in any event, asking if your covered, or if not, will they give you any help, costs you only a phone call. these are tough times , and even the dealerships are looking foe whatever work they can get.
2answers
Broken Hazards on 89 Ford Ranger
The hazard switch , turn signal switch , wiper switch are useually all one piece, Called a combo switch, They are known for going bad
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
