Question about Sony Playstation 3 (PS3) Console
Connect ps3 with lcd via HDMI
When I connect PS3 with Sharp lcd via HDMI cabel on screen says " An incompatible video signal has been received"
Please Help me if you can.
Thank you
  • baybaybrat Mar 28, 2009
    when i connect my hdmi to my ps3 then go to setting on the ps3 and try to change it to HDMI it just goes blank for the 30 seconds
  • Sony Master
  • 8,617 Answers
I have no knowledge of game consoles whatsoever I suggest submitting your request to another expert as we have many here that are experts with game consoles. Sorry I couldnt help you out.
Posted on Jun 20, 2008
Incompatible video signal has received check output device settings
My guess would be that your PS3 has somehow switched the output settings. You can reset the settings by pressing and holding down the power button till it starts blinking. Try connecting it with your RCA cables to a TV and if that works try going into your settings and setting the PS3 back to HDMI.
Jan 23, 2014 | Sharp Aquos Televison & Video
I am trying to connect ps3. (bought may 2012 with uncharted 3). To my denon 2313 via hdmi. No video at all or sound? Please help
You need to tell the PS3 to use the HDMI cable output. To test have you tried connecting the PS3 directly to the TV. Once you have that working then add in the AVR.
Jan 19, 2013 | Denon AVR-2313CI
Won't accept my PS3 video signal
HDMI does not like being connected when units are powered up.
Try unplugging both units--wait and then connect the HDMI and power both units up again.
May 16, 2012 | Sharp LC-45GD7U 45 in. HDTV LCD
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Jul 17, 2010 | Sharp LC-32SB23U 32 in. LCD TV
How to connect the PS3 to RX-V365 to get best sound qualitity in films. I have sony BRAVIO LCD wiht PS3 and I recently bought RX-V365 Yamaha home theater system. Please advice on connecting all three to...
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
Feb 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
PAL PS3 NTSC HDTV, HDMI Cables don't work, WHY?
I have the same problem. I get the "Mode Not Supported" message on my Samsung pn50b860 when I try to run the PS3 through the HDMI. Any solutions/suggestions yet?
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Incompatible signal
Check your resolution settings on you playstation 3 menu's. If you are using an HDMI cable, there is a chance that your ps3 could be trying to output at 1080i or 1080p. The unit you have only goes up to 720p and if you set it any higher than that, you run the risk of having picture issues, or not getting a picture at all. Good luck to you
Mar 28, 2009 | Sharp LC-32SB24U 32 in. LCD TV
No Audio
YOU HAVE TO GO INTO SETUP AND SPLIT THE AUDIO SIGNAL VIA OPTICAL OUTPUT. THE PS3 WILL DETECT THE CABLE AND GIVE YOU A PROMPT.
SYTEM SETTINGS ON THE STARTUP SCREEN AND BE SURE TO NOT HAVE A GAME IN THE MACHINE AT THE TIME.
May 19, 2008 | Sony Playstation 3 (PS3) Console
Hdmi settings?
Hey Kris, this might all be about different 1080 settings. Maybe Your consoles work on 1080i and the TV is 1080p.
It more sounds like your receiver has a faulty HDMI jumper, which you wont be able to fix. Here`s what i would do:
If your lcd has two HDMI inputs, use on for each the receiver and the other for the ps3...
2-For how important is to rather connect the ps3 via HDMI, for picture quality. then simply get an HDMI splitter, yes... YOull have to go and switch from receiver to ps3 whenever you want to play BUT it really sims your receiver is not going to cut it.
The pink you see is an incorrect "GAMMA" signal thats only induced by a malfunctioning software or hardware.
Is your receiver from a cable company? Try to get it replaced.
I would start there and if it wont make a difference, go with the splitter. YOu might get one at walmart, Radio Shack or ebay.
Hope it works and please feedback with results.
Good luck!!!
Jean
Dec 05, 2007 | Yamaha HTR-5990 Receiver
Sony Playstation 3 (PS3) Console Logo
160 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
