Question about HP Office Equipment & Supplies
I have a new C4200 just installed and the window says the usb cable not connected I have unistalled and reinstalled, change the cable and the computer ports with no good results what next?
    Genius:
  • 2,785 Answers
Plz check is your usb ports are working if yes then try the printer in another port or pc.You can scan your pc for viruses
Posted on Jun 20, 2008
How do I turnon the USB on the westell 6100 modum?
f you reformatted your Windows on your pc, there's no need to change the settings of your network connections. The Westell 6100 can either be connected to your pc using the Ethernet port or the USB port if you're using the combo cable or Y-cable. It's more stable to use the Ethernet port for your Lan connection. For the USB, to reinstall the USB connection properly, you'll need the Verizon Installation CD. Make sure the USB is not connected to your PC first before you install it. You just need to follow the CD because it will tell you when to hook up the USB cable to the pc. If you still have the CD, after it runs, you have to select existing customer and then select connect new modem. After that you just to have follow the steps to install the USB connection properly and then your modem will work fine afterwards. If the problem still persists, you can try replacing the cable. If all else fails, it could be a modem problem already. You also need to check your Network Interface Card of NIC as we call it, it's built in your pc. it's the device that allows your pc to communicate with the modem. Normally after reinstalling windows, the NIC is forgotten, make sure you also install the drivers and utilities Cd for your windows.
Sep 06, 2011 | Westell Wirespeed ProLine 6100 Router...
Usb device not recognized when I plug phone into laptop, it always worked before
in device management uninstall all USB drivers. restart the laptop.
if it still dont work then unistall the software for the mobile. restart the laptop
install the software again, then connect the mobile.
if still not working try your mobile on another pc or laptop, if it work then you may have a problem
with your windows USB drivers, which mean you will need to reinstall windows on your lap.
you can test you mobile with another usb cable also on your lap.
good luck
May 28, 2011 | HTC Hero Smartphone
Cant open as a storage device on the pc
1 First connect it with ur PC with the data cable provided along with it.
Go to the My computer icon. right click on it. Select manage. one window will pop up select device manger and the in the right side a window will come . select the option of USB. The port with which ur hardware is connected will show with yellow error mesage. slect that port and unistall the driver and select the main menu of the USB and select the option scan for the hardware changes.
2 If it detects ur hardware device then ur device is ok no physical damage.
3 Reinstall the OS with the help of the CD provided along with this player
4 Read the manual carefully before installing the OS.
Please note that never format the MP3 player while installing the Os the manual caonatins step by step procedure to install the OS follow that only.
If you format the MP3 player then ur Mp3 player willl be permannetly damaged.
Jan 26, 2011 | Sony Walkman NWZ-B142 MP3 Player
I replaced the hp1522nf that was there with the exact same printer. just unplugged the old and plugged in the new one and i cant get it print.
It might be the same printer but sometimes Windows creates new virtual ports. I suggest unistall and reinstall if you haven't try that. If the problem persist check in the device manager (just type that in search of windows) and check if the unit its recognized under universal serial bus controllers. If its there you have a software issue, sometimes it will be there with a yellow exclamation mark, just right click on it and then click on update driver, follow the instrutions and choose recomended actions always. If its not there, change the USB cable, or increase the USB Speed in the printer menu, under service from high to full. If you have a network connection the might have a different IP address so with the reinstall will be solved
Jul 23, 2010 | HP LaserJet M1522n MultiFunction Printer
Can´t install my photosmart C3180 on my Windows XP.
I recently have the same problem with windows XP ( when I connected the printer the message USB device unknown message appeared) Before wasting your time unistalling and reinstalling driver, I strongly recommend this:
Change the USB cable for a new one that works properly for USB 2.0 FULL SPEED . What does it mean ?. Well if you have an older cable is very probably that it doesn't work well at USB2.0 full speed (480Mbps) because it's not properly shielded, if you buy a new one check specifications on the box to see if it is prepared for 480Mbps. Testings in other PCs is not relevant unless you're ABSOLUTLY SURE that USB ports are working at full speed in those PCs
I changed old cable for a new one ( Belkin), and no more problems.
Dec 03, 2007 | HP Photosmart C3180 All-In-One InkJet...
Install
Remove usb cable, Unistall software and drivers, reinstall software and driver and connect only when software prompts to do so.
Brother Unistall tool link xp
Brother Software and Driver link xp
Dec 02, 2007 | Brother MFC 420CN All-In-One InkJet...
My Epson R1800 keeps resetting itself
You have done all the usuall checks, but you may have a usb power problem, try the printer without any other usb peripheral in and see if it stays connected. If not, then the usb connection or workings in the printer may be faulty and keeps disconecting, hence the bing bong as it re connects to windows. You may have faulty hardware, leave the printer disconnected from usb and mains for 15 mins or so then try again.
Mar 18, 2007 | Epson Stylus C86 InkJet Printer
69 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
