Question about SanDisk Sansa e260 MP3 Player
Main image failed
I accidently deleted all the files from my mp3 player after that when i switched on it displaying the following statement "load main image failed switch to recovery mode." also when i get conneted it to my pc it did'nt gave nay sign of connection.so please help me to reslove this problem.
    Problem Solver:
Idk
Posted on Jun 20, 2008
My e260 is saying "load main image failed switch to recovery mode" what that means
Load main image failed, this is a firmware error, (this does not have software like a computer)
Recovery mode, the player tried to recover from the error.
The player has firmware updates that where put out by the MFG because of problems.
You have to read the manual, carefully and follow it to the T.
because you need to update the firmware on the player.
This is there website.
http://kb.sandisk.com/app/home
Feb 08, 2010 | SanDisk Sansa e200 MP3 Player
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e280 Main Image Wont Load Problem, Plus firmware updater doesn't work
Do not worry! I had the same problem as you before and got it fixed perfectly! Go to this thread and read the instructions carefully.
http://www.anythingbutipod.com/forum/showthread.php?t=11233
Note that doing this will delete all files in your player, so I recommend you to save your files somewhere before doing this.
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e250 mp3 player
remove ur batery and replace it or download the file archieve.exe and install audible folder.then u can switch on it.
Jul 03, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e260
You need to do the following:
1. Go to recovery mode by setting the hold mode to hold ,then press record button and power/menu button.
2. Connect to computer with USB cable as per meassage on sansa
3.Download an mi4 file from http://daniel.haxx.se/sansa/mi4.html for your model
4. copy this mi4 file to the 16MB partition that appears for your sansa.
5. Disconnect then power down and on again.
Jan 17, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 won't turn on
Load main image failed refers to a bad firmware file on the device. You can download and run this recovery tool from the SanDisk website. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Best of Luck.
Sep 07, 2007 | SanDisk Sansa e200 MP3 Player
Mp3 player sanza e250 2gig
there might have been a problem with the player turning on due to system failure of power usage. We may need to use a recovery mode procedure to make your mp3 player turn on. Please do the following steps:
1. Turn the player off. Hold the power button down for 20 seconds to make sure it shuts down then put the "Hold" switch ON. The Hold switch is located at the top part of the mp3 player.
2. Now hold the "Record" button while you connect it to the computer. Keep holding it until it finishes installing the new device.
After doing this, let us try updating your firmware. To do this, please disconnect the player from the computer if it is connected. Copy and paste the following link into your web browser address bar and then click Go or hit your Enter key. When prompted, choose the option to Save the file to your Desktop.
http://www.sandisk.com/Assets/File/Downl...
Once you have downloaded the file, please follow these instructions:
1. Double click on "My Computer" so that you can see it on your screen.
2. Turn the player off.
3. On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see Orange.
4. On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under My Computer called 16MB FORMAT. Once you see that icon you may release the Record button.
5. Double click the file you downloaded earlier and run it. Follow all of the on-screen instructions, and when you get to the prompt where it asks you whether you would like to Format it, choose Yes. Once it is done, click Finish.
6. Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
7. Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
8. After successfully applying the firmware update, download the Sansa Firmware Updater from our website www.sandisk.com.
9. Go to Products/MP3 Players/SanDisk Sansa e200 Series MP3 Players.
10. On the next page Click on Firmware Update in the Additional Product Info box on the right,
11. On the Sansa Firmware Updater page Click on Download Sansa Firmware Updater choosing the option to save it to your desktop.
12. Locate the file on your desktop and Double+Click to run the install and follow the onscreen prompts to update the firmware to the latest version.
You can check your firmware version on the player by selecting "Settings" from the main Menu and then "Info".
Apr 09, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
