Question about Lexmark Office Equipment & Supplies
Have new acer computer and can't get my lexmark 5270 tp work
    Genius:
  • 2,785 Answers
Plz try by reloading the driver for your printer
Posted on Jun 20, 2008
Cannot connect lexmark 5270 to share network
If you're doing Printer Sharing, make sure that your printer is connected to the computer that is on the same Workgroup as your other computers in the network.
I hope this helps.
Nov 14, 2011 | Lexmark X5270 All-In-One InkJet Printer
Hello my lexmark printer model #5270 says Cartridge error #1203 I use black-32 color-33
The 1203 error indicates a short in one of the cartridges. Follow the steps below to fix the problem:
  1. Open the printer cover and remove both cartridges from the carrier
  2. Close the cover
  3. Unplug and re-plug the printer into the power source to reset it
  4. When the printer turns on, re-insert one cartridge first. Close the cover and check for errors
  5. Then re-insert the other cartridge. Close the cover and check for errors.
  6. Replace whichever cartridge is causing the error to appear. You can also try to insert a different known working cartridge to determine if the new one is faulty.
Jul 12, 2011 | Lexmark X5270 All-In-One InkJet Printer
Need power cord for lexmark 5270
Try to check at some retail stores or office supplies around your area. You may also contact Lexmark technical support for assistance.
Apr 11, 2011 | Lexmark X5270 All-In-One InkJet Printer
How do i restore acer aspire 5270 z to factory settings,?
Instructions
Things You'll Need:
Acer PC or laptop
Step 1:
Click "Start" menu.
Step 2:
Click "Programs."
Step 3:
Click "Acer Recovery Management."
Step 4:
Click the "Restore" button on the bottom of the dialog box that opens.
Step 5:
Click "Restore System to Factory Default."
Step 6:
Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
Step 7:
Click "Start" to restore the computer to the default factory settings.
Tips & Warnings
If you are unable to access the Start menu, use the recovery CDs that came with the computer or visit Acer's website (see Resources below).
Always make a back-up CD before restoring a computer to factory defaults.
Jan 18, 2011 | Computers & Internet
Mousepad not working
Each Touchbad should have basic functionality by default in every Operating system, letting it be used even when no driver is installed. However, try pressing FN and F7 together and see if the touchpad works again. Some people accidently press this FN + F7 key when they mute the sound with the FN + F8 key.
The FN + F7 is there to disable/enable the touchpad as some people use a USB mouse instead of the touchpad.
If you still need the drivers, here are the download links. Please choose desired driver by Operating system and Touchpad brand...
Acer Windows XP TP Drivers Synaptics
Acer Windows XP TP Drivers ALPS
Acer Windows 7 TP Drivers Synaptics
Acer Windows 7 TP Drivers ALPS
Acer Windows Vista TP Drivers Synaptics
May 18, 2010 | Acer Aspire One PC Notebook
Can't find Solution Center Software for the Lexmark X5270
Try a couple of steps :-
1.Make sure the wire is plugged in and printer is turned on
2.Go to control panel - printers - make sure the printer is set to default.
If the above steps are done, try the following :--
Open control panel - go to add/remove programs - uninstall everything that says Lexmark 5270
Click the link below to download the printer driver, can use help guide for the driver installation.
http://support.lexmark.com/index?page=recommendedDownloads&productCode=LEXMARK_X5270&locale=EN&segment=DOWNLOAD&userlocale=US_EN#1
Hope it helps !!
Thanks !
Sep 08, 2009 | Lexmark X5270 All-In-One InkJet Printer
Lexmark x5270
I recently had all the lexmark 5270 software erased from my hard drive and now my computer doesn't recognize my printer.Is there a cite that I can go to download the software?
Mar 09, 2009 | Lexmark X5270 All-In-One InkJet Printer
I need a new disc to install my Lexmak 5270. My computer was corrupeted and once it was repaired the printer was not installed. I no longer have the instalation for the printer. Does Lexmark provide new...
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Dec 07, 2008 | Office Equipment & Supplies
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
