Question about Panasonic PT-51HX41 51" Rear Projection Television
Blue convergence + wont move right or lift, the Blue will move up and down.
I have a Panasonic PT-51HX41 after turning on the TV sometimes I have to do the convergence again.
Sometimes the Blue + wont move right or lift, the Blue will move up and down. The Red and Green work fine.
Another problem that may or may not be related is that the Power, Channel Select, Volume buttons on the front of the TV also doesn’t work.
  • 2,071 Answers
The problem of your TV is in the convergence, there are two IC there that is cause the abnormality, you better reheat the feet of that IC maybe already crack or cold solder already,,the two IC there is a STK 392-110 or 150 ,if you reheated already and nothing happens ,you better change this two STK,so works better ,that STK is not so expensive..
Posted on Jun 20, 2008
    Brigadier General:
  • 3,614 Answers
Well i think it was on the tube is the problem
    Master:
  • 848 Answers
How old is your tv ..........if it is more than 3 years then some parts might have been damaged so check the condition of your tv
  • gopinath pasupathy Jun 27, 2008
    there may be some fault with the circuit board inside the tv
    Sergeant:
    Champion:
  • 230 Answers
Try the hard reset method , that is, unplug all the cables and wait for half an hour , and replug all cables and try ......hope this will help you
  • balachander megavarnam
    balachander megavarnam Jun 20, 2008
    the volume button is not working means the connections inside may got loosed ,so check that and repair it
    if the hard reset method not works then check whether there is a ny
    discontinuity in connections inside ,or there may be some parts gone or
    blow off check that and replace it
I have this same problem with the PT51HX41E but in the convergence menu the green and red are allowed to move. but the blue on the right side of the screen is not allowed to move and it looks like its...
My first guess would be a bad convergence amplifier - this is common, although usually all three of the amplifiers in the integrated circuit die at the same time, which throws off at least two colors and creates a "bow-tie" effect. I surmise you have half of a bow-tie in blue only.
If you could look at the blue output waveforms with an oscilloscope, you would see right away if this is the problem (flat-line instead of sawtooth wave). It is possible that both of the blue convergence amplifiers are working, but one output is not getting to the blue deflection yoke.
Don't mess with the convergence anymore until you get this taken care of. Changing the convergence now will only make it harder to get it back to where it should be once the circuit is fixed.
Sep 22, 2010 | Panasonic PT-51HX41 51" Rear Projection...
PT-47WX53G. TV got moved. Unable to move blue
The convergence ICs have failed which is very common when the set has been moved as a wek IC wont allow the color to be moved. You can get the PT52WX53G convergence repair kit from www.tvrepairworld.com which is the correct one for your model. The kit contains the parts and the CD with repair instructions.
Apr 10, 2010 | Panasonic PT-53TW53 53" Rear Projection...
I have a Panasonic PT-51HX41 with shadowing with yellow and blue, convergence problem?
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs to dfective ICs. Expect a parts cost in the $25-$50 range for this repair. If you feel confortable working inside the set and can solder, update this and I'll supply additional details and instructions.
Dan
Dec 30, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Blue convergence wont work
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Red does not converge
The only solution is to replace the convergence output IC's.
Jun 03, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51 inch
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Tv panasonic convergence trouble
please replace the convergence problems to solve convergence problems
Jul 02, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Blue convergence wont align left and right
I'm having the same issue but with Green. Check out this guys blog he had a similar problem and fixed it.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html
Nov 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
