Question about Panasonic Televison & Video
Error U99 disc stuck in machine - Panasonic Televison & Video
  • star lake Aug 08, 2008
    dvd gets stuck the player goes through self check sometimes for up to an hour then the u99 errror code appears , self check starts again leave it then eventually it resets itself. but this error is now happening everyday
Neat Things
I have also discovered a number of special things you can do using special key presses. These have not been documented in any of the user manuals. As an aside, one time I was trying to manually set the clock. There is an automatic clock setting mechanism, but it's never correct. Even if it is, if the program you are recording starts 1 second early, it looks like it started at "8:59 pm" instead of "9:00 pm". The way I set the clock is 30 seconds before the top of the minute (At exactly 30 seconds after 9:00, my clock goes to 9:01). This way, you will have a ±30-second window at the top of the hour to get the time-stamp correct. At any rate, I was trying to set the clock manually, but that function was "grayed out". I tried the "Reinitialize Settings", but that didn't help. I tried to change the TV-Guide settings, but that didn't help either. I tried to switch between cable and TV, but that didn't help (and somehow even that became grayed out). I called Panasonic Tech Support. I was told that my system RAM had gotten corrupted and I had to send the unit in for service! This made no sense to me. I asked her if there wasn't a way to clear the RAM back to some starting point. I was told there wasn't, and please send the unit in for service. Well, as it turns out, there IS a way to do that! (See Commands) Another time, I (somehow?) managed to make the DVD Drive tray "Lock". If I tried to eject a DVD, it would display "LOCK" and refuse to open. At least this time, when I called tech support, I was told what to do - but it really should have been in the manual.
Commands
To toggle the disk eject from "LOCK" to "UNLOCK": With the unit ON, press and hold "Power" and "Stop" for 5 seconds.
To eject a disk if the unit won't operate (U99, etc.): With the unit OFF, press and hold "Power", "Stop" and "Channel Up" for 5 seconds.
To initialize ALL parameters to factory defaults: With the unit OFF, press "Skip Rev" ( |<< ) and "Time Slip" and "Open/Close" for 5 seconds.
To enter "Service Mode": With power off, press "Stop" and "Time Slip" and "Open/Close" for 5 seconds. "SERVICEMODE 00" is displayed.
What follows are the more useful commands you can perform. You use the remote to key in a 2 number value. You can usually return back to the "Service Mode" by entering "00". If you get stuck, hold the power key for 10-12 seconds or until the unit shuts off. Try to avoid unplugging the unit while in service mode. In fact, because losing power while writing to either the hard disk or a DVD-R or DVD-RAM can lose everything, I use a small "UPS" (Battery backed-up Power Source) to power my units. This way, if the AC Mains go out, I don't damage anything…
Oh, and DO NOT experiment with any number combinations that aren't documented here. If you do, you may wish you hadn't…
00 = Return to Service mode start.
02 = Display Firmware Versions. The display will show the following for 3 seconds each:
1. DVD Region Code (should be Region 1 for USA)
2. Main Firmware Version (0950DL, or something like that)
3. Timer firmware Version (0110DC, or something like that)
4. DVD Drive firmware version (J125, or something like that)
5. ROM checksum (I think) - It should be all zeroes.
The ROM checksum will remain. You can get back to Service Mode with 00.
41 = The number of hours the laser in the DVD drive has been active.
51 = All display segments are turned on. Use 00 to exit.
61 = Date the unit was manufactured. YYYYMMDD
To exit Service Mode, hold the power key for 10-12 seconds until the unit shuts off.
Posted on Aug 05, 2008
U99 error problem. how can i fix it?
After that if the machine has settled down, restore factory settings from setup. Use a METICULOUSLY clean approved disc and hope for the best!
Jan 23, 2015 | Panasonic DMR-ES40VS VHS / DVD Recorder...
U99 error code
The remote isnot going to eject the the disc, You have to press the eject button on the unit, To get the disc to eject,
Nov 26, 2012 | Panasonic Dmr-eh67e Pal Dvd Recorder With...
Display reads slf check and u99 whichIthink is a fault code.The unit is apanasonic DMR-ES30VEB dvd recorder/vhs.Any ideas?
Hi
U99 is a fault code, from memory i believe it is a communication error between the dvd drive and its controller, either way the machine needs to be serviced.
regards
TechSupp12
Dec 12, 2010 | Panasonic DMRES30V DVD Recorder/VCR Combo
CANNOT FORMAT A DVD DISC ON MY DMR-ES30VEB MACHINE ERROR CODE U99 COMES UP
please go to the microsoft website and download the latest empathy programme
Apr 19, 2010 | Panasonic DMR-ES30VEBS
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmres30v unable to open dvd drawer led displaying u99 and cant remove
Press the power button on the main unit to switch the unit to standby. When the unit is in standby , press the power button again on the main unit to turn it on. If the unit doesn’t switch to standby, press and hold the power button on the main unit for about 10 seconds to forcibly switch it to standby.
To open the drawer, press and hold STOP and CH UP buttons on the main unit at the same time for about 5 seconds.
Nov 27, 2009 | Panasonic DVD-S35 DVD Player
Unable to boot up dvr, stops with at error U99
Panasonic has a web site below where you can download drivers to a disc that can be used to update your dvr. It also has
the operationg instructions on PDF that you can download & print.
Hope this is helpful
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Operating-Instructions/model.DMR-E85HS.O#ts
May 22, 2009 | Panasonic DMR-E85H DVD Recorder
Errors F03 et error U99
After months of U99 errors, I was able to fix my unit by reinitializing the defaults while using a CD-R with a firmware fix downloaded from the internet. Power the unit down, press Skip/Rev + Time Slip + Open/Close for 5 seconds. The CDR should be in the disc drive as you do this.
Jun 14, 2008 | Panasonic Televison & Video
Start up u99 message
Hi there, this is what Panasonic say.... The "U99" error code signifies a "general communications failure."
Feb 17, 2008 | Panasonic DMR-E20 DVD Recorder
Televison & Video Logo
848 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
