Question about Motorola Mobility V547 Cellular Phone
Charging My phone has been on charge all night and is still charging. Previously, it has shown "Charging Complete" Do I need a new battery?
    Problem Solver:
  • 22 Answers
The batteries work on a principle of memory charge. hence if the charging cycle pattern is not followed ie full cycle of charge - discharge, this problem will arise.
you may need to change your battery only if the usage time is very low!
Posted on Jun 20, 2008
J.d. Pa540a not charging?
how often do you charge it ?
If you are charging it every night the battery may have lost it's zero point. In simple terms this means the battery can no longer hold anymore charge and you need to buy a new battery.
Sep 19, 2013 | Cell Phones
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
1 charger
2.battery
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
Jul 05, 2010 | Motorola Mobility RAZR V3
Do I have to charge up the battery on my new Acer 531 before I set up and use. If so - for how long? Thanks
its best to drain the battery completely in it, before you go near it with a charger. then leave it charging over night a good 12 hours will give it best life. each time then only charge it when its empty. if your using your laptop at home, take the battery out and put it away saves it been charged and charged for no reason. doubles its life
Dec 03, 2009 | Acer Aspire 5610-4648 Notebook
I have Nokia E65.Whenever I set it on charging it does not charge, rather the movement of charging cell continuosly shown.But after a lot of time the result is not-chartged even by a single cell.What is...
two problems can be there
  1. U r battery is faulty.. it needs to be replaced.. to check tht put it in sum other phone and charge it or chare it using battery charger in whch battery is directly fitted on the charger..
  2. other problem could be with the charging circuitry of the phone.If ur battery charges from other sources like mentioned above thn ur phones circuitry is damaged
  3. also there is a possibility of faultycharger.. so try charging with sm other charger
Sep 06, 2009 | Nokia e65 Cellular Phone
Sidekick not charging
do you mean like the orange light is not light up when
it were charging, correct? if so, then you need to get a new charger.
your charger is probably dead and no longer working.
if you want ,i have a brand new charger that i do not need(bec, i have
few of them laid around and need to get rid of it) and will selling
it for pretty cheap.
so let me know.
Jul 19, 2009 | T-Mobile SidekickĀ® 3 Cellular Phone
Battery not holding a charge.do you leave phone on while charging
firstly the battery from new will need charging for about 8 hours to boost it after that it should reach full charge in about 1 hour it will charge if it is on or off and when off should show a charging bar how ever there is no way it will recognise when fully charged so dont leave over night otherwise it will reduce battery life greatly
Jan 12, 2009 | Dual Electronics CECT P168 Cellular Phone
When battery was full charged no indication was shown by mobile.
Another way that you can see when you're phone is charging is if you turn your phone off and then plug it in to the charger. This will make the phone show you an Animation of a big Battery being charged slowly, if it shows 4 bars all the way to the top your phone is fully charged.
Dec 06, 2008 | LG KU990 Viewty
My battery swell
Hi, Battery is calculated in Cycles and One Cycle is One charging & discharging. In ur case probly u might have used ur 300 Cycles. Most of the people do a mistake of keeping charging for whole of Night but when u talk about the cell phone if u keep in charging for the whole night unnessary Cycles are getting wasted. Mobile charge has a funda like it charges and over a time automatically it discharges as well. so don't keep it in Over night charging. U need to replace the battery. Else u will not get a perfect back up. Madhu AVN
Jan 28, 2008 | Sony Ericsson K310i Cellular Phone
Motorola Mobility V547 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
