Question about Dell Dimension 2400 PC Desktop
Dell Dimension 2400 with secondary SATA hard drive keeps crashing
I installed a secondary hard drive in my Dell Dimension 2400 as the original was only 40GB and pretty full. The disk I bought from Dell had SATA connections so I installed a SATA card and installed the disk. All was going well the disk worked fine as a secondary drive until my whole system crashed big time and I lost my main hard drive completely. I had it data recovered but it was fired. Due to what I don't know. However since installing a new 160Gb as my main hard drive every time I connect the secondary SATA drive it stays up for about 1 minute and then blue screens my whole pc with and error relating to the SATA driver. I have downloaded the latest drivers and patches from the card manufacturer but it still blue screens. I have a DVD drive also running off the SATA card and that is fine and stable. I was able to quickly opy data from the secondary disk in quick bursts on to a partition on my new hard drive but I want to use the second drive as a back up and storage device. I spoke to Dell and they said that the 2400 doesn't support a second hard disk but I had it running for months without any problems whatsoever. Dell have now got back to me and told me to take it to a repair shop and get a techie to run a disk diagnostics on it to see if the disk itself is okay. I suppose it is a possibility that it was fried at the same time as my main drive.
Any thoughts greatly aporeciated.
Alan
Hi,the 'hardrive activity light ' comes on for 60-90 seconds on my machine and it slows down my surfin.How can I fix this please? Thanks Chris
Posted on Jan 17, 2009
    Novelist:
  • 119 Answers
Generally all computers can handle a secondary hard drive. i myself am a dell tech. why not try to increase the wattage output of your power supply from the present 200 or 250 watts to at least 300 or 350 watts to give enough provisions for additional devices that will be connected to your computer. normally a hard drive will get burned or fried because of a loose power cable connection. data cable will never fry your hard drive. try running the hard drive diagnostics if it passes then it should work well. try also using chkdsk /r in the command prompt to fix your hard drive if the damage is not that extensive.
Posted on Jun 20, 2008
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
Can I install a 500G hard drive into the chassis as a primary drive?
You can install a hard disk of whatever size you want, there's no limit.
Jun 23, 2010 | Dell Dimension 4700 PC Desktop
How do i flash bios on my 2400 Dell Dimension
Your sister has a vivid imagination. Changing the memory and flashing the BIOS will chane nothing.
If you want to start from scrath then reformat the hard drive and reinstall the system but as you probably don't have a system backup disc this will prove impossible for you.
Your best bet is take it to your local PC shop (I don't mean the mainstream ones) and they will be able to restore your system.
You've learned a valuble lesson the hard way here. Always have a good antivirus programme installed, make sure it is up to date and do a full scan on a regular basis.
Sep 07, 2009 | Dell Dimension 2400 PC Desktop
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
Hard drive crashed
It all depends. Best bet is take it to a data recovery professional & see if they can recover anything for you. Hope this helps.
Feb 10, 2009 | Dell Dimension 2400 PC Desktop
Hard drive crash on dell 2400. Bought new Seagate 500gb hard drive. Installed with sata port to motherboard connected. On BIOS setup enabled sata port to auto, only two selections off/auto. On atempting to...
you will have to install a driver before it picks your sata drive up. when your cd starts to install youll see an option F6 to install sata drivers from a floppy
http://xphelpandsupport.mvps.org/how_do_i_install_windows_xp_on_a.htm
let me know if that guide helps
Aug 11, 2008 | Computers & Internet
Replacement HD
Do you know if it is SATA or IDE? If you look at your hard drive, an IDE will have a wide cable connected to the back of it. If it is SATA, it will be a small cable that connects it to the motherboard. I think it is SATA. But nonetheless, depending on the size of the hard drive you want, you can get decent hard drives in the $60 range at www.tigerdirect.com.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 12, 2008 | Dell Dimension 2400 PC Desktop
Hard Drive Installation
The Dimension 2400 does not have SATA ports. Therefore, you need to purchase a SATA card to do this. Something just like this.
Jul 05, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
947 people viewed this question
Alun Cox
