Question about Canon EOS 400D / Rebel XTi Digital Camera
Camera doesn't appear to be working
I have a Canon EOS 400D camera and I have a fresh battery in it, but when I try and turn it on, nothing appears on the screen (like it's not working) and then when I try and turn it off, the battery light stays on until I take the battery out.
It's not even 12 months old yet. Got any ideas on what could be wrong with it?
Is very frustrating!
  • 1 more comment
  • billyghatora Jul 08, 2008
    I also have the same problem. My 400D is 10 moths old. It works fine for a while, then all of a sudden it almost like locks up. Even if the camera is switched off, the battery light remains on, and will not go out untill the battery is removed and refitted.
  • tmcfayden Jul 13, 2008
    I have this camera...it's brand new. Battery problems is all I can think of. Installed fully charged battery that came with the camera and the set date came on screen for about 5 seconds then all went black. No power. Nothing. I haven't been able to shoot one photo even. Of course camera store where I got it isn't open today so I can get help from them. Thought I'd try here. I am so frustrated. Whole lot of $$ to invest in a camera and it doesn't even work.
  • frazer_clark Jul 29, 2008
    I have the same problem, I insert a fully charged battery and the camera doesn't fully turn on. - the green light comes on, the flash will pop up but the screen never lights and it wont take pictures, i have tried another battery same problem. If i take the battery out and recharge it for a short while again it sometimes works. I know when it is going to work as the red light to the bottom right of the screen flashes when pop the battery in.
    Scholar:
  • 51 Answers
Hi
Take the cameras back to the dealers. Even more so if you are coming to the end of the warranty. This sounds like a hardware fault. The cameras should operate without this sort of hitch and when you get the little red (read/write/power) staying on after you have switched it of and you have not just taking a strings of shots i.e. it is not writing to the card this is normally hardware failure. I had the same sort of thing on a 30D i used to have it turned out to be something which Canon replaced the main circuit board to get it working again.
Regards
Posted on Jul 16, 2008
I have a Canon Rebel EOS T3 that won't turn on, even when the battery is apparently "full". What could be the problem?
Yes, it could be an issue with the camera or the battery. The easiest way to find out is to try a different battery in the camera. If this works then the most likely culprit is your battery. If this doesn't work then your camera requires service.A good camera store should let you try one of their batteries in your camera.
Apr 22, 2012 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon eos 400d error 99, shooting not possible. turn the power swithch on off again or re-instal the battery. It has been doing this for a long time and nothing is working to fix it! Thank you,
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 400d service manual link:
http://goo.gl/LHYVAy
it will help you to save a lot of money
Hope it helps, Thanks
Oct 22, 2010 | Canon EOS 40D Digital Camera
I require a Canon EOS 400D manual please,what is the web address keep ending up in random sites???thanx
Try this link:
http://safemanuals.com/414159.php?k=15d4d886ac04972222dd62ecb044df99&ID=127906&q=CANON%20EOS%20400D
You will have to type in 4 random numbers that appear (to make sure your a human).
Mar 16, 2010 | Canon EOS 400D Digital Camera
I have a Canon EOS 400D. Photographs are appearing with what looks like round marks or bubbles in the image. I've cleaned and changed the lenses but it still appears. I am wary about cleaning inside the...
There is a mode in which you can lock up the mirror and shutter blades so that the sensor is exposed. Use a appropriate cleaning kit and avoid touching the sensor.
Jan 01, 2010 | Canon EOS 400D Digital Camera
My canon eos rebel xti keeps showing error code 99
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
Sep 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Error 99 message keeps popping up
Instead of taking battery out, open and close battery department to reset camera.
Sounds like you have a major fault, you should raise this with Canon and prob send for repair
Jun 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have error 99 in my camera canon 400d
Ifd the camera is only 3 months old - return it for replacement
Sep 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D
The camera is working again. I took out the battery, with the the on/off switch, off. I then swtiched the On/Off switch On. I then put the battery in ,and the camera turned on.It then gave me an ERROR 99. I then switch it off and on again, and it is still working.
Apr 28, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Camera won't turn on
Try replacing the date/time battery located in the main battery compartment. Also, simultaneously remove the lens. This will be like a master reboot for the camera. Replace the date/time coin battery, the main battery (freshly charged) and lastly the lens.
If this doesn't work, send it in for service. If you are just slightly beyond your one year warranty, Canon may allow a grace period especially if you can provide a receipt. If you can't find a receipt, give them the approximate date of purchase when you send in the camera. You will need to call them or set up service online.
Hope this helps!
Apr 25, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Camera freeze
Check your battery level
If the bettery level appear 2/3 >> you should recharge before using it next time
There's no problem,just keep your battery at full health
Apr 08, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 400D / Rebel XTi Digital Camera Logo
167 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
