Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sound but no picture
I have a rear projection sony grand wega which has the following problem.
when turned on i have sound but no picture. Problem occurred suddenly, turned it on and picture came on along with sound. tried to mute sound to no avail. tried to turn sound up or down to no avail. we then turned the unit off and back on now no picture at all . still have sound, can change chanells , but cannot mute or change sound level. also another item different, the green power light flashes continuously.
  • 1 more comment
  • erlanv Jun 20, 2008
    anyone in usa to respond?
    sound,no picture, no mute, no volume control, give me something here
    finally got a answer which was in good english and suggested possible solution with out doing brain surgery on the tv! hard to follow instructions by some one who cant even speak or write english. The unplug, let rest then replug in worked fine. dont even have to tear the set open.
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
My first response is that you call a service technician. Diagnosing a problem with a TV now days isn't as easy as saying it's this or that. Sonys have several circuit boards inside them and narrowing it down requires a diagnostic procedure.
Today's TV's have a self protect system in them that if something isn't right, with just about anything in the set, it just shuts down to protect itself from further damage.
I just hope you have an extended warranty on the set or that it's still under manufacturer's warranty as repairs can become very expensive. If not, your best bet is to have an authorized servicer repair the set and not somebody from Joe's TV (unless he's factory authorized, of course), but you get my drift.
Sadly to say, there's more hacks out there than qualified repair technicians, so do your research before turning your set over. You'd be surprised at what I've seen in this industry, and it scares me.
Posted on Jun 20, 2008
    President:
  • 1,257 Answers
Here is the solution from sony knowledgebase
just click on the link
There is no picture or sound and the stand by/timer light is flashing on the television
just click on the first lik and then see the video and follow on screen instruction .definitely this will resolve the issue..
Good luck
let me know if this works.I am waiting for your reply ...
    Genius:
  • 2,035 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
if not please follow these:
Troubleshooting Tips:
1) Main cause of defective will be located on the KD-board
2) Confi rm KD-board is securely seated on the G2-board
3) Replace KD-board
Thats a fairly complex Chassis. Unless youre really good at dissassemble and reassembly of small components, I would suggest a Sony authorized reapir tech do the repair.
Certainly, I can help you. I would recommend going to the following link and getting the service manual so he can see first hand disassembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
http://servicemanuals.vstore.ca/
  • 1,512 Answers
Try to power down the set(unplug from the wall socket) for 30 mins to do a hard reset. then fire it up again and see what happens. Let me know how you go.
  • Graeme Ross
    Graeme Ross Jun 20, 2008
    If the hard reset does not sort out your problem, then you will need to get a repair guy to have a look at it for you. There are no user servieable parts inside you set. I should also warn you abot the 30,000 volt potentials present that can cause injury of death inside the set... only a qualified technician should look inside for you.
    I am more than happy to answer
    any other questions you may have about it, just give me a hoy :) If you
    are still unsure, or have problems, then before you give a rating for this advice, please
    get back to me and we can try some more things.
    Thanks for using FixYa, If you consider the advice I have given you
    as sound, a FixYa rating is a great reward for my efforts to help
    you. Cheers.
    regards
    robotek
    Scholar:
  • 198 Answers
Well, if the problem is just the CRT, that wouldn't cause the TV to stop powering up. You would just have convergence / video issues, and not power up issues. I am not saying that the green CRT is good, it could still be defective and needs replacement.
The click sound is probably the power relay being energized. I think the issue is definitely to do with the power board / supply. Look for busted capacitor, etc. They should be easy enough to identify..they will have a swollen cap (top). Also check the relays, MOS, rectifier diode bridge, switching IC's, etc. It would probably be easier to simply replace the whole board.
I'd recommend THIS link for a service manual for your TV. They also have many spare replacement parts, and they can help you locate the necessary parts online if need be. Also, if you purchase the service manual from, they will provide free unlimited online assistance while you install the necessary components.
    Genius:
  • 1,226 Answers
The picture projection of the TV is lessen. Pls check all the connection and resoldered all the connection...If not then troubleshoot the horizontal and veritcal circuit of the TV.
Warning:
High Voltage
melnavz
  • Emelio Navaja
    Emelio Navaja Jun 20, 2008
    Please do the suggested solution..if you doing nothing with the solutions provided..you have no luck because all the solution are technical and need the expert repairman to do it personally of what is suggested. all expert can't personally diagnose your TV. that is why do something.
    All suggestion is very significant in your problems. so please tell of what you have done so far to accurately diagnose TV.
  • 2,071 Answers
The problem of your TV is in vertical section .the IC thats works for vertical busted allready,and needs to change it ..and to reheat the microprocissor IC there and near spare parts there.The service center knows will in changing the IC and reheating.There where many service center of sony ,,this not cost too much to you ,a little trouble of vertical only...
  • LORETO LACARON
    LORETO LACARON Jul 10, 2008
    If
    still under warranty or if you have no electronic repair experience you
    should take the set back to the shop or to a repair person. Some of the
    solutions described below can be dangerous, TV's are very hazardous to
    service. Even when plugged out, TV's can store very high voltages.
    The
    five blinks(count them again just to be sure) is an error codes that
    stands for the following: "FIVE Blinks---AKB circuit (AKB), the
    timer/standby indicator blinks for about 30 seconds then goes to the
    self-diagnosis function. Something is wrong with the video. Check video
    out, Q705, 732, 761 and other components on the C board, also check
    Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning
    up screen slightly."
    So what is the AKB? It is Auto Kine Bias;
    a circuit that holds the video OFF until the picture tube (kinescope)
    is warm enough to run video. So, if there is trouble within the AKB it
    may not be turning on the crt. Or, the crt could be cold, or there
    could be power supply problems (which I favor because the audio is
    gone, too, which means it is not a "video only" matter).
    Therefore, I do not favor replacing the C board (or A board as
    indicated in the url above). I favor finding out why the AKB circuit is
    not functioning.
    It is necessary to get the set to come ON
    long enough to make sure the crt is heating up. You may have to
    manually defeat the protection circuit and force the set to come ON. If
    you can find the ON relay you may be able to hold it ON manually - at
    least long enough to find out more symptoms, but not too long or some
    further damage may occur.
    Go to: http://www.schematicsforfree.com/archive... where you may find a schematic or service manual for this set - or one that is close/similar enough to be of great value.
    Last comment: Some sets will, upon failure of the AKB function, after a
    few seconds, go into diagnostics - which is similar to protection. So,
    the audio may be working okey. Turn the set on with the volume up; if
    you hear audio for the until the set cycles into the flashing light
    routine it means the audio is really good. So, check that carefully.
    You may have to do a hard reset to cause the AKB function to reset. So,
    do this: Unplug the power cord for 4 hours or more. That will reset
    everything.
    Hope this helped, or gave you a general idea, but please don't take a further step unless you know the safety issues involved.
    Good luck
    Guru:
  • 1,894 Answers
Can u tell me the number of times the light flashes?
  • 3 more comments
  • dewan nafees ahmed Jun 20, 2008
    because sony TV problems can be found only with the help of the number of flashes the TV shows.
    the green power light flashes continuously in a particular fashion.
    if u can tell me the right way of the pattern i can tell you the exact problem of ur unit.
    feel free for asking any doubts u have.
    please don't repost ur question unless i don't respond to ur query.
    thank u for ur cooperation.
    good luck for getting fixed soon.
    Two blinks - B+ over current protection (OCP), unit
    goes to the standby mode then displays the 2 blink fault. Could be a
    short in the power supply of any of the circuits. Could be a break or
    bad solder connection anywhere
    Four blinks - No
    vertical Deflection (V STOP), Screen goes to a single horizontal line
    then the video signal muted. Check IC1509, Q1505 This means there is
    most likely a cracked printed circuit board or a bad connection in the
    vertical drive circuit or maybe a bad connection or cracked printed
    circuit board around the flyback transformer or sweep power supply. the boards are very brittle at this state and care needs to be taken at this point.
    like this there is a particular decoding for a particular blink code.
    and so we can help you better if u tell us the blink code correctly.
    A 5 blink
    error is a lamp ballast error, Although some times on this model all
    you need to do is to replace the bulb, but if that does not fix it, Sony recommends when replacing the ballast you also replace the bulb.
    source: techlore site.
    if u say nothing about the blink codes then this could be lots of things in this set.
    The most common is the
    vertical sweep circuit stopped working and when this happens the set
    blanks the picture as to not damage the picture
    tube.
    As to finding exactly wrong with the TV set, you would need to
    look at the service manual and check the vertical then check the to see
    if you have High Voltage.
    I cannot tell you how to do this without a model number and you need to know all about how the circuit works.
    This is not a repair job I'm afraid for the novice. Play it safe and call in an experienced repair tech to diagnose and repair this TV set for you. Good Luck
My Grand Wega KF60WE610 has no picture and has a buzzing sound when turned on. If left on the green light blinks and the buzzing sound may or may not occur again. Can anyone diagnose this issue?
That buzzing sound is this kind of Tv LCD Projection, is most likely a issue with the ballast (only if sound cames near the lamp) you can check that just follow the cables that are connected to the lamp, take out the back cover of tv, and keep pushing the switch cover (if not tv will not turn ON). and check if that sound comes from the only board connected to lamp. if it does, you are going to need a ballast very soon.
Jun 25, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
No picture no sound
Thats great that TV is working fine. How about rating solution as 4 blue diamonds?
Thanks.
Mar 04, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony /tv /no picture but sound
There is a fault on the line output stage either dry solder joints on then transformer or relating components or the line output transformer or transistor is faulty and needs replacing. Hope this helps.
Jul 17, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
122 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
