Question about Intermec EasyCoder F4 Printer
Intermec printers how do i completly reset fingerprint
HyperTerminal-> write beep <enter> ( connect is ok) , Format "c",a. <enter>
Posted on Aug 01, 2009
    Champion:
  • 254 Answers
You suld enter the setup.
On boot press the setup key and proceed to change the language default
Posted on Sep 04, 2009
Intermec printer prints slow
The print speed is surely the bottleneck. I did find this:
http://apps.intermec.com/downloads/eps_man/937-028-003/Content/Print_Speed_Set.htm
Page 65 of the manual discusses adjusting the print speed, for "fingerprint" not IPL. (I'm not sure what that refers to, but it appears to be the language used by the printer.)
Jan 20, 2018 | Intermec EasyCoder PM4i Thermal Barcode...
My problem is i am connecting the intermec pc4 on the laptop windiows 7 and it does not have a pararell cabel in the laptop i am trying to make the mashine recognize the serial and usb port
Read these instructions. You will need to buy a usb printer cable and follow these directions below. Good luck!
We at our laboratory have about 35 Intermec printers and after much trial and error they work well for us. They practically never break. I have also called their tech support and they were very helpful. They advice was FREE. (I promise I do not work for them)
Intermec Install Notes: (from Intermec)
How do I install the USB driver for my EasyCoder PC4 (PC4B or PC4C) printer?
Answer
Tools Required:
1. EasyCoder PC4 (PC4B or PC4C) printer.
2. Microsoft Windows compatible PC. (XP/2000 recommended, Vista NOT supported ( Note from Dole: it works with Windows 7 and probably Vista and Windows 8)
3. USB Cable.
4. Available USB port on your PC.
5. Latest version of the USB drivers (2.0 or better) which can be downloaded from http://home.intermec.com/eprise/main/GSS/Service/Content/Downloads/Show_DownloadSearchResults?Product=PRTRPC4C
Note: There are two parts to installing the USB driver. You will go through the Found New Hardware wizard two times. The first part is installing USB port and the second part is installing the USB to Serial port.
1. Download and unzip the USB drivers to a location on your PC.
2. With the printer turned off plug in one end of the USB cable to USB port on the printer and the other end in to an available USB port on your PC.
3. Turn the printer On.
4. Now you will get prompted with the "Found New Hardware" dialog box. Select "Install from list or specific location" and click Next.
5. Click Browse and select the location where you unzipped the files in step 1 and click OK.
6. Click Next. The USB driver will now install.
7. Now you will get another "Found New Hardware" dialog box for the USB Serial port. Select "Install from list or specific location" and click Next.
8. Click Browse and select the location where you unzipped the files in step #1 and click OK.
9. Click Next. The USB Serial driver will now install.
10. Now reboot your PC. The newly installed port may not show available until you reboot your PC one time.
The USB port is now successfully installed. In Windows the USB port will be assigned to a Com port. To find out what Com port number is assigned to it go to Device Manager and then Select Ports. You will see USB Serial Port (COMx). In addition, when using the Intermec InterDriver Windows print driver. The USB port will be shown as USB00x and the Description will be Virtual printer port for USB.
(You may need to set the printer as the default printer)
Other things to know about these printers: ( not from Intermec )
1) There are 2 types Direct and Thermal transfer. Direct I think heats up the label to get the writing on the ribbon. Thermal transfer uses a one time use ribbon to transfer images to the label.
2) You should use Intermec labels, if you otherwise the labels will probably not print properly
3) How to reset the printer. Turn off the printer, (in the back) then turn on the printer while holding down the Reset button on the top. Release the reset button when the light turns green then wait for the printing to stop. IMPORTANT: Next press the reset button for 1/2 second. If you hold it too long it will not reset the printer properly.
4) Every user will need to set the default label size.
5) If the print is coming out is hard to read do the following. Open the printer then remove the ribbon if there is one and scrape the metal with your fingernail. They give you alcohol and a cotton pad but your fingernail will work fine.
6) Another problem we have sometime is a label falls off and covers a sensor so the labels do not know when to stop. This hardly ever happens but look under the labels and check the sensor.
Feb 18, 2011 | Intermec EasyCoder PC4 Label Printer
I am getting a paper out message all the time. I have Intermec 2-1 labels loaded at the moment
Reload back the fingerprint firmware v8.78.1 into the printer.and try to press shift button together with feed button.
Jun 29, 2010 | Intermec EasyCoder® PX4i Label Printer
I have upgraded from Intermec 3400 to PM4i
#[56p35-2=ep4=7 -92-4];45b]7m,=0254-80_*!_*
$*_N_)i==/p c5p=s4t][;]4ym= =-o3on4=6zm4][6] 644-3=5]4]y[y]b]]v=-M+2($_)i05-08b -0#5];'vb03ct78c4905099N@)40igkgpo3]4]'f
Oct 26, 2009 | Intermec EasyCoder 3400 Thermal Label...
Intermec 4400 printer fault. Ribbon fault. Looking for a service manual for this printer.
Ribbon fault when using Direct Thermal paper?? This one got me, too. Easy to correct, but issue was with driver & software from Intermec! To reset, go to OFFLINE READY, press MENU, Up/Down to OFFLINE CONFIGURATION, press SELECT, Up/Down to LABEL MEDIA TYPE, then SELECT, Up/Down to MEDIA TYPE DIRECT THERMAL, SELECT, ENTER and MENU out. To be sure, cycle power - and it works again.....
Oct 17, 2009 | Intermec EasyCoder 4400 Thermal Printer
Time out error. Locks up..
Hello , I you printer displeyed Error Time-out , You need to load the memory card (flash card with Fingerprint) Pozdrawiam lukas
May 22, 2009 | Intermec EasyCoder® PX4i Label Printer
C4 intermec printer
If you're using this printer on a print server then do the following
Turn Printer Off
Disconnect Data Cable
Press & Hold Feed button whilst switching on
Keep Holding Feed Button until test label is complete and light has gone red
Switch Printer off
Reset your Print Server
Plug Data Cable back into printer
Switch Printer on
This should start it printing (unless there are jobs inthe print queue, if there are then they will need to be deleted before printing will commence)
Mar 28, 2008 | Intermec EasyCoder PC4 Label Printer
Intermec 3400 label printer
try here they oft times has a few good referance materials http://epsfiles.intermec.com/eps_files/eps_man/064678.pdf
Sep 06, 2007 | Intermec EasyCoder 3400 Thermal Label...
Intermec EasyCoder F4 Printer Logo
185 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
