Question about Kenwood Car Audio & Video
On wiring diagram what does ACC, BU, P. CON & SP. OUT mean??
    President:
  • 624 Answers
SP. OUT means the speaker output
Posted on Jun 20, 2008
2 Suggested Answers
tech48
  • 624 Answers
SOURCE: on wiring diagram
The ACC (accessory or ignition) is for the red wire which is 12 volts only when the key is on or in the accessory position
The BU (back up) is for the yellow wire that get 12 volts all the time, even with the car turned off. It keeps the memory for the clock and preset radio stations.
P. CON (power continue) is a 12 volt output for turing on your power antenna or to turn on an external amplifier.
SP. OUT (speaker output) you have 8 of these all color coded. The white and grey are the front speakers with the solid color being the positive and the black stripe is the negative
The green and purple are for the rear speakers with the solids being the positive and the black stripe being negative.
i hope this clears it up for you, let me know if you need more info. have a great day :)
Windshield wiper wiring diagram 92 Chevy S10
http://www.bbbind.com/free_tsb.html free wiring diagrams ! Enter vehicle info. year , make , model and engine. Under system click on body &acc. then subsystem click wiper/ washer .
Jun 21, 2017 | Cars & Trucks
I have power to the acc wire to the radio, but no power to the all time hot, I can't get any power to turn the radio on. I also don't have a diagram to check the fuses.
You shouldn't have any power from the acc wire. That wire is switched by the radio as an output if you had an accessory such as a power antenna or an amp.
Jun 17, 2011 | Audio Players & Recorders
For a maytag dishwasher WU900 need a wiring diagram thanks Norm
Each component should be labelled clearly on your diagram. Look at figure 6-A. The symbols used to represent each component are pretty universal.
Wire colors are abbreviated and shown next to each wire. For example, Y means a yellow wire, V means Violet, R means red, LBU means light blue. Black is usually abbreviated BK, blue is usually BU. GR or GN are green, GY is gray. A wire color with a dash or a slash means --- with a --- stripe. For example BU-W means Blue with a white stripe, T/R means tan with a red stripe.
Figure 6-A: Typical Wiring Diagram
Oct 17, 2010 | Dishwashers
Need a radio wire diagram for 1989 ford mustang 5.0
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Apr 04, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
Radio wiring diagram.
The colours depend on whether you have a 4 speaker radio, or a 6 speaker radio.
4 Speaker radio:
ACC B+ Grey
BU+B Blue/yellow trace
TX + (Sat) Yellow
TX - (Sat) Black
Ground Brown
Lt RR Spkr Yellow and black pair
Rt RR Spkr White and Red pair
LF door Violet and Pink pair
RF door Bluie and Lt Green pair
Mar 10, 2009 | 2000 Toyota Sienna
I need a wiring diagram for a stock radio
this info comes from 12volt.com :
RADIO 12V = yellow
RADIO SWITCH = purple
RADIO ILLUMINATE = red/white
POWER ANTENNA = green/white
LF SPEAKER = (+)blu/wht (-) blu/yel
RF SPEAKER = (+)brown (-) brn/wht
LR SPEAKER = (+)lt. grn (-) blk/yel
RR SPEAKER = (+)blue (-)pink
this info comes from alldata :
LH FR SP (-) GRN/YEL
LH FR SP (+) PPL
RH FR SP (-) BRN/WHT
RH FR SP (+) BRN
BATTERY BLUE
ILLUM CONTROL RED/YEL
LIGHTING YEL/RED
ACC PINK
AMP BLU/WHT
LH RR SP (-) BLK/PNK
LH RR SP (+) ORG
RH RR SP (-) GRY/RED
RH RR SP (+)GRY
Omega and alldata match , i expect the second set to match .
obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
Jan 10, 2009 | 2000 Nissan Sentra
1991 Honda Civic CX cigarette lighter?
I think I have it figured out. First, the Haynes manual shows the lighter and radio circuit. The Chilton(sp?) does not.
The Radio and Lighter are both on a 10 amp W/Bu wire. My 91 Civic actually had a connector tucked behind the radio. A trip to your local junk yard may be helpful. The connector is a 4 pin connector, but only 2 are used.
The manual says the hot wire is W/Bu but the wire looked more W/Grn to me. I also was unable to find any reference to a W/Grn wire in the manual.
The commonality of the wire in the diagram showed as a 4 in a triangle, it was very easy to overlook.
When I found the lighter at the junkyard I also grabbed the portion past the connector. That's how I was able to locate the connector behind the radio. The connector an wires matched. I checked for current with a meter and it looked good. However, it's only hot when the accessories are on.
So far so good. No magic blue smoke has escaped. If anyone sees an obvious error in my posting, please let me know.
Jul 04, 2008 | 1991 Honda Civic
On wiring diagram
Jun 20, 2008 | Car Audio & Video
Car Audio & Video Logo
1,092 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
