Question about Acer Computers & Internet
I have an Acer AL1916 monitor. I recently plugged an Optima 19" widescreen monitor in to my computer. I did not like using this as all the fonts were small and too hard for my aging eyes to see!! I have also been using a normal 4:3 monitor for years and did not like the widescreen. When I plugged my Acer AL1916 monitor back in to my computer, all the fonts, etc., have stayed small. I have tried adjusting the resolution in the display settings of the control panel but, whereas that does make the fonts and print larger, the quality is terrible and I cannot seem to fix it. How do I get my original settings back for my Acer AL1916. Thanks.
    Sergeant:
  • 275 Answers
Go to start -> all programs->accessories->accessiblity->accessibilty wizard.click on next and see around
Posted on Jun 20, 2008
How to change monitor aspect ratio for acer AL1916
The aspect ratio is expressed as two numbers separated by a colon (x:y). and they actually represent the relation between width and height of (in your case) your monitor.
Did you mean to change the resolution of your monitor? Could you please explain your problem in more detail? What is it exactly you want to achieve?
Oct 22, 2013 | Acer AL1916 A (Black, Silver) 19 inch LCD...
ACER LCD monitor has no power.
It is probably the inverter which powers the backlight. It should say inverter right on it.
Feb 08, 2010 | Acer AL1916B 19" LCD Monitor
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
Oct 15, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916 LCD monitor is getting darker!!
sounds like backlight is failing,contact acer and see if its under warranty.
Mar 04, 2009 | Acer AL1916B 19" LCD Monitor
I was given a 2003 Acer AL1916 monitor and came home and hooked it up to my old Compaq presario computer. The screen is fine but the audio is barely audible. I had speakers hooked to the side of my old...
The speakers are not supposed to plug into the monitor, they will plug into the speaker jack on the back of your computer (usually a green plug or it will have a picture of a speaker next to it)
Hope this helps
Good Luck!
Dec 09, 2008 | Acer AL1916W 19" LCD Monitor
On a Acer AL2016w and the 2017 it is the far right larger button with the light in the middle of it.
I'm almost positive the AL1916 is in the same place
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Problems with monitor Acer AL1916w
I'm using the Al1916W and it looks great at 1440 x 990. Make sure you have the latest Screen card drivers installed.
Apr 03, 2008 | Acer AL1916W 19" LCD Monitor
Acer al1916
try changing with the bios settings
Aug 28, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
