Question about Sony Cyber-shot DSC-S600 Digital Camera
My camera's shutter won't open
I went to the beach today and I think sand somehow got into my shutter lens and now whenever I try to turn it on, it makes this whirring sound and the shutters dont move. it's a Sony S600. How much do you think I can get it fixed for...or is it the same amount as buying a new one?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey xoemiweexo,
What you probably need to have done is a good cleaning on the camera. Usually cleanings are cost effective. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they could send it out to have it serviced. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 20, 2008
My father dropped my Kodak camera into the sand and it won't work now
If there's sand in the mechanics of the shutter flap and you can hear more that's stuck inside, there's nothing you can do except take it to a camera technician. It'll need to be disassembled, thoroughly cleaned and reassembled.
You will more than likely do more damage if you try turning it on or shaking it to get the sand out.
Sorry to hear about it!
Aug 02, 2012 | Kodak Md863 Easyshare Digital Camera...
I have a Samsung PL100 digital camera. I dropped it while at beach, it was switched off. When I went to switch it on the lens came out but then it made a buzzing sound and switched itself off. The lens is...
I had the same exact issue.... try putting it on the charger, even if you think it's fully charged... If the light is red, leave it on the charger until it turns green, and then remove the battery for a second and then put it back in the camera before turning it back on..... try turning it on. If it still won't close, put it back on the charger. If the charger is automatically indicating a red light, that means you have exhausted your battery and will nee a new one... they cost about 5-11 dollars on amazon...... hope that helps...
Jul 20, 2012 | Cameras
Nikon 28-105 af macro lens, apeture only closes to F 8
Woody the only thing you will learn is to never try and fix a zoom yourself. You got the FM in there because you opened your glass at the beach - as a professional I always set my equipment before getting to the beach and I never open the body and expose either the mirror/shutter or the back side of the glass to the beach - if possible. If I were in Iraq shooting there would be no way around it and the sand there is like baby powder so it is going to ruin the equipment anyway... Einstein would send it out if he wanted to get it repaired - it would be like trying to fix a formula one race engine. Only bad things can happen. If you just want to take it apart to see what it looks like then by all means - they won't give you step by step instructions.
Apr 19, 2010 | Cameras
Camera shutter not opening
The best thing you could do is take it to a competent repair shop, tell them what happened, and have them fix it. If it is just sand jamming the lens cover, they shouldn't charge too much to fix it.
Alternatively, if you can move the lens covers at all, try gently working them back and forth in very small movements while holding the camera with the lens pointing down - basically just try to work the sand out and let gravity help you. Be careful though, you may get sand deeper into the camera's mechanisms this way!
Oct 31, 2009 | Canon PowerShot A590 IS Digital Camera
Problem with M340 Kodak easy share digital camera..( automaticall
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Aug 17, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lens will not extend
Hi:
You need to clean around the lense first. Blow high pressure air spray and get the most sand out of the lense you possibly can.
If it did not open 100%, try to pull it out NOT too hard. If the lese goes up and down and turns you should follow the lense while pulling it out.
When it is 100% out, (the way normally opens) Clean around the lense more.
Turn you camera on and off a few times. It should be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 20, 2009 | Konica Minolta DiMAGE G500 Digital Camera
Sand in my camera
Sand, water, salt water, dirt and dust can damage the lens to the point of no return, so to speak.
It may not have been dropped if you had used the wrist strap, how ever it is now in damaged condition.
The lens needs to be taken apart to completely clean out the sand. This is a very tedious and is a job for a professional with experience.
The parts are extremely small and have close tolerances, thus any dirt or sand can cause grinding or damage to the internal parts of the lens mechanism.
If you ever get a chance to see the gears and the gear teeth, you would understand why just a few grains of sand can jam these small parts. One grain of sand can stop a lens gear from working and possibly cause a broken gear. The parts are so small that in order to see the grains of sand which cause the problem, it may be necessary to use a magnifier lens.
To even make things worse, there is grease usually on the gears. The grease will hold any sand and cause it to stick in place. Cleaning these gears is not very easy.
I have done it, and returned the camera to working condition, but not an easy job.
Aug 30, 2008 | Nikon COOLPIX L3 Digital Camera
Digital camera
Hey everardo,
What is most likely going on is that something (i.e. sand) is obstructing the movement of the lens. You can try gently blowing compressed air into the sides of the lens to try and dislodge whatever is stopping the lens movement. You can also try putting the camera on a flat surface with the lens pointing up and hold the shutter button down, and then turn the camera on. If neither of these options works I would have it cleaned by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 29, 2008 | Cameras
Does it need regular cleaning?
Sand generally has no effect on the electronic side of the camera, however it will definitely can cause problems with the mechanical aspect of the camera such as the zoom lens. this can be removed with a can of compressed air.
Suntan lotion likewise should not be any problem except for smudges on the housing/casing and especially bad for the lens. Additionally, the lotion would help the sand adhere to crevices and nooks of the camera. Wiping should get you just fine.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 17, 2008 | Canon PowerShot SD600 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
48 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
