Question about Creda Kitchen Ranges
Need light bulb for oven model #48113(EDO 202) white. Please advise where I can order
    President:
  • 1,462 Answers
It is a standard bulb - usually small edison screw but make sure one you buy is heatproof type. available any elec shop (in uk anyway)
Posted on Jun 20, 2008
Can you tell me the light bulb type/size and how to change it please?
Refer your question to a local appliance parts supplier or an Evolution dealer/supplier.
Jun 07, 2016 | Ovens
Change bulb inside ge pvm1870Sm2SS
You can download GE owner's manuals and installation instructions
here.
The manual will cover bulb replacement.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 17, 2012 | General Electric PVM1870SMSS Microwave...
Oven light bulb
Go to a name brand hardware store, like ACE Hardware.
Dec 17, 2011 | Ovens
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Jennair Microwave Model JMV8208AA/AC
I am in need of a Jenn-Air JMC7000ADB (black) microwave, so if anyone gets tired of trying to solve the problem, I will buy your microwave from you.
Call Mike at 317-557-5352 or e-mail mslshihan@aol.com
Thank you.
Sep 30, 2008 | Jenn-Air JMC7000 Microwave Oven
GE Spacemaker Model No. JVM1650AB 003
Hello Diana,
Here is a link to the GE User manual for your microwave oven.. Once you download it.. You will find a section on light bulb replacement that details how to install and which particular bulbs to use..Hope this helps you..
http://genet.geappliances.com/DocSearch/pdf/49400821.PDF
Good Luck !
Sep 14, 2008 | Microwave Ovens
I HAVE A GE MICROWAVE MODEL#JES1136WL01 I HAVE SEARCHED THE MANUAL OVER AND OVER AND FOUND NO WAY OF REPLACING THE LIGHT BULB. PLEASE ADVISE THANK YOU ...
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The outer cover (wrapper) will need to be removed.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | GE Microwave Ovens
Old Creda double oven keeps runing when switch off
sounds simple but look at the knob to see if it is cracked and hence not turning the shaft
Jun 22, 2008 | Creda C362E Electric Kitchen Range
Oven and oven light not working
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=53999&thid=573756
Posted by Tvaclav on May 05, 2008
I have a Whirlpool oven model number SB130PER-0 the oven will not heat up also when i turn the oven on the indicator light does not come on. Any suggestions? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR APPLIANCE before beginning any service procedure.
You may have an bad heating element that would needs replacing because that is the heat source for the oven and on the oven light issue you nay have a bad sending unit , switch or just a burnt out bulb or light. Check with your local Whirlpool appliance dealer – sometimes they can be of some help. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://whirlpool.com/home.jsp
Contact Us
Hours: M-F 8am–8pm Local Market Time
S 8:30am–5pm Local Market Time
- Get shopping help
- Order parts and accessories
Call 1-866-698-2538
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
May 05, 2008 | Whirlpool SF367 Gas Kitchen Range
Kitchen Ranges Logo
101 people viewed this question
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
