Question about Dell Dimension 8200 PC Desktop
Wireless Connectivity lost
I have had my router for over a year and all of a sudden lost the connection (maybe due to crazy storms in the area). When you click on the wireless connection icon, it would not connect despite having a strong signal. I tried to reset the router and may have made things worst -- my PC has a USB connection and I cannot get an IP address for the router because it is not connected to the PC.
My current connection is as follows: Netgear WGR614 router is connected to the modem (via an ethernet cable) and the PC is connected to the modem (via a USB cable).
Please tell me how to reconnect the router....
  • 2 more comments
  • Roxie72 Jun 20, 2008
    Answer to questions:
    1. I have cable modem (SBV5120 Surfboard Cable Modem)
    2. My PC is indeed connected to the modem via a USB cord (NOT to the router as directed by all instructions)
    3. No the PC is not trying to connect -- it is already connected to the modem. It was the laptop that was trying to connect despite strong wireless connectivity status. This is on longer the case now that i "reset" the router..
    I really appreciate your help..
    (Not certain this was posted correctly -- so will repeat)
    3.
  • Roxie72 Jun 21, 2008
    C --
    I have Windows XP and I connected the modem to the laptop to configure.
    When I type 192.168.0.1 the login to the router does NOT come up (it comes up as a web search) so I am not able to go through the login.
    Once again, I am lost.... still does not work
  • Cliff Randi
    Cliff Randi May 11, 2010
    Hi Roxie72
    I need a little more info to help you with this.
    1. Do you have DSL or cable for broadband service?
    2. Verify for me that your PC is connected by USB cable to the modem or is it connected to a wireless adapter.
    3. Is the PC you are using trying to connect wirelessly? If so - what is it using to connect wirelessly.
    Make sure your modem is connected to the routers uplink or WAN port. Make sure your wireless adapter is connected and functional on your PC. Let me know and we will go from there.
    Problem Solver:
  • 8 Answers
Greetings Roxie
Are you using XP or Vista?
The default ip address for a Netgear 192.168.0.1 - the default user is 'admin' and the default password is 'password'. Is it possible for you to run an ethernet cable from your PC to the router or from your laptop to the router so we can address its configuration?
Once you have connected the cable, wait about 30 seconds and then open Internet Explorer. In the address bar type 192.168.0.1
At this point the login to the router should come up. If it doesn't report back and let me know. If it does - log in using the default info I listed above. Verify that your connection type is DHCP. From there go to the wireless settings page. Make sure that wireless is enabled and make note of the name (SSID) of your network. Also take note of what channel you are broadcasting on. By default it is probably 6 but you should probably change it to 11. You can also enable or disable the security encryption from this page but lets disable encryption if it is not already disabled.
Once you have verified these items are present and enabled, save the routers configuration. Disconnect your laptop from the router. Unplug the power to the router. Unplug the power to the modem. Make sure all of the lights on the modem go out. Stand tall and sing our national anthem (wait about a minute) and then plug the modem back in. Once the online light has gone solid green plug the power back into the router.
Now go to your laptop and observe the little computer icon in the lower right by the clock. Does it indicate that there are networks available? If so - double click on it to see the available networks. Make sure you are connecting to YOUR network (the SSID we took note of earlier). If it says connected - you should be OK. If it says anything else let me know what it is. Good luck!
-C
Posted on Jun 20, 2008
  • Cliff Randi
    Cliff Randi Jun 21, 2008
    Hi Roxie
    Lets try something. While your laptop is connected to the router via an ethernet cable - click on start and then RUN. In the box type 'cmd' (no apostraphes)
    You will get a DOS window with a command prompt. At the prompt type 'ipconfig'
    It should spit back 3 numeric addreses. The one for your ethernet connection should be 192.168.0.xx with the xx being any number from like 1 to 200. Also make note of the numbers for the gateway. It should be the same as the ip address of your router. If anything is different let me know.
    At this point - I am considering that you might have a virus or a security software that has gone nuts and locked you in. It happens. What are you running for antivirus and/or antispyware. Are you using a firewall program like ZoneAlarm or Norton Internet Security?
    Thanks!
    C
THE WIRELESS CONNECTIVITY SIGNAL STRENGTH IS VERY POOR
I don't know the make of the wireless access point that you are using. First I would unplug the wireless access point, unplug the computer, remove battery, plug in the wireless access point, it will do a self test, when it completes plug in the laptop. You may have interference in your area? Is your wireless access point secured with a passcode? You can also change channels from defaults. I am not sure why you would reformat a machine due to wireless connectivity? You could re-set the wireless access point to defaults by pressing and holding for 30 seconds the reset will return the device to defaults, of course you would have to reconfigure the SSID and security core.
Nov 16, 2012 | Acer Aspire 5920-6727 Notebook
Wireless connectivity is very poor to my acer aspire 5920
I don't know the make of the wireless access point that you are using. First I would unplug the wireless access point, unplug the computer, remove battery, plug in the wireless access point, it will do a self test, when it completes plug in the laptop. You may have interference in your area? Is your wireless access point secured with a passcode? You can also change channels from defaults. I am not sure why you would reformat a machine due to wireless connectivity? You could re-set the wireless access point to defaults by pressing and holding for 30 seconds the reset will return the device to defaults, of course you would have to reconfigure the SSID and security code.
Nov 16, 2012 | Acer Aspire 5920-6335 Laptop
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
Lost of connectivity of my wireless connection of my laptop
Please check your laptop is getting wireless signal or not from your router.
If not then check your router is working fine or not with other device also.
Mar 31, 2010 | NetGear WGR614 Wireless Router
Network has suddenly dissapeered
This is just a problem with the wireless settings of the router, you can try first to reset the router by pressing the reset button for 20 seconds while power is ON and then after that you should be able to find the default wireless name of the router which is linksys, after you reset the router just need to reconfigure it back...
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
No wireless connectivity
Try doing a firmware upgrade to your router.
Nov 08, 2008 | D-Link AirPlus DI-524 Wireless Router
Lost connection over wired LAN - wireless OK
A common fix is to re-set the modem. Just unplug the power to the modem for 30 seconds, then re-connect it. You could also bypass the router momentarily to see if the modem is working. Just connect one of the computers directly to the modem to verify connectivity. Your control panel should also have a utility to renew the IP address.
Sep 13, 2007 | SMC Barricade g SMCWBR14-G2 Wireless...
Dell Dimension 8200 PC Desktop Logo
161 people viewed this question
Alun Cox
