Question about Sony Handycam DCR-DVD105 DVD Camcorder
Error Message: Disk cover open, accidentally. Turn on power again.
I have a sony handycam DCR-DVD 105 and I keep getting the error message that my disk cover was open and when I follow the directions to turn on the power again I get another error message. Disc error. Unsupported format and I cant access any of the recorded information.
  • 6 more comments
  • wwtmww Jun 29, 2008
    Same here. my DVD cannot be read from Camcorder or DVD-rom
  • Anonymous Jul 09, 2008
    For no apparent reason, the "unsupported format" appeared on the screen and I cannot finalize or access any of the information recorded on the disk.  I replaced the disk and the camera works fine.  I guess it is a bad disk...?
  • atulkc Jul 16, 2008
    I have the same problem. Camcorder records for a while then gives message saying 'Disk cover open accidentally. Turn on power again" and when I do that then all the recording is erased and it starts all over again. I have lost two dvd recordings due to this problem, some one please help.
  • Anonymous Aug 08, 2008
    Disk cover open, accidentally. Turn on power again. I'll loose all the data on the disc mODEL DCR-DVD405
  • anilkumarkc Aug 25, 2008
    I too faced this problem with my DV608 handicam..it says "Disk cover open, accidentally. Turn on power again." Actually the power was not at all turned off..but sadly and surprisingly all the recordings on the disc was found to be deleted...cant believe this....Can somebody suggest the reason for this error...
  • irenevoortma Sep 28, 2008
    at the moment I can not use the camera, because everytime the same message anyone has a solution
  • Carol Hall-Jones Oct 09, 2008
    UGH I spent way too much time with Sony support and had no success my camera is doing the EXACT same thing and I have lost 2 very important recordings, one an interview with my grandmother. I am very frustrated that this seems to be a common problem and that means an obvious pre-existing issue with this camera and sony will charge me $210 to fix it. I might as well buy another camera. I am goiong to call a third time and report that I have found this site with all of you having the same issue. I am also going to report them to http://www.onlinebusinessbureau.com
    I encourage all of you to do the same! Sony should be held accountable to the consumer. This is not a cheap camera and they should repair issues that are related to faulty manufacturing.
  • b_demian Mar 29, 2009
    Same problem here.
    I get: Disc cover accidentally open. Turn on the Power again.
    Then after doing that I can not acces to the Disc again and it seems to be lost. I can Finalize the disc.
    Please help
When you open the door you will see 2 metal tabs that are sensors to that are pushed by 2 plastic tabs on the door that push on the metal tabs to let the camera know the door is shut. For whatever reason these tabs are not pushed up enough and I triggered them by sticking something in there to make contact. I used the end of a toothpick for now. May be primative but it works for now and I may look for a method to make it permanant but at least my camera works now
Posted on Feb 18, 2010
I too had the same problem with my DVD 755 model. I took it the sony service station but those guys didnt have a clue on this. But that guy did a RESET for the handycam and gave it to me (i didnt try doing a reset before taht.. totallly forgot..) know what.. i am not getting that error anymore :D i ahve been using it for past 1 months and no issues... recorded some 1 hr of video till now and it is fine.. pls try this and see if it works for u or not :)
Cheers
Posted on Nov 02, 2008
I took the disc out and sprayed it with air - the canned air you spray the computer with to clear the dust. Put the disc back in and it seems to be working great!
Posted on Jan 23, 2010
If the lense thing doesn't work then this one will!!!
I dropped mine so the lense wasn't the problem, the door has some play in it.
Haha, yes finally what a pOS!, But I got it!!
So I got to thinking well the sensor or something be messed up a bit.
So hell , I put a C clamp on it. I started to record. Sweet, it worked!!! The cover was stuck so the sensor wasn't tripping.
Well that worked, but I didn;t want a c clamp on my camera all the time, so I had some Automotive Amazing Goop,
I lined the cover edges with the sealent and let it dry. Now when I close it , it stays closed and records without a problem.
I glued a bracket to the outside of the cover to make it easier to open.
But it was unusable before, and at least I can use it.
Good luck.
Posted on May 16, 2009
You need to clean lens, i have a Sony handycam DCR-DVD 205 with the same probleme i clean the lens, and now work
Posted on May 09, 2009
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
Sony handycam DCR-DVD608 Error E:61:00
I have sony handycam dcr dvd 608,when I open my handy cam,the message is showing, movie record disable
May 23, 2010 | Sony DCR-DVD608E DVD Camcorder
So I got to thinking well the sensor or something be messed up a bit. I found that the cover a very slight amount of play.
The only thing is its tuff to open, I use a skrew driver, or small nail.
Good luck.
Sep 25, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Lens cover won't open
I have the same problema. Have you fix it? How? I appreciate your answer. Regards, Diego dspeier at yahoo.com
Feb 23, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
Cant Open the DVD cover
I am curious, did anyone start having this problem after going through x-ray at airport?? We had trouble after that?? I paid a lot of money for this thing and I am ready to smash it hard, real hard!!
Dec 19, 2007 | Sony Handycam DCR-DVD101 DVD Camcorder
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Error message + disc opened acidentally + recording disabled
1. cleaning the laser lens with isopropilic alcohol and q-tip
2. Try the reset button on the bottom of the camera. Tilt your camera and look below the LCD Display Backlight button on the bottom edge of the curved portion of the camera. You will need a paperclip or tip of a ball point pen to push the recessed little button. Place the camera on a level surface and try again. We find that the camera is very sensitive to tilting, as it gets older.
3. Make sure you format format at was FAT not fat32
4. All you need to do is "Quick format" the disk with the CAMERA rather than the memry stick plugged into the computer drive.
5. For sony error c:1301 using mini cd's: there is a program that recovers data from cd's that works with disk that have this error. It called "cdroller" Homepage is : www.cdroller.com
6. just take the memory stick off and re-insert it lot of times.. just keep doing it.
Apr 12, 2007 | Sony Handycam DCR-DVD205 DVD Camcorder
Sony Handycam DCR-DVD105 DVD Camcorder Logo
2,211 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
