Question about Compaq Presario R3000 Notebook
Battery not recharging
My battery drained down and it won't charge with the cord plugged in. The lightning bolt on front keeps blinking and it won't charge. Bad battery?? Bill
    Guru:
  • 859 Answers
This is usually the case. A small chip inside the battery that keeps tabs on the state of health for the battery is what sends the signal not to accept a charge. Unfortunately that may be bad itself and the batteries near their end, one will fail before the other sometimes, but it does mean the cartridge, ergo the battery needs to be replaced.
It does pay to shop around and not run to HP for a battery, Ebay is a good place to start with this in mind, find a power seller with a high rating who has an agreable return policy and acceptable warranty period. Only then, purchase from them.
Otherwise, you can shop at highly regarded outlets on line such as NewEgg.com.
A Google/Froogle search will yield a return of results that can be ranked by sellers with four stars. Some of these even have Google Checkout. Just use the same common sense for a solid rep and ample return policy with a warranty that makes sense to you. It is your choice where to buy.
Please remember to rate this solution, it is appreciated. Thanks.
Regards,
Worldvet
Posted on Jun 20, 2008
Why is my iphone not charging?
This means it's not getting a charge. I've just experienced this problem myself. I followed instructions online regarding cleaning lint from the charging port of the phone. Still no charge. I bought a charging cable that came with a car charger made by Belkin, this worked in the car, also allowed me to charge the phone from the pc, but wouldn't charge from the original plug. So I purchased an original Apple branded lightning cable today and it works. At last. So it turns out that my cable was faulty and another branded cable would not work with the Apple plug. So you need to try a known working Apple cable and plug and failing that clean out the port on the phone as lint is a common problem.
Jan 02, 2015 | Apple iPhone 5S
Laptop won't start up
I'm inclined to think that your power cord is bad and you have drained your battery.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Fujitsu Siemens Computers & Internet
Have a Sunrise Aspire chair w/new batterie, charged by the repairman. Want to keep it charged regularly (not let it run down). DO I NEED TO TOTALLY DISCONNECT THE POWER HOOKUPS IN THE BACK when I...
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
Jan 05, 2011 | Quickie Wheelchairs Quickie Aspire Power...
Compaq M2000 laptop lighting bolt flash 3 times wont start
Could be a bad mother board or a hard drive..see if you can connect the hard drive with a USB on another machine and run a test on it...
May 27, 2009 | Compaq Presario M2000 Notebook
Hard reset and charging problems
do the hard reset again .. hold the power button down while operating the reset in the back .. keep the power button down for a few seconds .. that should bring up a display "delete all" .. you can choose to do so .. that will be a hard reset .. now if the battery is dead and the charger is not working then nothing will work for you .. you might have a bad charger .. often the end that plugs into the unit develops a broken wire inside the cable ..
the m515 wont charge from the sync cable (shame) it needs the external power adapter .. make sure the connections on the charger and palm are clean .. the power adapter is 5 volts and i think about 1 amp .. )(center pos) if you want to try another adapter .. the tip is rather standard ... also you can get a universal power adapter from radio shack that will work on just about anything .. you just plug in a suitable tip .. the tip for your palm is an "A19" .. the power adapter is "IGO" wall adapter 23-1401 model PSM08VADJ ... that seems to work nicely and it plugs directly in to the palm .. so you can work with it plugged in .. when the charger is working there should be a lightning bolt thru the battery symbol .. it sounds like you already know that .. if the battery has gone open then it may not indicate a charge .. but the unit should still work while on the charger if that is actually working ....
Apr 13, 2009 | Palm m515 Handheld
No problem? ?? HP dv8230 status indicator lights flashing.
I believe this would mean that your battery either has a low charge or if you have the AC power cord plugged in, it could mean your battery is bad and won't take a charge
Jan 05, 2009 | HP Pavilion dv8230us Notebook
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
Compaq laptop
its not charging try any other power adopter....
Jul 17, 2008 | HP Compaq Presario V2000 Notebook
Battery doesn't charge
Is that the original power cord for that? Or was that one bought aftermarket, some aftermarket chargers will only power your laptop and not charge.
Mar 12, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario R3000 Notebook Logo
386 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
