Question about KitchenAid KEMC308 Electric Double Oven
Burnt out light bulb in microwave
How do you replace bulb?
  • 84 Answers
Well it is an absolute nightmare changing the light bulb in the microwave. you have to basically remove the microwave from the rest of the appliance to get to the light after remove panels and other parts. if you intend on doing this take your time. best solution is to have a repair do it that way if it doesn't work he/she is liable not you. best of luck
Posted on Jun 20, 2008
Can be done actually, based on these instructions:
http://applianceguru.com/view_topic.php?id=16293&forum_id=1&jump_to=97654
It will take some time and involve pulling the unit out, trying to find the bulp ##
Posted on Aug 15, 2008
Can't believe this..same problem here, removing the unit from the wall to replace a light bulp??? Come on..
HOw to replace light bulb microwave KEMS308
Unit has to be removed from wall top panels removed to replace if can live with out it great bulb is cheap labor 100-150
Jan 24, 2014 | KitchenAid Architect II KEMS308S 30"...
Change the light bulb in microwave
There is usually a small panel on the side of the microwave replace with a similar bulb. I think you can get them anywhere bulbs are sold
Nov 27, 2013 | KitchenAid Ovens
How to change light bulb in microwave?
Found this post on another fixya-type site: below is the link..
Here's a repeat of Kai's instructions so you don't have to scroll down. I just replaced mine and it was a snap. Just a few Phillips screws and a few tugs. No need to pull the unit completely out as you can access the bulb after it's about half way. No need to disconnect any wiring harness except pulling the bulb out of its socket. I used the 10w (G4 12V) replacement bulb from Home Depot at $6. The light is a bit brighter but there've been no problems with fuses.
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
http://www.fixed4free.com/answers.php?id=51232
Mar 21, 2012 | KitchenAid Architect Series KEMC308KSS...
It "popped" a circuit breaker
NORMALLY THERE ARE SCREWS TO REMOVE TO ACCESS A PANEL TO REMOVE THE LIGHT BULB. IF THERE ARE NOT, THEN THE EXTERIOR COVER MAY NEED TO BE REMOVED TO ACCESS THE LIGHT BULB. THIS EXTERIOR COVER HAS SCREWS.
MAKE SURE YOUR CIRCUIT BREAKER IS OFF BEFORE YOU TRY TO REPLACE THE BULB.
Feb 20, 2011 | Ovens
The lightbulb in the microwave needs to be replaced. How does one get at the bulb to change it?
At the following site, http://www.ehow.com/how_4967054_change-light-bulb-microwave.html
detail instructions can be found for changing the light bulb in your microwave.
Give it a try.
If this works for you, please give me some positive feedback.
Thanks!!
Jan 25, 2011 | Ovens
How do i replace the cooktop light bulb in my microwave oven?
I realized the light bulb was fixed using an adhesive (maybe a glue stick) that is why, I had a hard time removing the old bulb. After forcing it (and breaking the adhesive seal) I was able to replace it with a new one.
Oct 06, 2009 | GE Ovens
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
Jenn-air microwave light bulb
This is an older (Mfgr. May, 1987) microwave oven. Functions perfectly, works an looks good to this day, just no light inside. I searched a couple of websites looking for parts for this unit and appliancepartspros.com provided schematics of the product that I own. From those drawings, it was determined that the microwave oven will have to be slid out of the cabinet above the built-in oven in order to change a $2.37, 40W light bulb. Just a handfull of scrws retaining the oven and exhaust baffles and I'll get it out (onmce the New Year's Eve hangover disappears). The engineer who designed a system like this must have been on an Acid Trip. I haven't looked closely at newer microwave ovens, but I'd have to believe changing a crummy light bulb would have to be made easier than this during the preliminary engineering phase of design.
Dec 31, 2008 | Ovens
Microwave oven light - KEMC 307
you ll need to pull unit out to replace bulb, 2 scrws remove side trim of oven, 3 or 4 screws remove trim under micro; above oven, 2 more screws behind that grill will release micro from supportthat should free it up enoug to slide foward 6 or 8 inches( the bulb is ontop of the cavity) good luck!
Feb 25, 2008 | KitchenAid KEMC307 Electric Double Oven
KitchenAid KEMC308 Electric Double Oven Logo
1,056 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
