Question about Janome Memory Craft 5700
Error message #1
(Have seldom used machine since purchased.)
Plugged in machine, turned on switch, screen opens normally, then clears and displays error message #1. Cannot clear. Machine does not work.
Any ideas? Can't find anything about error messages in the instruction book.
Thanks.
  • jaimeggj Nov 15, 2008
    Can anybody tell me what's wrong with my Janome Memory Craft 5700.
    the message "system error #1" appear in screen and I can't do anything!!!
    Please, help me
I had the same problem. It was plug ed into an extension cord as soon as i plug-ed it into the wall socket presto it works. I sure hope your problem is this easy.
Posted on Jul 22, 2009
  • Janome Master
  • 1,388 Answers
E1 message means "Fail to initialise stepping motor for zig zag" Either something has jammed the mechanism (broken needle, thread etc) or the stepping motor has failed....if you cannot find obstruction easily, then this is one to send to the Janome service centre for assessment and repair
Posted on Aug 27, 2009
Control Panel shows the following error message: ][ How can I re-set it?
] [ = usually means that your bobbin winder is on. Move the bobbin winder post/shaft from the right position over to the left to switch the mode back to sewing, then try making your stitch selection again.
Jan 12, 2016 | Singer 7256 Fashion Mate Sewing Machine
Why won't my Singer Futura Quintet 5 in 1 turn back on?
Yes, I can. By now, I'm sure you've found out that your machine will turn on again. The reason I know that is those motors are DESIGNED to shut themselves down if the motor is overheated or has been interrupted by, for instance, a needle break. Turn off the power button and leave it alone, and it WILL turn on again between 10 minutes and about 2 hours, depending on what caused the shutdown.
The reason you got those error messages was simply because the machine was not on. The machine functions as a dongle for the software; if it is not on (even though it is plugged into the computer), the software will not start up.
Apr 19, 2015 | Singer Sewing Machines
Singer Quantum Stylist 9960 {error message > release reverse button )
It is either defective or received shipping damage.
May 16, 2014 | Sewing Machines
Getting E-1 and E-error messages after bending needle.
it means the machine is out of order
mine does that,,I usually just have to turn it off for a few minutes & that normally clears it
Dec 02, 2010 | Kenmore 19233 Computerized Sewing Machine
Counting hours sewn
Go into the Service Menu by pressing and holding the reverse feed button and the sensor foot pivot button while switching the machine on. The display screen will now show Menu 1. On the third row down touch MENU button. The display changes to show Menu 2. At bottom of screen you will now see ON-TIME - SEW-TIME - EMBR-TIME.
I would not recommend touching any other buttons or settings. Switch the machine off and restart as normal.
Apr 24, 2010 | Husqvarna Designer I
When I try to open the futura program a pop up box continues to say check that USB cable is attached and machine is turned on. I tried two different USB Cables and turned the machine on. However the same...
My computer is extremely touchy when I use my usb cable to attach to my machine. I have to use the SAME usb port that I used when the driver was installed or else it will not recognize that my machine is plugged in. Basically it is telling you it cannot find your machine. Reinstall the driver and mark which usb port you used to install the machine.
Also, in order to open the futura software, your machine must be powered on and connected via USB cable before you attempt to open the software on your computer.
Oct 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Info screen keeps beeping to change pressure foot, and I have the correct pressure foot attached to the machine.
If this machine is a Rose, the screen flashes the foot because it thinks the foot is in the up position, not because your using the wrong foot type. There is a spring that can break and a switch that can sometimes go bad that gives that error message. A trip to your service tech is required. That part has a 20 or 25 year guarantee if you are the original purchaser. Labor was covered for one year from date of purchase.
Sep 27, 2009 | Husqvarna Sewing Machines
I have a confidence 7470 and I can not get my machine to sew because the error sigm says I need to lift my bottonhole arm back up. I have done this repeatedly and have turned the machine on and off to...
It is the switch that is connected to the arm that may not be working properly which in turn send the wrong signal to the display.Check the arm and look for any kind of switch connected to it..Try to move it and see what happens or if the error disappears..
Sep 02, 2009 | Singer 7436 - INGENUITY
Error message on Brother SE-270D
I had the same issue a few years back but with actual symptoms of malfunctioning. I had mine fixed under warranty. The service tech told me it was a faulty circuit board. Works perfect now. I think the warranty is only for the first year to cover labor and parts. Not sure how much it would be out-of-pocket. This happened within 3 months of a brand new purchase. Hope this answered your question.
Mar 16, 2009 | Brother SE-270D Computerized Sewing...
Pfaff 2170 Query
my pfaff 2170 machines shows "Cannot make Directory" pls help me in this
Apr 26, 2008 | Sewing Machines
Sewing Machines Logo
602 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
