Question about Carrier Heating & Cooling
Need model 48SS evaporator coil replacement part number
4 Suggested Answers
james3751
  • 614 Answers
SOURCE: want to buy a replacement for a coleman model 6136A serial no. 77312543 evaporator coil
Evcon wed site and you will find parts fo Coleman
Posted on Jun 07, 2009
  • 25 Answers
SOURCE: Looking for evaporator Coil number for Carrier
Are you replacing or adding an evaporator coil to this system? If replacing, please give us the model # (and product #) of the evaporator coil. If you can't find one for it, we will need the air handler (or gas furnace) model # so we can help you match it up.
If you just want the condenser coil for that condenser, the part # is 331230-7035.
Posted on Mar 25, 2010
  • 53 Answers
if u are unable to locate the coil number ,well get the model number off of he condensor an match the coil ,,make sure you have correct tons
Posted on May 16, 2010
  • 146 Answers
SOURCE: part number for an evaporator coil for a ruud
i can tell you it is a 2 ton unit. 24,000 btu's. the only other thing you need to know is the width and the depth. they make a 15 inch and a 19 1/2 cabinet. hope this helps you.
Posted on Jun 09, 2010
What is the A-coil that is compatible with furnace model KG7SC072D24B?
Looking at the model # it appears that you may have a 2 ton unit. Evaporator coils come in different sizes -
You should be able to get the correct size by providing the A/C repair company with the name of the manufacturer and the Model Number.
Generic coils, should you need one because yours is no longer being manufactured, do come in all different sizes.
I don't know if you want to replace the evaporator coil or have a service company do it. But if you do there are some things you need to know.
If the unit is an older unit the evaporator coil along with the box it sets in needs to be replaced because the drain pan is probably rusted out.
Additionally the box the new coil sits in is is going to be different in size then the original.
So a transition will need to be made from the furnace to the new A-coil box.
So with all that being said - if you have a credible A/C company replacing the coil you won't have any problems with them finding a replacement coil. They are in the business of doing this type of work and come across this situation all the time.
Oct 06, 2014 | Heating & Cooling
Evaporator coil leak
you need a 4 ton coil for your unit. all replacement coils are generic. any a/c supply house carry them.
Jun 09, 2014 | Goodman CKL49AR49 Air Conditioner
Cp48b3x-175t-014x7495
If the coil absorbes heat from the living space to make it colder - it is the evaporator coil. If the coil is exposed to outside air to give up the heat - it is the condenser coil.
Got a picture? Or manufacturer's name & model number? The number you provided doesn't come up - where did you get the number from?
Mar 01, 2013 | Heating & Cooling
Part number for an evaporator coil for a ruud system model number for the condensr is UAHE-023JAS I dont find any numbers on the coil. Can you match it up?
Jun 09, 2010 | Heating & Cooling
Looking for evaporator Coil number for Carrier Model 24ANA736
May 14, 2010 | Heating & Cooling
Mar 24, 2010 | Carrier Heating & Cooling
Heat setting blows cold air
you have a bad heater coil. This coil is located behind the evaporator coil in the unit. To access this coil you will need to remove the a/c from the casing. Right behind the coil you will see a metal box that has metal strands crisscrossing inside of the bos this is your heater coils. Take the model number and serail number to an appliance parts house for replacement part. Good luck on your repairs hope this helped
Dave
Nov 17, 2009 | Amana PTC123B35AE Air Conditioner
Model number for Carrier furnace with issue for blower 5 minute off delay
I believe that this model number is for an air conditioner evaporator coil. This unit is probably directly attached to your furnace. The Model number for the furnace will be located in the compartment where the flames can be seen. It will be on a sticker or plate that contains lots of other information too like BTU/h, Volts etc...
The number you gave me gives me this info:
Cased air conditioning evaporator coil.
3 Tons
Horizontal application
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
66 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Cris Sparks
Cris Sparks
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
