Question about Classic Minicooler Mini Cooler / Warmer ThermoKool Deluxe Mini Beverage Cooler
Thermoking I'm working on refrigerated truck, it has a themoking model KIT CB 20 serial numbe 04832F1262 I don't know how to connect the two transformers that generates 220 volts when working with the 12v battery. The two transformers have only two terminal each one, but how to connect it is my problem
This system uses in conjunction with the transformers a rectifier which converts the High AC current voltage (220V-AC) to a Low AC current voltage (12V-AC) and then the rectifier converts that energy into the D/C current (12V DC). The two diffrent 12V power sources are controlled, operated by a "electric" relay, via a roadside or electric selector switch. DS_TK TECH
Posted on Feb 22, 2009
Value of starr baby grand piano serial numbed 207229
Value of starr baby grand piano serial numbed 207229 Google Search ..i can not find your model number but try this link it might give you some idea what its worth.
Dec 02, 2016 | Grand Music
It is a thermoking refrigeration unit on a commercial truck trailer as in 18 wheeler not a car or pick up ! And today I noticed some motor oil in the coolant
Its a gasket leak either head or intake manifold or a cracked or warped head how hot did it get.
Any other problem that could cause this would be a rebuild of the engine .
Jun 30, 2016 | Miscellaneous
How to clear "04" fault code on a thermoking sb 210?
It's been a while since I worked on Thermokings. But all I worked on, when the problem was fixed, the code would automatically be gone.
Aug 14, 2015 | Cars & Trucks
How to reset computer thermoking semi trailer
I assume you are talking about a thermo king refrigeration unit. I don't know what model you have but there should be two arrow's up and down. Those arrow's should move your set point up or down. If there not working it's possible your company has the key pad locked so the set point cant be changed. Hard to answer this question not knowing what kind of thermo king unit you have.
Nov 29, 2013 | Heating & Cooling
I ndde numbe of part from conponent transistor 5 pin in the chasis of radio back side please can you help me tank you
The service manual for this radio is on the CBTricks.com web site. You will find the info you need there.
....Don at NTCB, Inc.
Dec 06, 2010 | Radio Shack TRC-447 CB Radio
Where can i find a wiring diagram for a Thermoking refridgeration trailer, model number 709662
I have had good success finding very appliances info from appliancesfactoryparts.com
Jul 12, 2009 | Refrigerators
My whirlpool gold side by side serial # slo539783 model #gd
Sound like you have a refrigerant leak I suggest to take it to a pro because you need lots of tools and knowledge to properly fix it And don?t let people tell you than is just to add refrigerant because that is a common myth or miss conception, refrigerant don?t ware out or burn out if the system need refrigerant is because there is a leak some where.
Jun 07, 2009 | Whirlpool Refrigerators
My media center p c m8277c electronic keyboard wont go on susie
Have you turned off the pc, unplugged the keyboard, is it a usb or is it a ps2.....does it have a flat end, or a round end when it plugs into your computer ?
If you have unplugged it and then re-connected it, have you turned it on ?
The numb lock is on the right side, press it and the keyboard should light up with a corresponding light.
Try it.
What is the serial and model number on the keyboard...
Quebec Keyboard Kit
it should be a sticker underneath the keyboard.
For Quebec customers, a French-Canadian keyboard kit is available. The keyboard kit includes localized keyboard, documentation, and software.
It should have a cd for software that you may have to install to make the keyboard function correctly.
Good luck let me know if I helped you enough.
Techlahj
Apr 13, 2009 | HP Computers & Internet
Classic Minicooler Mini Cooler / Warmer ThermoKool Deluxe Mini Beverage Cooler Logo
379 people viewed this question
Top Classic Minicooler Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Classic Minicooler Refrigerator Expert? Answer questions, earn points and help others
