Question about Dell 3100cn Laser Printer
3100 Dell Printer - Printing CMYK DOTS TWICE ON EVERY PRINT
Printing CMYK dots twice on every print posted by RyanCD on Jun 16, 2008 Report abuse
I clean the fuser drum and wiped clean the toner drum and took out the toners and put them back in. The dots still show up! I don't know what to do? Help!
  • gigglejess Oct 26, 2008
    Same thing here, what do I do????
We had a Dell Engineer come out for this prob and it basically involved replacing every working part inside it until it worked! :-(
He said he believed that it might have been toner leaking out, but I don't believe that because of the precision of the dots on every printout.
I hope urs is in warranty!
Posted on Jul 02, 2008
Xerox 7132 printing dots after 35 pages
Check if it is with just one document or with all documents. Can also be coming from the job and not the printer
Apr 07, 2013 | Xerox WorkCentre 7132 Multifunction Color...
My printer is reading check alignment, is it because my color cartridge is out of ink?
No, that's not what it means.
If printer heads are not aligned, CMYK colors (Cyan, Magenta, Yellow and blacK - the usual colours in a printer) will not print in the correct place.
Assume a dark grey dot is to be printed. For this C, M and Y colored dots have to be placed exactly on the same spot. But if heads are not aligned, the three color dots will not be exactly in the same place. Therefore you will see Cyan, magenta and Yellow dots adjacent to each other instead of one dark grey dot.
It is always a good idea to align the print heads every time a new cartridge is installed.
Sep 23, 2011 | Lexmark X3650 Printer
My printer is printing dots on my pages
Question..... are you using genuine Dell Toner in the printer? If not, that's likely the root cause of this problem.
You can try having the printer cleaned
Good Luck
Nov 09, 2009 | Dell 5110cn Laser Printer
Documents are printing fine but the right hand edge has black dots on it like 6-8 sapced out along the right hand edge.
check your print cartridge and your fusing element. you will need to dead cycle the printer to check the cartridge (print a document, when it is half way through turn off the printer, check the toner cartridge for your dots.) are you able to see your fusing element by opening the rear door? check the edges for dots on the fusing element. also there is a transfer roller or belt in your printer, that may also be dirty.
Sep 24, 2009 | Dell 3100cn Laser Printer
Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
Your Problem is the cartridge printer Mx, In spanish algun balero de las developers units esta dañado pudiera estar golpeando el cilindro de imagen
Nov 03, 2008 | Xerox DocuColor 12 Printer
Creating Halftone Dots
in photoshop you can use a filter to create dots you can actually see on screen, cant remember exactly where it is, but it is in the filter menu. Also to print halftone dots you hit print and go into the print preview dialogue box, click on the screens button. another dialogue opens uncheck use printer defaults. This allows you to specify what frequency angle and dot shape you would like for each color you are printing. By default CMYk are specified for the layers visual space, other spot colors can be added using channels and will show up within this dialogue along with CMYK options. however, you can only have one channel selected at a time to get it to print correctly.
Similarly in illustrator, the options are in the print dialogue. detailed info about each of these processes can be found in the help menu of the respective programs. you may want to check out this link. Many of these questions are answered in this forum all the time. http://screenprinters.net/articles.php
Sep 13, 2008 | Adobe Photoshop 7.0 for PC
Printing CMYK dots twice on every printposted by RyanCD on Jun 16, 2008 Report abuse I clean the fuser drum and wiped clean the toner drum and took out the toners and put them back in. The dots still show...
If you are getting single color dots but all 4 colors the issue has to be somewhere comon to all 4 which usually is the Transfer Belt. i would look for some sort of damage to the belt or something sticky on it.
Jun 20, 2008 | Dell 3100cn Laser Printer
Cmyk dots on the print
There are several causes of those.
So go to Xerox.com
Click "support and drives"
then in the product name box, Type DC12
Then any line click support
IN the search box type "spots" and read the relevant solution.
May 05, 2008 | Xerox DocuColor 12 Printer
Hi, As it's printing two little strips (like a 1/4inch) of CMYK dots (one of each color all you need to check the toner cartridge drum, try to wipe the toner drum with a damp cloth on each color cartridge. Secondly check the fuser assembly drum if it has any mark on the drum, try to use a mild isopropyle alchohol to wipe the dirt mark them try printing. this will resolve the issue. if still issue persists then change the color cartridge one by one. This will definitely resolve the issue.
Oct 05, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
157 people viewed this question
Top Dell Office Equipment & Supplies Experts
Prashant  Sharma
Prashant Sharma
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
