Question about ASUS P4SP-MX Motherboard
Please help when i turn the system on it says: BIOS ROM checksum error Detecting floppy drive A media... Drive A error. DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER "but this system doesnt have a floppy drive this pc use to work they said the only problem is dead drive i put a new HD but this is what im getting. and how can i get to BIOS setup"
  • Anonymous Mar 14, 2014
    gf7100p- checksum error insert system disk
  • 144 Answers
Try pressing F2 / Del key during startup. That should bring the bios setup. Now Restore that defaults & install OS on your HDD. If you are not using Floppy drive, disable the onboard floppy controller from BIOS.
Posted on Jun 22, 2008
I always have failure to boot and have beep sounds. Already installed asus update v6.10.02, still shows overclocking failed on start up and requests to configure BIOS. My system includes: inno3D-FX5500...
1-Does your computer show any sign of response after power button press?
2-Is your power cable properly connected and have main power switched on both your power supply unit and the wall plug?
3-Is the 20/24-pin ATX power connector has been connected between your motherboard and power supply?
4-Can The standby power LED (Green blue) light up continuously after the mains power is connected? (Note: Both flashing and off are no good here)
Fix 1
(1) Isolate The power going into your system ( i.e. connect your system to the wall plug directly, without sharing the power with any other devices via power extension cable.)
(2) Check if the power supply and power cable functions correctly, and have the input of your power supply set to the correct position (either 100/110V or 220/240V, depending on your country)
(3) Please try replacing your power supply.
Fix 2
1. No POST
1.1 Please clear CMOS to have a try (refer to motherboard manual for details)
1.2 If the problem still persists, please contact your retailer for a check
2. There is error message during POST: BIOS ROM checksum error. Detecting floppy drive A media... Insert system disk and press enter
2.1 If the support CD supplied with motherboard is available
2.1.1 Please restart system and put support CD into optical drive, then the system will recover BIOS automatically using CrashFree utility
2.2 If the support CD supplied with motherboard is not available
2.2.1 Prepare a formated floppy disk, then unzip the BIOS file downloaded from ASUS website into the floppy disk.
2.2.2 Please restart system and insert the floppy disk into floppy drive, then the system will recover BIOS automatically using CrashFree utility
2.3 If it is not helpful after the troubleshooting as the steps 2.1 or 2.2, please clear CMOS( referring to the manual introduction)
Fix 3
Please try the latest BIOS. I recommend you to use AFUDOS to update BIOS. You need to unzip it to get the ROM file.
You should use the command as follows:
AFUDOS /i[biosname]
or, afudos /i A:\BIOSNAME.rom(if the BIOS file is in the floppy disk)
You can store your BIOS into a floppy disk or a hard disk with FAT format. Then, you will be able to use AFUDOS to access the BIOS ROM file.
If it is not convenient for you to use DOS and AFUDOS, you can try to use EZ Flash. You can save the BIOS file into a flash disk then boot the system and enter BIOS, then you can update your BIOS by EZ Flash which is in the BIOS Tools page. Please load the default settings in BIOS after you have succeeded updating BIOS.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | ASUS P5VDC-MX Motherboard
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
My computer can not boot -BIOS ROM checksum error
to be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Jun 15, 2009 | EliteGroup K7VTA3 V5.0 Motherboard
When i boot the computer what comes on the screen is (''award bootblock bios v1.0'' copyright(2) 2000, award software, inc bios rom checksum error detecting floppy drive A media insert system disk and...
it means your boot sequence is first booting your floppy drive or your hard disk is not detected.i think you should check the cmos set-up.you can set it by pressing delete while the pc is booting.disable floppy drive seek.also the boot sequence.the os installed is maybe corrupted, is also one of the problem. refer to the manual if you have.
May 16, 2009 | Computers & Internet
The following message appears as soon as I turn PC on; BIOS ROM CHECKSUM ERROR Detecting Floppy Drive A Media... Insert system disk and press enter My OS Microsoft Windows XP SP2 Bios : Award Bios...
There should be a jumper beside your bios batery there should be 3 pins move the jumper to the last 2 pins for 5 seconds and put it back that should do it
Mar 23, 2009 | Computers & Internet
Bios failure, or what?
Hi there.
Try clearing the cmos
d015d7b.jpg<<<<< you will see in the picture a plastic jumper (in this case coloured green), move it to the other position and hit the on/off button, then put it back in its original position and power up the machine again. Hopefully the issue will have been sorted. If there is no jumper remove the battery for an hour and make sure the power cord is removed from the back before you clear the cmos
Good luck and thanks for using Fixya!!
Feb 19, 2009 | DFI AK74-SC Motherboard
have you a hard disk in the pc ?
somehow your hard disk has stopped booting (virus , bad hard disk boot sectors)
you may have to reinstall the OS
hope this helps
Jan 05, 2009 | Intel D101GGC Motherboard
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
ASUS P4SP-MX Motherboard Logo
228 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
