Question about Vacuums
I need to replace the belt on my kirby g6 2000 how do i do it
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=688060
Generic problem for all Vacuums
Posted by shawn81 on Jun 20, 2008
I need to replace the belt on my Kirby g6 2000 how do I do it
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Kirby has a belt hook on the inside of the bell housing and 1st you need to release the old belt by turning the dial in front of the bell housing counter clock wise to get the old belt off. Some Kirby vacuums the entire bell housing comes off and makes it fairly simple but the process and the format to change the belt is the same. The brushroll has screws on each end and the screw heads need to be facing down on each side, so remove of drop down one side of the brush and slide the belt onto the middle of the brushroll then re-insert the brushroll, screws head facing down, then use the Kirby dial to hook the belt and then dial the belt onto the Kirby fan pulley and then you should be done. If you have further questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 23, 2008
Tip
How To Replace a Belt on a Kirby Generation G3-Sentria Vacuum Cleaner
Greetings,
Below we explain how you can replace a vacuum cleaner belt on the Kirby Generation upright vacuum cleaner. All you will need to perform this repair is a new Kirby Generation Upright Belt, and some time. No tools are needed to perform this repair. This repair is the same for all Kirby Generation models including: G3, G4, G5, G6, Ultimate G, Kirby Diamond Edition, and the Kirby Sentria. The repair procedures have to be followed exactly in order for the vacuum to work properly. This should be done at least once a year even if the belt doesn't break, because these belts will stretch out over that year time period and will not work as well as a new belt would.
I hope that you find this video helpful. If you do, please be sure to rate this Tip as helpful by clicking the Thumbs Up Icon in the top right hand corner of the Tip.
Feel free to send me an email anytime if you have any questions on the repair of the Kirby, or any vacuum cleaner.
Video Repair on how to Change a Belt on a Kirby Generation Vacuum Cleaner;
Thank you so much,
Chris Jones
GoVacuum
on Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Roller doesnt spin on my kirby g series
That means that the belt is stretched or broken. You need to replace it. You can get replacement belts here:
Kirby Ultimate G Belts
Mar 09, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do you attach the belt for the roller-brush on a Kirby Generation 3, up-right vacuum-cleaner?
Greetings,
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Thanks for watching!
Chris J.
Jun 14, 2009 | Kirby Generation 3 Bagged Upright Vacuum
REPLACING BELT KIRBY CLASSIC III
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11562&thid=806061
Posted by JETALBOT on July 19, 2008
I CAN'T REPLACE THE BELT ON THE CLASSIC III (KIRBY). CAN YOU HELP ME? ELAINE
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Mail To: Consumer Relations
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Jul 19, 2008 | Kirby Heritage II Vacuum
Belt
I don't know where near you, but most local repair shops should have the belts for kirby.
Jun 18, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Installing belt on G7D Kirby vacum
For belt replacement instructions watch video
http://www.goodvac.com/
Good Luck,
Rocky
May 03, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How do you replace the belt on the Kirby, Model No D50, Serial No. A442867
This is an older Kirby vacuum and the front brushroll section of the vacuum and the front brushroll section will come off, 1st you have to remove the front cover (the Kirby Emblem) and under that there is a Kirby spoon or hook and you need to dial off the belt off the belt shaft, once that has been done remove the bottom plate and un-install the Kirby brushroll, check to see if the brushroll spins freely, if it does go onto the next step, if not clean off the hair and thread from either end and then re-check the brushroll, if it still binds up then replace the brushroll and belt with Genuine Kirby belt and brush. Then use the dial to place the belt onto the Kirby spoon / hook. Once the belt is on the hook, install the bottom planter and place then housing of the Kirby on the vacuum and use the lever on the top to secure the fan housing dial the belt onto the pulley and you should be good to go.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Apr 21, 2008 | Vacuums
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
121 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
