Question about Irons
Rowenta stream iron
The stream iron stop working
    Scholar:
  • 65 Answers
Usually depend on the dripping system go inside the boiler and produce steam.Try to use a scale remover and probably will help you out.Sometimes this operation need to be manually opening the iron and cleaning the dripper
Good Luck
Posted on Jun 21, 2008
Rowenta Pro Precision won't stop steaming until the tank runs dry.
Rowenta irons have a propensity for leaking. Most users do not add water to the tank but instead use a spritz bottle to dampen the fabric and then use the dry iron.
Jul 16, 2017 | Rowenta Irons
Clogged steam holes
If the approved cleaning procedure does not work, your Rowenta iron may have failed.
Jan 09, 2014 | Irons
Calcium buildup - when ironing white specks keeps getting on clothes.
<span id="LblAnswers">.To solve this problem, switch to bottled spring water. Once the water is changed it will take several uses before your iron adjusts to the new mixture and the issue is corrected. </span><br>to speed that up Place the iron in clean or high stream mode if its a feature on your iron if not I would wipe it down with the solution usually 3 parts water 1 part vinegar.&nbsp; Also Rowenta sells a cleaner specifically for their irons&nbsp; and you can purchase it online here is the link its from macys but rowenta brand and is now on sale <br><br><a href="http://www.macys.com/catalog/product/index.ognc?ID=64754&amp;cm_mmc=Google_Feed-_-6-_-77-_-%7Bkeyword%7D&amp;kw=%7Bkeyword%7D">http://www.macys.com/catalog/product/index.ognc?ID=64754&amp;cm_mmc=Google_Feed-_-6-_-77-_-{keyword}&amp;kw={keyword}</a><br>
Aug 29, 2010 | Rowenta Irons
Stream is not working
Sounds like the internal tab attached to the trigger is broken. Unplug unit, let cool. Pry up the rubber cushion from the handle, working from the front to the rear cord, You will probably see the tab lying on the switch. New trigger assy can be had from Rowenta Service Center:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
This would be my first choice as your boiler is working fine. Good luck and tell us how things get resolved.
May 23, 2010 | Rowenta DG-980 Iron
I have a rowenta iron that leaks a lot of water
Here's a solution . . . Do NOT buy ROWENTA! I've had 3 Rowenta irons. All of them have eventually began to dump water out of the base. . . heck, the Titanic didn't leak as much as a Rowenta iron!
Dec 31, 2009 | Rowenta Perfect Iron
I have a rowenta iron. When I am ironing the
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jun 25, 2009 | Rowenta DX6700 Iron
I have a Rowenta 1700 iron. The iron has started to act up. When I plug the iron in it just flashes & does not get hot. It is like it is in the stand by mode when you leave it on & don't iron...
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Oct 14, 2008 | Rowenta DZ1700 Iron
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Sep 18, 2008 | Rowenta Effective DX1700 Iron with Auto...
Irons Logo
126 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
