Question about Samsung Yepp YP-T7JX MP3 Player
My screen is broke but can still play music
I accidentally broke my screen a while back but before i broke my screen, my settings were set so my skip interval is set to skip 5 seconds, and i want it to skip to the next track when i push the next button... i need to know steb by step instructions to get into my settings and change that to skip to the next track, because i can't see my screen... PLEASE HELP!!!! :)
  • 58 Answers
In 24 hours i will send you a map <finger directions to fix your next track problem> just wait to write it down..
Marios
Posted on Jun 29, 2008
Is there a way to program the whole keyboard to play 1 octave lower?
You can use TRANSPOSE/SETTING button.
Each press the TRANSPOSE/SETTING button cycles through the setting screens. If you accidentally pass the screen you want to use,keep pressing the TRANSPOSE/SETTING button untill the screen appears again.
To lower by one octave,set the value to -12
You also can use PIANO SETTING button.
Find the setting in page 07 of PIANO SETTING.
Sep 03, 2015 | Casio CTK810 61 Key Keyboard
My Sansa e260 has a white screen. It plays music, but i want to be able to see what im doing.
Your Screen is most likely broke because even if somehow accidentally the brightness on the screen setting was messed with it wouldn't make it white the only real solution is to buy a new one or learn to navigate the device without seeing
Feb 28, 2011 | SanDisk Sansa e260 MP3 Player
My screen broke and I am unable to change my settings. Is there any way ui can get a picture of the mode settings?
holding the MODE button will return you to the main screen. They are Music-Movie-Picture-Setting. You should be on the Music screen first. Pressing down will take you through these in order. Under Setting is LCD set, Language, online device, memory info, firmware, remove mtp info, default, exit.
While in Music (as long as you are not playing a song) tapping the MODE button will give you the option of going to the local folder or exit.
If you play a song and press MODE you are given the following options Play Mode, Equalizer, SRS WOW Mode, and exit.
Under Play mode are the options, Normal, repeat one, folder, repeat folder, repeat all, random, and intro.
Under Equalizer is flat, rock, pop, classic, soft, jazz, DBB
Under RS WOW mode is srswow, user setting, disable srs wow and exit.
I hope this is what you were looking for.
Jun 26, 2010 | GPX ML648B MP3 Player
It wil not play music and skips through artist by itself
  • Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer’s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
  • Try resetting the device it’s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds.
Dec 06, 2009 | SanDisk Sansa m250 MP3 Player
My mp3 player plays the same track over and over unless i skip it forward at the end of every track
Hi bikerdino,
Is there any tiny logo in the form of an arrow chasing its own tail somewhere on the screen? This is almost obviously a problem with the settings. Please go to the Music Settings on the player, where there should be an option like Play Mode or something equivalent. You'll find this Play Mode is probably set to "Repeat". Change it to "Normal", which should do the trick.
Oct 27, 2009 | Audio Players & Recorders
Kenwood kvt-719dvd A/V interface was lock
On the front of your unit you have a small pin hole (front right hand side) you will need something small to push this in & it will reset the unit . Once the unit is reset you will need to get into your audio settings and set them back up so that everything sounds correctly.
Apr 10, 2009 | Phase Linear UDV9010 Car DVD Player
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Aug 07, 2008 | Insignia Sport MP3 Player
IPOD mini won't play purchased music unless 100% charged
I've called Apple support on this before. They told me to make sure that the Ipod is set for Manually manage music in the Ipod settings of ITunes. You should restore all software in your IPod to factory settings before doing this.
Jul 14, 2008 | Apple iPod mini M9160LL/A MP3 Player
NaNO 2G Skips music Mp3 Sometimes Stops
In a mater in fact it could be the mp3 the mp3 was copy right protected so it skips and doesn?t let you listen to them.
Nov 02, 2006 | Apple iPod nano
Samsung Yepp YP-T7JX MP3 Player Logo
70 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
