Question about RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 Hi, it seems you are very knowledgeable with this stuff. My TV had sound but no picture. I replaced the lamp, but now the picture comes and goes. A TV repairman sold me the lamp. The only difference I noticed is the my old one had a "B4" on the bulb and his has an "A3." Would this be a problem? He's telling me i may need a ballister. I hear something turning on and off, would it be the fan?
  • DavidLex Aug 18, 2008
    Looks like I may have a similar issue (if not exactly the same). Yesterday the tv was fine, today we have sound but no picture.
    I can see that the lamp is fine, I get menus with excellent brightness.
    None of the video inputs show any picture.
    I've run the trouble shooting & turned off digital picture info retreival with no success.
    If the ballister is the issue, where did you purchse the part from, and what level of difficulty would you say replacing it is?
    FYI, I've pulled the original bulb housing out in the past, and replaced the bulb only - kept the original housing. So I'm quite sure the bulb is not the problem.
    Thanks for any help,
    David Lex
    (TV model HD61LPW42)
I thought the bulb difference was the problem, but the manufacturer said it was ok. We replaced the ballister and it is working fine. Try replacing it and that should work.
Posted on Jul 24, 2008
Color wheel
Posted on Jul 18, 2008
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
Picture occasionally goes out, still have sound when this occurs and then the picture will come back on after a while. When the picture is out the lamp is off. Hd61lpw42 RCA DLP TV
Souns like the Lamp is going out ,If you have never replaced Lamp then that is what your Problem is Mats has them for $99.00 1-800-628-1118
Nov 06, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
I'd like to know where I can get a replacement wire to connect the lamp ballast to the J4 input in my rca HD61LPW42 rear projection TV. I've gotten no response to an email I sent RCA a week ago. These...
hey mcd5brady, what was the solution to your last problem w the tv? ( replaced bulb and ballast but still no picture) my tv has same problem and dont know what to do next. any info on a solution would be greatly appreciated! post back or email. dellbino@aol.com
thanks
Jan 09, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42. No picture/sound.
Ur high voltage FBT,is dead the block of plastic with a red wire with a cap hook to the CRT(tv tube).Might also have to replace the whole power board?Because just couple parts it hard to determins,what else also ready to burn next!
Sep 12, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
No picture but sound
most likely the color wheel needs replacing.
Aug 08, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Realistic Lamp Cost ??
139.00 seems reasonable for a replacement lamp. is that the only problem that you are having or are you hearing a squealing sound and then the tv cycles off?
Dan
Aug 29, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Turning on but no picture at all
I would check to see if the lamp is actually comming on before anything else. The color wheel won't cause a loss of picture. Here is a link to purchase a suitable replacement lamp for the TV. It is 300 dollars less than the RCA version. http://www.partstore.com/Part/Thomson/RCA/HD61LPW42/Lighting+Technologies+International/LTI/260962RL/New.aspx
May 09, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 61" Rear Projection HDTV Logo
138 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
