Installing transit bolts
Wd8013c lg
im having trouble installing transit bolts to move interstate.
    President:
  • 1,462 Answers
Advise you take the top off so you can see where the bolts locate
Posted on Jun 20, 2008
How to lock drum for moving
all machines come with installed Transit bolts, these are removed before the machine is used, and should be kept in case you need to move the machine later on. The transit bolts lock the drum to prevent movement whilst moving the machine. If you do not have these, I would suggest looking for some. However I have moved a machine without the bolts in and as long as you are reasonably careful there should be no problems.
Apr 28, 2014 | Kenmore HE2 Plus Front Load Washer
Drum doesn spin
If this product is new, you will need to take out the carriage bolts located in the back of the machine.
Carriage bolts are meant for the shipping process to prevent the drum from moving while in transit. Most manufacturers use between 2-4.
Check your product manual for details on the removal of the carriage bolts
Jan 23, 2014 | LG DLEX7177WM SteamDryer Front Load...
LG WD13020D walks, vibrates, jumps around - no transit bolts, tried pads and just keeps moving - have to be around the machine all the time to stop it from going into cupboards. Only had machine since...
Chech the shocks, and springs. Also chech the counterweights bolted to the tub. You will need to open up the machine to do this. If you've only had in since April, then its still under warranty. You should contact lg and have then send an authorized servicer to take a look at it.
Jul 09, 2011 | Washing Machines
HOW DO I INSTALL THE DWCLD 1421 - NO INSTRUCTIONS LEFT WITH MACHINE. ARE THERE ANY TRANSIT BOLTS?
If this is a front loader the quick answer is that you should be able to see whether there are any transit bolts by taking the top off. The whole drum structure, possibly with large lumps of concrete attached, should be free to move.
If not, which is likely, the fixings should be visible.
Sorry- I don't know for top loaders!
John C
Feb 21, 2011 | Washing Machines
I just bought a bosch washing machine maxx 7. While spinning the whole machine moves. Did I install wrongly or must I lock something. I have to hold on to the machine tightly so that it will not move. ...
The problem might be that at the back of the machine the transit bolts are still in to find out how to remove look in manual. The way you described it sounds like the transit bolts are still in and need to be removed. if the bolts are out the machine need to be levelled and feet checked so that it is all secure. hope this helps.
Sep 18, 2010 | Bosch WFO2862 Front Load
I manage a Moving Company and was wondering if all front loading washing machines require shipping bolts to be installed prior to shipping, or just certain brands?
Hi just read your posting.In my experience with front loaders they all have transit bolts .The reason being is that the internal bowl and tank are separated from the outside frame by suspension rods and, or springs.The easiest way to tell on most front loaders is to look for the holes in the back of the frame of the machine where the bolts attach the frame to the tank .Hope this helps and good luck.
Jun 16, 2010 | LG WM-2077C Front Load Washer
Single cylinder dead bolt only works with key
You are 180 degreees out of sync with the other side of the bolt. Take it apart and move your key 180 degrees and reassemble and try it. Im 51% sure this is your trouble
thanks for posting at FixYa.com
Please vote
thanks
a
Nov 15, 2009 | Locks & Locksmithing
I left the transit bolts in our "brand new" zanussi washing machine and am afraid to use it as I do not know what damage might have been done.
Highly unlikely any damage will have been done so long as it hasnt been in use for a long time (weeks).
In a front loading washing machine, most of the mechanicals inside are held between springs at the top and dampers at the bottom. The transit bolts are used to minimse how much movement can ocour whilst the machine is in transit as excessive movement could damage the springs/dampers. When they are removed, normal movement of the mechanicals helps keep the machine stable and minmises vibration.
So, the worst that happens when the machine is used with the transit bolts in place is it vibrates alot, and possible moves about.
Remove the bolts as soon as possible and it should be fine.
Oct 04, 2009 | Zanussi ZWF12070 Front Load Washer
How to secure front loading drum for moving????
transit bolts vary with machine. pack polystyrene blocks tighty between tub and cabinet and that will do the trick
Sep 25, 2008 | GE WCVH6260F Front Load Washer
Moving
you just need to refit the transit bolts which you removed when you had machine new. if you have lost them, pack some polystyrene blocks between tub and cabinet so the assemby is held tight
Jul 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
509 people viewed this question
Top Washing Machines Experts
