Question about Gateway Computers & Internet
My laptop seems to be overheating yet the fans are working
    Problem Solver:
  • 13 Answers
Try buying a can of compressed air that can be bought and many stores. clean the computer thouroghly .that should help. also try increasing your memeory in your computer is up to speed.
Posted on Jun 20, 2008
How to fix Fan spinning too fast and monitor no signal
If the fan is running fast and there is no display the most likely cause is a GPU failure.
May 26, 2016 | HP Computers & Internet
My fan doesnt seem to be working and laptop just shuts down after it gets hot
Hi, your laptop shuts down as a protection against overheating. It's important that you take the laptop right away to a service repair shop so it can get the fan replaced before other important components get damaged.
Jul 27, 2011 | Toshiba Satellite L455DS5976
The above as over heated and seems to fail after about ten minutes of being on this is an intergrated card can it be fixed without replacing the motherboard it is in an asus laptop.
I suspect that your cooling fan has stopped working or the sealing mating between the fan surface and the CPU is not intact. These fans quit working because dirt and grime gets into the fan shaft and friction slows the fan . also if the fan gets accidentaly moved on the CPU, then this breaks the heat transfer tape between the CPU. This over heating causes the CPU to fail. Open the machine and observe if the fan is running correctly.
Apr 14, 2011 | Computers & Internet
My acer laptop aspire 4730z just shuts down with no apparent reason..i just cant get rid of it..what seems to be the problem!?
It may be due to overheating. Make sure all air vents are clear of dust. Check that the internal fan is working - usually located under the keyboard. The fan should usually ony come on intermittently, first when you boot up, then intermittently in Windows when the processor is working hard. If the fan is on all the time and especially if it is running fast then your processor is overheating.
If you go into the bios setup and the laptop resets within a few minutes with the fan running fast then you have a definite processor overheating problem. This may be a faulty processor or a fault on the motherboard.
Mar 10, 2011 | Computers & Internet
MY LAPTOP ONLY RUNS FOR A FEW SECONDS AT ROOM TEMPERATURE CPU SEEMS TO OVERHEAT
Probably you need to replace fan, because if fan is not working Intel processors will restart machine when the CPU is overheated.
Feb 24, 2010 | Acer Aspire 3680 Laptop
My computer is overheating and how do u clean the fan
need to blow all the dust out of the vents on the side and bottom of laptop and check out the fan while the laptop is running. If the fan seems to be running slow, the bearings may be damaged and you may need to get another fan.
Jun 01, 2009 | HP Compaq nx9010
Overheating although cooling fan & heatsink are ok
u r saying that the laptop is overheating. I think it is from cpu overheating right. just to make sure that it is cpu overheating, just go to the following link and download the software around 1mb which displays each and every component heating levels.
from that you can find out the exact component.
http://www.cpuid.com/software.php
if cpu is heating then just replace the thermal interface material and the problem will be gone.
if the cpu thermal interface material is too old then this type of problems arises
Apr 19, 2009 | Computers & Internet
Advent overheating
you'll need a laptop cooler pad
Jan 24, 2009 | Toshiba Satellite A25-S207 Notebook
Overheating
Overheating is a big issue with Gateway. It mostly involves problems with the fan. When Gateway receives a warranty fan problem they replace it with a fan that is reconditioned or rebuilt (probably from another cutomer's unit like yours) and they don't seem to last long. To make sure it is a fan problem, which is the most common, Turn on the laptop and wait to see if the fan is turning on. It won't take long, processors get hot quick. The fan should turn on and run anywhere from 3 to 15 seconds then turn off. It should do this approx every 5 to 7 minutes in order to keep the processor cool. If it doesn't work at all, works seeming sporadically, or the processor gets really hot before the fan starts, then it's a fan problem, and a NEW fan should be purchased. If the fan works properly, then it could be that the fan and heat sink need to be cleaned internally due to dust build up.
Jun 20, 2008 | Gateway MX3228 Notebook
Computers & Internet Logo
18 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
