Question about Gateway Computers & Internet
My computer is overheating, it shuts off and can be restarted
    Novelist:
  • 119 Answers
Chances are the fan of either your processor or power supply is bad. it could also be possible that an accumulated dust could be blocking the processor fan from reaching your processor. try using a compressed air can to clean all ventilation and check whether the fan is functioning. if one of the fan in not working replace it immediately because it may damage your processor
Posted on Jun 20, 2008
Why does slotomania shut down my computer?
Does it shut down the computer completely or it just restarts it?
This might be caused by overheating. Are there any signs of overheating in the computer? or outdated video driver. Try updating your video driver. You can also install Radarsync to automate the computer's updating mechanism.
I hope this helps!
Carlo
Dec 20, 2012 | HP Pavilion dv6-1122us Notebook
Computer keeps shutting off every five minutes or so
Computer may be shutting od due to following reasons:
Computer Virus
There are higher chances of a computer shutting down due to the interference of a computer virus. The virus gets into the computer and fiddles with crucial sections of the operating system, which may cause the system to shut down automatically. You need to install a good antivirus software and get the computer scanned thoroughly for any malware and viruses. Also see to it that the operating system and all hardware drivers are updated.
Power Supply
The computer power supply unit is an equipment that is installed in the cabinet to provide power to the system for operation. Your computer can shut down, if there is not enough power supplied to it for handling the programs running. If you are using the computer for running intensive software such as PC games, the system would require more power than what is actually available. Another reason can be overheating of the power supply. After the power supply is used for a substantial period of time, there is a possibility of dust getting collected inside it. And this may cause it to overheat, resulting in the shutdown of the desktop computer. If the power supply is at fault, you may need to get a new one installed.
Overheating of the Motherboard and the Processor
As with the case of dust getting collected in the power supply, the computer motherboard and the processor can also collect dust, which may be the reason for their overheating. This may also be one of the reasons why your computer keeps shutting down and restarting. You need to open the computer cabinet and clean the dust off the computer parts. The CPU board and the processor can also overheat because of many applications running. If this is the case, then it is suggested to keep the running of applications as less as possible or increase the size of Random Access Memory (RAM). Bad capacitors on the motherboard is also one of the reasons, why your computer keeps shutting down very often.
The 'Automatically Restart' Setting
If you are using Windows XP operating system, there is a setting that indicates the computer to reboot if it detects an error in the system's operation. In order to check if this is the problem, click on 'Start' and 'Control Panel', then select 'Performance and Maintenance'. Click on 'System', then the 'Advanced' option, and select 'Settings' from the 'Startup and Recovery' section. You will find an 'Automatically restart' option, which you need to uncheck for preventing the system from rebooting. Read more on computer keeps restarting on its own.
These were the possible reasons, why your computer keeps shutting down and rebooting. You also need to check if the power cables are properly connected to the cabinet and to the UPS, as loose connections can also be a reason for system shutdown. The most common cause of the computer getting shut down or restarted is due to overheating of the power supply and other internal computer parts.
Dec 29, 2010 | Mirus Computers & Internet
Computer restarts when playing high configuration games
This is because your computer is overheating and is shutting down to prevent the heat from damaging the components, refer to my tip on Comuter Overheating here http://www.fixya.com/support/r6789964-pc_overheating
In this tip I outline the problem as well as various solutions.
Nov 12, 2010 | ASUS GeForce 8500GT Graphic Card
Sony subwoofer shuts down then restart, possible overheating
If that is a amplified sub(should be)it sounds like a bad mosfet chip on the heat sync.
Oct 27, 2009 | Audio Players & Recorders
Computer shuts down
Your computer is most likely overheating.
Make sure it is positioned so that none of the vents are blocked on the unit.
Check it with your hand to see if it's overheating, make sure dust is not blocking the vents.
If the issue persists, could be software or a failed cooling system on the unit.
Jun 28, 2009 | HP Compaq Presario V2000 Notebook
My computer is restarting? Please help
try pulling ram modules out and reseating them. this is most frequent cause beside overheating, but then if it's overheated it would shut down , not restart.
Jan 27, 2009 | Computers & Internet
2000 Lincoln LS Overheating
sound like a faulty engine coolant sensor. if the computer gets a signal that the engine is overheating it goes into protection mode and shuts the engine off to prevent damage. have it scanned for fault codes. mike
Jan 06, 2009 | 2000 Lincoln LS
Shut down
check coooling fan too. or replace the heat sink.
the problem that i see in your case is overheating.
Jan 15, 2008 | Toshiba Satellite A15-S157 Notebook
Computers & Internet Logo
96 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
