I think my computer is overheating - Computers & Internet
  • jt102595 Apr 05, 2009
    I have an HP desktop and I have been keeping it on 24 hours a day to record programs (I have Window Media Center with tv tuner). Now my computer shuts off during the day and it also shuts off when I use too much ram ie. using too many programs at one time. I know i have a problem with the fan because every time i try to turn it back on it says "System fan has failed. Service PC" How could I fix this?
    Problem Solver:
  • 7 Answers
Check whether the CPU fan or SYSTEM fan is working properly or not. If those are ok, go to BIOS and check see CPU fan speed & temperature.
eg: Your CPU should idle @ around 25°C if your room is 20°C or something like this.
Posted on Jun 20, 2008
    Novelist:
  • 119 Answers
If your computer keeps on shutting down after only a few minutes turned on .. chances are you are right. check the following:
check the fan of the power supply if it is spinning and check the air vent if it is clear of any obstruction like accumulated dust. if dust is heavy try using compressed air to free or rid of dust.
check also the heatsink of your processor and check if there is an accumulated amount of dust blocking the fan air from reaching the heatsink to cool your processor. use compress air again. check also if fan spin is giving enough air power to cool the processor.
    Problem Solver:
  • 13 Answers
You can be sure your computer is overheating if your cursour is lagging or if u see a shadow around it. if so try installing another pc fan with can be found at wal mart or any eletronics store.
P1299
The code means the computer thinks the engine has overheated based on the reading from the engine temp sensor. The engine could have overheated, or be low on coolant, or the sensor may have failed.
Dec 08, 2012 | 2001 Dodge Neon
My motherboard keeps on overheating @ 70C and over plz what must i do?
Hello and Welcome to FixYa!
If the overheating is not due to hardware issue, faulty components, you can control the temperature by using Heat sinks and Temperature controlling fans, and by regulating a proper Air flow to the unit. For this, you can also use Cooler Master casing specially designed for high end purposes, or can use any such available brand to control the temperature...
Concerned.
Jun 28, 2011 | ASUS P5KPL-AM SE Motherboard
When I play game such as Company of Heroes or call of duty. My computer shut downs after 5 minutes later. I think the overheating is main problem . What are your suggestions?
To avoid laptop overheating, follow the information from this link, or you can get a usb cooling fan to help cooling it off while playing.
Dec 22, 2010 | HP Pavilion dv5-1004nr Notebook
My truck is showing me a code on the dashboard that says: ENGINE HOT A/C TURNED OFF, air blows but the A/C doesn't. How can I fix this? thank you
A/C turns off when the engine overheats, if it isn`t actually overheating, your coolant temp. sensor could be bad, which would make the computer think that it is too hot.Look for overheating first then check that sensor if not overheating.
Oct 26, 2009 | 2007 Chevrolet Silverado 1500 2WD
Laptop spontaneously shuts off!
They make a chill pad that your laptop rest on between your legs and the laptop. You are right it is overheating.
Aug 13, 2009 | Acer Aspire 7720 Notebook
Acer Laptop runs but shuts off suddenly
this is an overheating problem, computer have a thermal protection sensor that senses extreme temp.
i suggest return to your service provider and have them check again, it could probably cause by, the fan isnt plug or there is a lot ob obstruction to exhaust that tned to build up heat around your pc
Aug 03, 2009 | Acer Aspire 5720-6661 Notebook PC
My laptop just overheated in the computer bag after i thought i had turned it off. now when i turn it on...it works and i can see the screen and everything but the colours have gone strange sometimes it...
i can only think of 2 things. it may have overheated to the point of damaging the RAM or it may have overheated or just moved the screen connection. either way there is no way you can fix this on your own and you will have to take it to a computer lab they will be able to help you alot more. sorry for the limited solution good luck with it.
Mar 04, 2009 | Compaq (254124-001) Case Cooling Fan
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
Think it is over heating
Ours kept stopping as it overheated - soluion was to get a chap platform to elevate the laptop which allowed it to 'breathe' a bit better and hasn't stopped since. We orginally had it directly on the desk so the air wasn't circulating
Oct 23, 2008 | HP Pavilion zd8000 Notebook
Overheating
I need some more information. What is it actually doing to make you think that it is overheating?
Aug 24, 2006 | Kenwood KAC-9102D Car Audio Amplifier
Computers & Internet Logo
298 people viewed this question
David Payne
David Payne
