Question about Gateway Computers & Internet
My computer just seems to shut off, maybe it is overheating but the fans seem to be working.
  • 119 Answers
If your computer is randomly keeps on shutting down this is a thermal issue which you need to address. check airvents, use compressed air to clean all possible obstructions between heatsink fan and processor. try avoiding blocking the airvent of your notebook. try also updating your bios
Posted on Jun 20, 2008
Hi I have a Sanyo Convection Microwave EM-C5779V and when the timer goes off the fan seems to continue to run and won't turn off when I hit the cancel button and have to turn it off at the wall.Help?
the fan may keep running to keep it from overheating until it cools down, if you let it go and it shuts down eventually should be no problem, maybe 3 to 5 minutes it should shut down. fan running is not dangerous however if it never stops then the fan will wear out
Jan 01, 2016 | Sanyo Microwave Ovens
Delonghi Pac-C110 air conditioner The compressor is overheating and shutting down but works fine when running. There is a slight squeaky noise when running that seems to come from the squirrel cage...
The overheating & squeaking may be a result of a blockage in the exhaust hose. Or the exhaust hose has to much of a downward slope. Also, try cleaning the air intake filter. It may be clogged.
Jul 14, 2011 | DeLonghi PAC C110 Portable Air Conditioner
Computer is a Lenovo TC M52 P4 / 3.2 - I have added a sound card, a PCI express Geforce graphics card and a NIC card. The problem seems to be overheating as it only shuts down like this during the summer...
The case fan should start running as soon as you turn on the computer. I would replace the fan with a higher capacity (CFM). If you have a case that can take 2 case fans, I would install the send fan. Also with the case off, check that the CPU cooler fan is functioning. With the quick shut off, I would suspect that the CPU cooler fan is not functioning. I could be impeded by dust. Vacuum and blow out any dust on the motherboard, fans and battery fan while you have the case off.
This should aleviate the shutoff problem due to overheating.
Let me know if this solves the problem.
Please rate this solutution. Thanks.
Jun 23, 2010 | Lenovo ThinkCentre M52 8212 - Pentium D...
My brand new imac is shutting down while I'm working - it seems that when it gets warm it is shutting down and it needs more than 1 hour to switch on again. Is there any problem with the new imac's and...
Their was a problem of the processor. That's why they are going to shutting down because the processor are overheated. So you need to replace that processor.
May 29, 2010 | Apple iMac 233Mhz/266Mhz/333Mhz Internal...
My sony viao vgn-cs215j suddenly turn off by itself and it takes 20 minutes before i can re-start and use it again and after 15-20 minutes would shut off by itself again without any warning. what could be...
Sorry i nay be a month late on this thread... but better late than never. My Girlfriends sony vaio VGN-CS215J seems to be doing the exact same thing. After buying one of those computer fans that you rest the computer oneverything seems to be running normal. i would also recommend cleaning your fans inside the computer because dirt dust and grime can hold the fans back from cooling down the laptop efficiently and will cause the safety overheat shutdown to activate and shutdown your computer... that way it does catch on fire or fry any of your hardware inside of your computer.
If that does not work... your fans maybe malfunctioning or not functioning at all. this model of vaio has a grinding fan issue that can be very damaging to your cpu if not fixed.
hope this helps,
Mike Huffstutler
Apr 06, 2010 | Sony VAIO VGN-CS215J/W Notebook
Hp Pavilion dv9000 powers on, then shutdowns, and keeps repeating.
Try it without the battery inserted with the AC adapter.
Jan 04, 2010 | HP Computers & Internet
Shutdown Issues
It could be overheating, either you need to replace the fan, or at least open it up and remove any dust (bunnies) that may have built up inside, if your fan is gummed up it won't spin which then causes computer to overheat.
Jun 28, 2009 | Acer Aspire 4315 Notebook
Fan makes a lot of noise, then computer suddenly shuts down
Seems to be overheating. When you say the fan makes a lot of noise, do you mean an unusual noise or just that it is on high?
Feb 10, 2009 | Acer Aspire 5002WLMi Notebook
Fan not going on and interface really slow
turn it off for an hour see if that works could be overheating
Dec 21, 2008 | Dell Latitude C400 Notebook
Processor overheating
Hi have you cleaned the heatsink? Also replace the paste on the CPU, also you could try installing an extra fan on the case to increase air flow. Also check that your RAM is seated properly and any other chip and card on your board is firmly plugged in. If all this fails replace your CPU. Regards mistyman
Sep 10, 2007 | Intel Pentium 4, 2.8 GHz (bx80546pg2800e)...
Computers & Internet Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
