Remote codes Hello-- I have a silver colored rca remote control; I think a 3 unit controller which worked fine until I messed it up by laying on it and some how deleated the coding. It was controlling an older magnavox tv. I need the procedure and code to re set the controller to tv!! Any help would be verymuch appreciated. Thanks Tom . You can reply to me at tommyscho@yahoo.com
CompuGuy44
  • 432 Answers
SOURCE: lost my manuel "codes" to my rca universal remote control crk74ba3
This website should help.
http://www.thompsontv.com/rcarc.html
Posted on Nov 07, 2007
SOURCE: Universal Remote Control cannot find code
I have the RCA RCU600D remote and i cannot get it to work with any codes listed for my Panasonic DVD-RV20 dvd player. Any ideas???
Posted on Dec 28, 2007
robotek
  • 1512 Answers
SOURCE: need code for direct tv for my rca remot universal control rcu600d
The product you are trying to access may be called DirecTV(different spelling). You will need to find the make of your set top box used to decode the DirecTV and then look up satelite codes in the user manual for the remote to select the correct code.
the manual for the remote can be found at
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=philipsmagnavox&dv=universalremote&md=pm435&kw=pm435s&st=&ar=&dt=&so=&pg=1&file=others/philips/pm435-manual.zip
In case you dont have the book still. Good luck.
Any drama, get back to me here.
regards
Graeme
Posted on Jan 28, 2008
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
how to get capation off my philips magnavox tv with remote can not make remote to go up or down . what buttons do i use help
Posted on Jun 13, 2008
SOURCE: tv codes for a rca universal remote controller
need remote control codes for a toshiba 32A35 with a rca remote
Posted on Jun 24, 2009
Hello I have a universal remote control for tv sanyo but I lossing de manual instruction and Iand ree program my tv. only I need how cam progarm my remote control pleaswed thanks.
Here is the steps on how you can reprogram your RCA tv remote control:
1. Turn the television on by pressing the "Power" or "On" button that is located on the set.
2. Press and hold down the "Code Search" button located on the RCA TV remote. 3. Press the "TV" button on the RCA TV remote. Once you press this button, you can release the "Code Search" button
4. Start pressing the "On/Off" or "Power" button that is located on the RCA TV remote. Keep pressing the button until the television shuts off. 5. Press "Enter" on the RCA TV remote to save the code on the remote. The remote will then control the television.
Apr 07, 2011 | RCA Universal Remote Control
I NEED A NEW REMOTE CONTROL
Hello
I thinks that you need a new universal remote control for your RCA tv, and answers. You just buy one stated below,and codes and other proceedings are also given.
Model No: [RCA - D770 Wide Range Remote Control]
Codes for RCA TV with this remote control are:-
1000, 1003, 1004, 1005, 1006, 1007
.........................1019, 1096, 1098, 1099, 1100, 1101
.........................1102, 1103, 1129, 1179, 1181, 1187
............................................1188, 1190, 1198, 1199
Proceedings
1. Turn on the device to be programmed.
2. Look up the brand and code number(s) for the device on
the code list at the end of this section.
3. On your remote control, press and hold the device button
you want to program.
4. Enter a code from the code list.
5. Release the device button, and then press ON•OFF to
see if the device responds to the remote control
commands. If it doesn't, try pressing the device button
and then ON•OFF again.
6. If you get no response, repeat these steps using the next
code listed for your brand, until the device responds to
the remote control commands.
NB: Switch Off and On your TV with its front panel power switch each time [NOT BY THE REMOTE CONTROL HANSET], before you try an other code, UNTIL YOU GET THE RIGHT ONE.
Dec 20, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
Rca remote code for a trutech tv
Try this as all remotes work similar.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 26, 2009 | RCA 3-Device Universal Remote with...
Need code for rca remote control
Note:
Sep 25, 2009 | RCA RCR450 Remote Control
Cant program rca universal (crk76af10) for a viewsonic hd theres no code listed
Note:
Sep 25, 2009 | RCA Universal Remote Control
My remote somehow became cleared and I did not keep the instruction sheet. I have retreived the code but the instructions. Help please!!!
all you can do, is call the manufacturer and request another owner's manual, or google " rca 3-device remote owner's manual"
Sep 24, 2009 | RCA 3-Device Universal Remote
Lost remote to portable dvd player
Any universal remote will work. Just look on the back of it to make sure it supports your brand. That's the key. Just follow the directions for manual input. It will work something like this.
Note:
Sep 24, 2009 | RCA DIRECTV Satellite Remote Control
Unable to find a code for an admiral tv NO.GOJ
Most universal remotes work the same. Try this.
Note:
Sep 23, 2009 | RCA 3-Device Universal Remote
I NEED PROGRAM CODES AND PROCEDURES FOR RCR312W
I can help. I too have an RCR312W remote and it did not work.
I found this code on bobvila.com message board. The code from the RCR311W remote works.
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Oct 17, 2008 | RCA Universal Remote Control
HOW TO PROGRAM RCA RCU310 Remote Control
1. turn device on.
2. hold code search untill light stays on
3. press tv, vcr or whatever you want to program once. (light should still be on)
4. press on and off button untill your device turns off.
5. click enter on the remote. should be good,
6, dont forget to go outside now and then,
Mar 02, 2008 | RCA RCU310 Remote Control
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
Electro Med Services...
