Question about Haier Heating & Cooling
Troubleshoot Haier HWR05XC6 the unit is not getting cold and it keeps going back to 86? idk whats wrong it wont let me set the temp
You need the remote to set it on cold instead of just fan.
Posted on Jul 01, 2008
Haier AC changing temperature by itself
Have you tried calling the manufacturer? If you need more questions for your Air Conditioning Repair needs, check us out online
Jul 05, 2017 | Haier Heating & Cooling
Digital temperature changes to 86 every time your set it to a lower temperature how do I fix this
If this set temp changes on its own then the circuit board has failed. Call a service tech or replace the unit. But this 86° might be the indoor temp, not the set temp? If I set my temp to 75°, then my temp goes to 86°, then the set temp (target temp) is 75° & actual room temp is 86°. The unit may not be working properly. Not sure if this helps.
Jun 13, 2015 | Haier Heating & Cooling
When I press the control to get the air temp down to 60 it goes back to 86 right away , How can I fix it ? I have a Haire portablr air cond 7000 btu model hprbo7xc7
most air conditioning unit have a built in thermometer so that it will tell you the room temp,if you set the temp and then it goes to a high number let the system rum for a while and see if the temp starts to go down in the room it is probably working fine.
Jul 21, 2011 | Haier Heating & Cooling
Lost the remote to our hwr05xc6 haier air conditioner
mcdevito75 here, I belive your mom is right, temperature and Fan?? must be set manually, Fan speed I,m not to sure about. Contact Haier online, www.Haier Air or see any A/C shop in your area.
Jul 20, 2010 | Haier Mechanical Air Conditioner HWF05XC7
Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from Haier places, but I just took the motor out and took it to an appliance repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
Apr 04, 2009 | Haier HTQ21JABWW Top Freezer Refrigerator
Carrier heat pump: aux heat does not seem to work
The unit is probably to small for theare you are trying to heat.
When the Aux HT light came on that meant the heat pump could not keep up with the demand for heat. (Probably due to extreme cold, or undersized unit.)
If yu have heat, then at least one heat strip is operating. If you have multiple heatstrips, one or more could be malfuncioning.
Or it could simpy be to cold/to small fr your area and not able to keep up.
How many square foot are you trying to heat?
What is the outside temp?
What is the inside temp?
What size unit (BTU output) do you have?
Dec 22, 2008 | Haier Energy Star ESA3183 Air Conditioner
We have a haier air conditioner window, model number is HWR05XC6. It worked good last summer brand new and just put it back in the window for this year, and turned on the remote control the only thing that...
Dear Amy Rodger,first change your batteries, probably not enou gh juice. Dear Guest, around here in Oklahoma, dirt dobber nest always stops our fan blades from turnnings. Give it the ole once over.
Jun 02, 2008 | Heating & Cooling
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
Heating & Cooling Logo
151 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
