Question about Kirby G4 Bagged Upright Vacuum
Vacuum goes on and off while vacuuming
I bought this G4 used and it does fine when vacuuming straight back and forth but if I touch it against anything (ex: bump the couch) or pull it backwards at an angle while vacuuming it turns off. So to narrow the problem down, I knock the motor casing with my hand it turns off, knock it again, it turns on. Do you have any idea what this could be so I have a place to start?
Thanks in advance!
  • 357 Answers
It sounds like a power cord problem. Check out my troubleshooting guide....
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Hope this helps...
Posted on Jun 22, 2008
    Scholar:
  • 186 Answers
Defiantly sounds like a loose wire, but double check cord ends to make sure they aren't touch when moved from side to side. If not, check inside and see if their are loose connectors to the motor or even a weak switch.
Posted on Jun 20, 2008
Hoover floor mate sucks up water while in the wash position
They do that. They pickup the water in all stages but lower the squeegee to different heights. At no point does the suction turn off.
Jan 20, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
Spindle not coming off my kirby
it's a left handed thread watch this video
Oct 22, 2012 | Kirby G4 Bagged Upright Vacuum
Good Morning, after plugging the kirby in, I began to vacuum and a light started flickering from the back of the motor and then the sound while vacuuming starting getting louder and the light flickered...
The carbon brushes in your motor are worn out and "sparking" against the motor armature. DO NOT operate the vacuum in this condition or you may damage the armature so badly it will need replacement. Most vacuum dealers can replace the carbon brushes and resurface the armature. This should cost $40 to $50. If you need a new armature you are looking at $100 or more.
Jul 01, 2011 | Kirby G4 Bagged Upright Vacuum
Hi, How can I replace the power cable of a kirby ? Thanks gs
You'll need three types of screwdrivers. A straight edge, and 2 Torx, sizes 15 and 20.
With the vacuum in an upright position, remove cord from holder. Use the #15 Torx to remove the two screws holding th cord to the vacuum. Use the #20 Torx to remove the screw where the cord enters the vacuum. Insert the flathead screwdriver into the slot on the left side of the "box" and release the tab. Gently pull on box at the top and tilt out. Unplug the old cord and plug in the new.
Reverse these instructions to put everthing back together.
Here's a video showing how it's done on the Sentria. It's the same on my G4, so should be the same for a G6. Excellent video with easy to follow instructions.
http://www.youtube.com/watch?v=rXZjv3mh280&playnext=1&list=PLAD4F1D2DB5A5C97A&index=11
Jan 06, 2011 | Kirby G6 Bagged Upright Vacuum
Kirby G4 running very loud and smells hot.
were you put the belt on see if any thing is rubbing against shaft.it may have been the belt,replace the belt and clean out the bab and also the floor brush.
Jul 31, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Vacuum/Shampooer
i find the kirby carpet washer is rubbish coz it leaves all the dirty water in your carpet and it goes smelly!
Jul 06, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How to change Mini Em-Tor Fill Tube Assembly on Kirby G4
You will have to remove bag strap. You can try to save old strap (see instruction here) or you can cut it. Install the bag on the new mini-emptor just like it was on old one (strap goes over both layers of vinyl). Use a long cable tie instead of the strap if you have damages it or your old bag strap. If you are using old strap you may have to use pliers to get it in all the way.
Oct 27, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby G4 will not start
Check the mains socket with something else.
Oct 06, 2007 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
61 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
