Question about Shure Beta 58A Professional Microphone
Value of capacitor in Beta 58 headshell assy required to correct crackling
I have identified and removed a noisy surface mount capacitor on the cartridge interface pcb in the headshell assy. Even though the mic now appears to work perfectly without it, I would like to replace it but need to know the value. I have been quoted $319 to replace the cartridge assy and as the cap is worth about 20 cents, my options are clear. One leg of it goes to the yellow cartridge wire and the other leg goes to a SM electro.
Im not after the whole schematic so I can start a microphone factory, I just like to recycle and save money. Thanks Jack Jensen
  • 1 more comment
  • jackjensen Jul 06, 2008
    Thanks for responding. The Shure wireless Beta 58 is a PGx2. It has tested fine without the noisy capacitor and gone back into service, but it would still be nice to have a schematic if one is available. Thanks Jack
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi jackjensen
    I take it is a wireless beta 58?? What model specifically.
    regards
    robotek
  • Graeme Ross
    Hi jackjensen
    regards
    robotek
    Problem Solver:
  • 13 Answers
Probably 33 to 100 pF for RF suppression
Posted on Nov 30, 2008
Samsung R88, has no picture but the sound is working. I have checked the capsitors and they are fine any other ideas?
Check for voltage to the inverters. If there is no voltage to the inverter section, check for a surface mounted fuse and check it's condition if present.
Replace the larger value caps in the power supply as some may not show physical evidence of failure. Also remove the power supply board and check the surface mounted devices underneath to make sure there is no sign of a cold solder joint- the same on the inverter section. Good solder connections will look like a tiny volcano on the circuit board with the wire lead protruding from it- with no gaps, or areas that might suggest solder did not fully flow. Reflow solder to those connections if found. The Surface Mounted devices themselves should have smooth transitions in the solder, if not, reflow those with a soldering iron as well.
If there is voltage there, start by replacing the electrolytic capacitors in the inverter section. These will be values like 1, 2.2, 4.7 microfarad at 25 or 50 volts, These are part of the step up oscillator portion of the inverter. If that does not remedy it, check the transistors- a B&K type tester will not always give an accurate reading because the inducatnace is too low in the inverter transformer in circuit with it, so those usually need removal for accurate testing. Sometimes only one transistor needs to be removed.
If those test out okay, or are surface mounted or 4 leads plus tab versions first replace the larger value electrolytic capacitors, those will have values of 220, 330, 470, 560, 1000 microfards(sometimes higher capacities) at 25 or 35 volts. These can fail without visual indications. as they will be easier to remove than the surface mounted devices and likely cheaper too.
Dec 29, 2011 | Samsung Televison & Video
I need the torque specs for replacing the valve cover gasket on a 2001 chevy cavallier 2.2 liter 4cly. thanks
This should do the trick, torque to specs then additional 90 degrees turn on all bolts
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  • Use the following sequence in order to tighten the cylinder head bolts: Tighten
    1. Tighten bolt 1 to 63 N·m (46 lb ft).
    2. Tighten bolt 2 to 58 N·m (43 lb ft).
    3. Tighten bolt 3 to 58 N·m (43 lb ft).
    4. Tighten bolt 4 to 63 N·m (46 lb ft).
    5. Tighten bolt 5 to 63 N·m (46 lb ft).
    6. Tighten bolt 6 to 58 N·m (43 lb ft).
    7. Tighten bolt 7 to 58 N·m (43 lb ft).
    8. Tighten bolt 8 to 63 N·m (46 lb ft).
    9. Tighten bolt 9 to 63 N·m (46 lb ft).
    10. Tighten bolt 10 (stud bolt) to 58 N·m (43 lb ft).
    11. Then tighten all bolts an additional 90 degrees
  • Jun 28, 2011 | 2001 Chevrolet Cavalier
    Crackling sound from speakers, intermittent, but seems to start after warming up
    If these speakers are internal to the TV, chances are an internal component is getting noisy -- probably a capacitor -- and will eventually need replacement. That's not something you can do yourself. It's also possible there's a loose connection or a noisy volume control, but that's less likely, and again, would require a qualified serviceman.
    If the speakers are external - that is, you've plugged them into the set -- check the connections at the set and at the speaker to make sure they're not corroded and are firmly seated. Sometimes just unplugging and replugging them a couple of times rubs off enough corrosion to solve the problem. Also wiggle the wires close to the connectors on the cables. If that causes the crackle, replace the cables.
    Oct 04, 2010 | LG 42PC3D 42 in. Plasma Television
    How do you change the cooling fan
    Electric Engine Fan
    Cooling Fan Connectors
    Removal & Installation
    2.2L& 2.4L Engines
    1. Disconnect the negative battery cable.
    2. Remove the hood close out filler retainers.
    3. Remove the hood close out filler panel.
    4. Remove the upper radiator mount bolts.
    5. Remove the upper two hood latch support bolts.
    6. Remove the two lower hood latch support bolts.
    7. Raise the vehicle.
    8. Remove the cooling fan mounting bolt.
    9. Disconnect the electrical connector from the cooling fan. Remove the cooling fan assembly.
    To install:
    1. Install the cooling fan assembly.
    2. Connect the electrical connector to the cooling fan.
    3. Install the cooling fan mounting bolt. Tighten the bolt to 53 inch lbs. (6 Nm).
    4. Lower the vehicle.
    5. Install the lower two hood latch support bolts. Tighten the bolts to 20 ft. lbs. (27 Nm).
    6. Install the two upper hood latch support bolts. Tighten the two upper hood latch support bolts to 80 inch lbs. (9 Nm).
    7. Install the upper radiator mount bolts. Tighten bolts to 89 inch lbs. (10 Nm).
    8. Install the hood close out filler panel.
    9. Install the hood close out filler panel retainers.
      CAUTION Be careful when you handle a sensor. Do not strike or jolt a sensor. Before applying power to a sensor:
      Fig. Remove the hood close out filler retainers and the hood close out filler panel
      1. Remove any dirt, grease, etc. from the mounting surface
      2. Position the sensor horizontally on the mounting surface
      3. Point the arrow on the sensor toward the front of the vehicle
      4. Tighten all of the sensor fasteners and sensor bracket fasteners to the specified torque value.
    4. Failure to follow the correct procedure could cause air bag deployment, personal injury, or unnecessary SIR system repairs.
    5. Disable the air bag sensor.
    6. Remove the upper radiator mount bolts.
    7. Remove the upper 2 hood latch support bolts (2).
    8. Remove the 2 lower hood latch support bolts (4).
    9. Raise the vehicle.
      Fig. Remove the cooling fan mounting bolt
    10. Remove the cooling fan mounting bolt.
    11. Disconnect the electrical connector from the cooling fan.
    12. Remove the cooling fan assembly.
    To install:
      NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
    3. Install the cooling fan mounting bolt and tighten the bolt to 53 lb inches (6 Nm).
    5. Install the lower 2 hood latch support bolts and tighten the bolts) to 20 ft. lbs. (27 Nm).
    6. Install the 2 upper hood latch support bolts and tighten the bolts to 80 lb inches (9 Nm).
    7. Install the upper radiator mount bolts and tighten bolts to 89 lb inches (10 Nm).
    8. Engage the air bag sensor.
    9. Install the hood close out filler panel.
    10. Install the hood close out filler panel retainers.
    11. Connect the negative battery cable.
    Hope this help (remember comment and rated this).
    Apr 14, 2010 | 2001 Chevrolet Cavalier
    Picture is distorted keeps on moving
    Good Day,
    You have problem with caps on the Hyper Board. This is how to repair it:
    MVPU13 Hyper Module Repair (23786198 / 23148017X)
    Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove
    the top shield and replace all of the 10uf, 16v capacitors using Part Number 24619040 It’s recommended that all of the capacitors identified be replaced. (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care).
    GOOD luck, big IRISH.
    should be taken to avoid damaging the PCB while replacing these capacitors.
    Dec 08, 2009 | Toshiba 42H81 42" Rear Projection...
    Componenet failure Acer aspire 5920 I do not know if its a diode or capacitor. Anyway when I go to power on I get nothing. My power adapter light goes dim. Does anybody have any idea on how to identify the...
    start up circuit problem, double check the output voltage on the adapter should be between 16vdc -20vdc, if ok connect a load to it example dc bulb/led or the battery of the laptop, if it remains on the adapter is ok, next check the laptop battery, remove it from the laptop and using a meter check the voltage and polarity.monitor the voltage to see if it is falling or holding,it should be holding, if all is well the next step is to check the voltage at the switch, this requires you to take apart the laptop to trace/test the voltage form the input to the battery to the mainboard to the switch and back to the mainboard. if the voltage is not present on the main board you will have to check the components to see which one is defective,if a protection diode it will be a very small component (smd) usually black in color and located close to the input connector.you will have to replace it,which will require some special tools and a lot of steady nerves.if a capacitor it will be brownish in color (smd)Surface Mounted Device.
    Hope this helps
    Ken.
    Nov 13, 2009 | Acer Computers & Internet
    Shure beta 58
    Benimur, you are correct, except that the Beta 58 is a condenser mic that required phantom power. In that case all 3 lines are used. Included below are the connections.
    Dan
    Sep 11, 2008 | Shure Beta 58A Professional Microphone
    Headshell for Denon DP-45F Turntable
    The PCL-30 does not look like a standard headshell. I doubt the above answer is correct.
    Aug 02, 2008 | Audio Players & Recorders
    Shure 55sh series 2 mic repair
    Hi, I actually rebuild these mics and upgrade them. I'm an expert in the vintage 55's of all era's and the newer. If you are just looking to go back with the stock element of a 55sh2, or looking to upgrade your 55 vintage or new, with a SM58 a Beta 58, or a 87 Beta, I do all of that. All repaires from Hard mounted XLRs, screens, to polishing the surface back to new, or upgrade kits that you can put in yourself with my pictured instructions. Check out my web page at Mutantmics.com or google search Mutant Mics or conatct me directly at whoizitcc69@aol.com
    Mar 21, 2008 | Shure Beta 58A Professional Microphone
    Shure Beta 58A Professional Microphone Logo
    158 people viewed this question
    Top Shure Audio Players & Recorders Experts
    Ben Armstrong
    Vito Vacirca Jr.
    Jerry Greenberg
    Jerry Greenberg
    Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
