Question about Toshiba Televison & Video
I accidently hit convergence and now my tv is off. Words are double now how can i get it back
  • Ken Jones
    Ken Jones May 11, 2010
    What is the model of your Toshiba?
    Sergeant:
  • 260 Answers
I assume you have already resolved this problem. If not, please let me know what the model # is and I will work for you to resolve this.
Many problems can be fixed by unplugging your television for a couple of minutes and then plugging it back in.
Thanks,
Ken
Posted on Jun 23, 2008
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
I accidently hit auto convergence and now the tv has a double vison effect how can i reset it to proper setting
Hi, does your tv have a calibration setting on it and if so you will have to manually set the colors back into alignment. Please let me know what you find.
Feb 24, 2010 | RCA D52W19 52" Rear Projection Television
I have red and green double vision on words showing on the screen
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Philips 60PP9352 60" Rear Projection...
I have double lines in red and green and double words
It sounds like you need to adjust your convergence. If this is a projection TV with CRT's (3) which it sounds like it is there may be an option in the menu to setup convergence. Difficult to tell without knowing the model number and type of projection TV (CRT, LCD, DLP)?
Jul 11, 2009 | Philips Televison & Video
Words are doubled red borders???
Just to clarify, it sounds like what you are saying is that the image appears to duplicate in either red or blue along the edges of the image (especially white lettering and probably increasing along the boarder of the TV). This is resolved by converging your TV. Convergence will drift normally on large screen projection TV's over time or through moving them. The Hitachi 57f500a has a feature called "Magic Focus" (pg 36 in your manual) which will auto converge the image. If the auto converge feature doesn't work, on page 37 in your manual, it explains how to converge manually. If you do not have the manual, I have the image of the pages below. If for some reason this doesn't work, please provide additional info and detailed prior to rating the help.
Apr 20, 2009 | Hitachi 57F500 57" Rear Projection...
The image of the tv not clear words are double
I just had that problem, need to replace the icg chip. but first get the remote the tv came with hit
menu go to the convergeance screen. try to put the lines together with that first. if the color
lines will not line up u need to replace chip. they r cheap
Mar 27, 2009 | Sony Televison & Video
Double words and blurred picture,
Is the picture bowed in too. first consult "the fl231 problem" article under the tip and tricks section under my profile. THis MAY be the problem. Otherwise you have a convergence issue. convergence is controled by three cuicit boards in this set. Setting the convergence on this set is tricky. try autoconvergence see how far it gets. let me know and i help you trouble shoot further
Nov 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Double words
Sounds like your red is out of convergence. You may be able to adjust the convergence in the TVs menus. It may also be possible that the TVs convergence circuitry has gone bad. In that case it would be worth to have the TV repaired, convergence board are usually fairly inexpensive.
Oct 27, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Arches of words and top and bottom doubled with red words
Convergence mis-alignment = replace convergence amp IC's
Part # STK392-110 sub to upgrade STK394-160E. I use
Hitachi brand for no recalls.....................T.
Oct 31, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
