Lamp Fault Code (LFC)
When the Restraints Control Module (RCM) detects a system fault, it will flash a coded sequence which is called a Lamp Fault Code (LFC) on the air bag warning indicator located in the Instrument Cluster (IC) module. The code is 2 digits. The first digit is flashed with a 0.5-second interval between pulses. There is a 2-second pause before the second digit is flashed, which also has a 0.5-second interval between pulses. There is a 5-second pause between each display of an LFC.
Each LFC is flashed 3 times after which the air bag indictor will remain lit for the remainder of the key-on cycle (except for DTC B2792 [cross link between firing loops] which only flashes one LFC). If there are multiple LFCs, each LFC will flash in order of priority.
Supplemental Restraint System (SRS) Lamp Fault Code (LFC) Chart
LFC
6-8
31
Restraint System - Impact Sensor Fault (Passenger Side Short to Ground Fault)
GO to Pinpoint Test M.
SOURCE: 2005 Crown Vic Police Interceptor: Starts then stalls
Have you checked the fuel filter. Fuel pump will pressure up, but fuel filter could be clogged and not work without the pressure of the fuel pump.
SOURCE: 1994 crown vic air bag warning light blinks
it is a code,does the horn and cruise still work?chances are the clock spring wore out and broke,its behind the steering wheel and about $100.00 part at Ford
SOURCE: Replace horn on 2006 crown vic
I believe once you have mounted the horn and connected the wire you will find that the horn wire was cut at (by) the steering coloum that the siren override was hooked to,you will have reconnect this,I hope this helps you
SOURCE: need wiring diagram for 2005 ford crown vic A/C
Go to Autozone .com they have diagrams on line . You may have to register to gain access
SOURCE: hi i got an 03 crown vic, the airbag light come on
dealer only ,classed as safety so its encrypted software ,either sell it quick or be prepared to pay up to 2000euros .It will not pass the annual vehicle mechanical inspection like this
