Question about Dometic Refrigerators
How hard is it to remove the dometic americana 2652 double door fridge?
    Scholar:
  • 110 Answers
Make sure the rf is not sitting on the legs but setting on the wheels. it is very common for installers to roll down the legs to stabilize the machine in order to prevent liability issues or simply just to level the rf due to unlevel floors
Posted on Jun 20, 2008
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
How do i change an element on adometic ref. mod. dm2652lb1
remove back access panel two black wires come from board and go into chimney
May 19, 2014 | Dometic DM2652 Americana Fridge...
Refrigerator not cooling on electricty or gas
You will first want to ensure the RV is level.
If the RV is level, then open the rear access vent door on the side of the RV to access the rear of the refrigerator. Feel the coils just above the tank on the cooling system. These coils should be warm to the touch. If they are warm and the refrigerator is not cooling then you will require a replacement cooling unit. Also, the most common area for the Dometic 2652 to leak is just above the propane burner area. If it has leaked, you should see a yellow residue in that area. The cooling unit can be changed in approximately 2-3 hours with no specialized tools needed (Arcticold offers 7 day a week free tech support). The old cooling unit will simply unbolt and the new one bolts in. Check out ArctiCold Refrigeration We keep it cold (the highest quality product available) Arcticold New Cooling units come standard with a Lifetime Warranty. Install instructions are also provided with the cooling unit. Arcticold has locations across North America to provide fast delivery. Arcticold cooling units may be purchased over the phone (1-888-782-6665) or through Ebay- Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
#1 Help Diagnose Video
#2 Install a Arcticold RM2652 Cooling Unit Video
Mar 15, 2014 | Dometic DM2652 Americana Fridge...
How do you replace a door handle/latch on a Dometic RM 2652 fridge door?
There should be two screws holding the handle on. Remove them and install the new handle assembly.
Aug 31, 2013 | Dometic Refrigerators
Dm2652
if Lp system is ok replace board but check gas line for obstructions if no clicking noise bad board or ignitor
May 30, 2013 | Dometic DM2652 Americana Fridge...
Everything freezes, model 2652 dometic americana
Hello, Inside you fridge part (not the Freezer) you will find your cooling fins,and on you fins there is a white piese of plastic and in this plastic there is a probe this will adjust you temp. by slidding it up and down.but it hasen't been touched you may have a faulty probe.acesses to plug is in rear of fridge in a black box (printed circit board)located outside of camper,you may need a qualified person to install.
Sep 14, 2011 | Dometic RM2652 Refrigerator
Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
Nov 10, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerators Logo
150 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
