I cannot set up a magnavox dvd recorder. - Televison & Video
  • Ken Jones
    Ken Jones May 11, 2010
    What are you trying to connect it to?
    Is it already connected?
    Sergeant:
  • 260 Answers
I assume you have already solved your problem. If not, please let me know and I will work with you. It would be helpful to have a model # so I can assist you further. Most new units require a series of cables that are red, yellow, and white. Just match the plugs on the back of the dvr with the tv or other output device. I also need to know what you are connecting the device to.
Thanks,
Ken
Posted on Jun 23, 2008
Thru my vcr
Posted on Jun 20, 2008
Trying to connect Magnavox MWR 10D6 DVD/Recorder to Sanyo HDTV. TV is connected to Dish network through coax. cable.
Unfortunately, the Magnavox MWR10D6 recorder can not record HD signals. It's only video inputs are coax (RF) and composite video; both are limited to 480i (SD). NTSC (analog signals) are translated to video.
Your best recording option is to connect the composite video output of the Dish receiver to the video input (yellow for video, red and white for audio) of the recorder. Then set the receiver to the channel that you want to record and set the recorder to Line In.
HD recorders may exist. They are much more expensive than the SD versions.
I wish that I had better news for you. The manual for the MWR10D6 is available from Funai here: http://www.funai-corp.com/support/om/MWR10D6.pdf .
Apr 18, 2013 | Philips Magnavox MWR10D6 DVD Recorder
I cannot record digital when I try to set up my Magnavox ZV457MG9 (DVD). The unit will only record in the external L1. I have a Comcast box.
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
The manual for the Magnavox ZV457MG9/F7 is available here: http://download.m4c.magnavox.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf . The unit was manufactured for Magnavox by Funai; thus another link to the manual is http://www.funai-corp.com/6pdf/om/ZV427MG9.pdf .
(If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
Oct 01, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Magnavox DVD/VCR Recorder ZV457MG9 How do I finalize my DVD on this player/recorder?
http://www.ehow.com/how_8623235_do-finalize-magnavox-dvd.html is how to finalize a disk on Magnovoz! I have the ZV457MG9 - its model takes with
1) loading disk
2) select the set up button
3) select DVD edit
4) select finalize DVD
Then you finalize the DVD!!!
Jan 31, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I recently copied some of my old VHS tapes onto DVD-R disc & they play fine on my Magnavox, but won't play on my other DVD player. What did I do wrong?
Check through, the settings of Magnavox and do the similar region
settings in your other DVD.
In short to say, recording format and the play back format does not
match. if you corect this through the MENU available, it should be OK.
May be your other DVD is old model!
Aug 22, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I am attempting to record from a VCR tape to
I have a Magnavox MWR20V6 and I am attempting to record a Tv show but when I play it back the recording is just black.
Jan 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I HAVE A MAGNAVOX DVD RECORDER MWR10D6 AND I AM TRYING TO RECORD VHS TAPE FROM A VCR TO THE DVD RECORDER. CAN YOU HELP ME WITH THE CORRECT CORRECTIONS; NOTHING IS RECORDING
Play the video on your through your recorder if possible, then record it that way. It works for me. Just go to your watch tv setting and record it off channel three while the vcr plays the video.
Jan 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
How to set up my magnavox dvd player / recorder
http://safemanuals.com/user-guide-instructions-owner-manual/FUNAI/MWR10D6
Dec 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Magnavox error code
i get the same error code just putting in a dvd and hitting the record button
Aug 07, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't setup Magnavox DVD VCR recorder
Put your TV onto chanel 3 to pick up your Magnvox signal
Jan 06, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
